IBM ASIC back-end design engineer recruit
2455|0
 楼主| hustyw 发表于 2008-8-5 21:31 | 显示全部楼层 |阅读模式
IBM&nbsp;ASIC&nbsp;back-end&nbsp;design&nbsp;engineer&nbsp;recruit<br />&nbsp;&nbsp;Job&nbsp;Scopes&nbsp;&&nbsp;Responsibilities:<br />IBM&nbsp;ASIC/back-end&nbsp;design&nbsp;engineer&nbsp;is&nbsp;resposible&nbsp;for&nbsp;physical&nbsp;implementation&nbsp;of<br />&nbsp;very&nbsp;large&nbsp;scale&nbsp;CMOS&nbsp;SoC/ASIC&nbsp;design&nbsp;from&nbsp;netlist&nbsp;handover&nbsp;to&nbsp;GDS&nbsp;tapeout,&nbsp;b<br />ased&nbsp;on&nbsp;IBM&nbsp;90nm,&nbsp;65nm,&nbsp;45nm&nbsp;and&nbsp;beyond&nbsp;technology&nbsp;with&nbsp;IBM/industry&nbsp;leading&nbsp;E<br />DA&nbsp;tools.&nbsp;The&nbsp;work&nbsp;scope&nbsp;includes&nbsp;one&nbsp;or&nbsp;more&nbsp;of&nbsp;following&nbsp;areas:<br />-&nbsp;Supporting&nbsp;customer&nbsp;on&nbsp;IBM&nbsp;IP&nbsp;core&nbsp;usage,&nbsp;IO&nbsp;selection&nbsp;and&nbsp;netlist&nbsp;preparati<br />on/synthesis.<br />-&nbsp;Working&nbsp;with&nbsp;customer&nbsp;to&nbsp;define&nbsp;physical&nbsp;implementation&nbsp;strategies&nbsp;including<br />&nbsp;logic&nbsp;partition,&nbsp;design&nbsp;planning,&nbsp;etc.<br />-&nbsp;Top&nbsp;level&nbsp;insertion&nbsp;and&nbsp;netlist&nbsp;processing,&nbsp;including&nbsp;IO<br />assignment/insertion,&nbsp;JTAG&nbsp;structure&nbsp;building,&nbsp;scan&nbsp;chain&nbsp;&&nbsp;BIST&nbsp;insertion,&nbsp;et<br />c.<br />-&nbsp;DFT&nbsp;verification&nbsp;and&nbsp;formal&nbsp;verification<br />-&nbsp;Timing&nbsp;assertions/constraints&nbsp;specification&nbsp;and&nbsp;verification,&nbsp;STA&nbsp;analysis&nbsp;a<br />nd&nbsp;design&nbsp;timing&nbsp;closure;<br />-&nbsp;Physical&nbsp;design,&nbsp;floorplanning,&nbsp;I/O&nbsp;planning,&nbsp;physical&nbsp;synthesis,&nbsp;clock&nbsp;tree<br />&nbsp;generation&nbsp;and&nbsp;tuning,&nbsp;place&nbsp;&route;<br />-&nbsp;Physical&nbsp;verification&nbsp;and&nbsp;reliability&nbsp;verification;<br />-&nbsp;ASIC&nbsp;package&nbsp;design,&nbsp;image(power&nbsp;bus)&nbsp;creating&nbsp;and&nbsp;verification<br />-&nbsp;On&nbsp;chip&nbsp;and&nbsp;package&nbsp;power&nbsp;bus&nbsp;analysis,&nbsp;chip&nbsp;and&nbsp;system&nbsp;cominbational&nbsp;SI/PI&nbsp;<br />analysis.<br />-&nbsp;Design&nbsp;signoff<br />-&nbsp;Coordinating&nbsp;with&nbsp;other&nbsp;IBM&nbsp;function&nbsp;teams&nbsp;to&nbsp;support&nbsp;the&nbsp;related&nbsp;problem&nbsp;so<br />lving&nbsp;during&nbsp;SoC/ASIC&nbsp;design&nbsp;execution.<br />The&nbsp;candidate&nbsp;would&nbsp;also&nbsp;have&nbsp;future&nbsp;extended&nbsp;responsibility&nbsp;participating&nbsp;in&nbsp;<br />the&nbsp;design&nbsp;planning&nbsp;and&nbsp;sizing&nbsp;for&nbsp;the&nbsp;advanced&nbsp;ASIC/SoC&nbsp;chips,&nbsp;and&nbsp;developmen<br />t,&nbsp;deployment&nbsp;and&nbsp;other&nbsp;application&nbsp;engineering&nbsp;support&nbsp;of&nbsp;the&nbsp;design&nbsp;methodol<br />ogy.<br />If&nbsp;you&nbsp;have&nbsp;interest&nbsp;please&nbsp;mail&nbsp;to&nbsp;yinwen372@163.com&nbsp;with&nbsp;subject&nbsp;&quot;Apply&nbsp;IBM&nbsp;<br />ASIC&nbsp;design&nbsp;engineer_yourname&quot;&nbsp;and&nbsp;resume.<br />Thanks!<br />
