我对TI官网上的例程“spi_loopback_interrupts”进行了测试,为什么我sdata[i]里的数据总是比rdata[i]要大3,想不明白,请教啊!程序如下
#include "DSP281x_Device.h" // DSP281x Headerfile Include File
#include "DSP281x_Examples.h" // DSP281x Examples Include File
// Prototype statements for functions found within this file.
// interrupt void ISRTimer2(void);
interrupt void spiTxFifoIsr(void);
interrupt void spiRxFifoIsr(void);
void delay_loop(void);
void spi_fifo_init(void);
void error();
Uint16 sdata[8]; // Send data buffer
Uint16 rdata[8]; // Receive data buffer
Uint16 rdata_point; // Keep track of where we are
// in the data stream to check received data
void main(void)
Uint16 i;
// Step 1. Initialize System Control:
// PLL, WatchDog, enable Peripheral Clocks
// This example function is found in the DSP281x_SysCtrl.c file.
InitSysCtrl();
// Step 2. Initalize GPIO:
// This example function is found in the DSP281x_Gpio.c file and
// illustrates how to set the GPIO to it's default state.
// InitGpio(); // Skipped for this example
// Setup only the GP I/O only for SPI functionality
EALLOW;
GpioMuxRegs.GPFMUX.all=0x000F; // Select GPIOs to be SPI pins
// Port F MUX - x000 0000 0000 1111
EDIS;
// Step 3. Initialize PIE vector table:
// Disable and clear all CPU interrupts
DINT;
IER = 0x0000;
IFR = 0x0000;
// Initialize PIE control registers to their default state:
// This function is found in the DSP281x_PieCtrl.c file.
InitPieCtrl();
// Initialize the PIE vector table with pointers to the shell Interrupt
// Service Routines (ISR).
// This will populate the entire table, even if the interrupt
// is not used in this example. This is useful for debug purposes.
// The shell ISR routines are found in DSP281x_DefaultIsr.c.
// This function is found in DSP281x_PieVect.c.
InitPieVectTable();
// Interrupts that are used in this example are re-mapped to
// ISR functions found within this file.
EALLOW; // This is needed to write to EALLOW protected registers
PieVectTable.SPIRXINTA = &spiRxFifoIsr;
PieVectTable.SPITXINTA = &spiTxFifoIsr;
EDIS; // This is needed to disable write to EALLOW protected registers
// Step 4. Initialize all the Device Peripherals:
// This function is found in DSP281x_InitPeripherals.c
// InitPeripherals(); // Not required for this example
spi_fifo_init(); // Initialize the SPI only
// Step 5. User specific code, enable interrupts:
// Initalize the send data buffer
for(i=0; i<8; i++)
sdata[i] = i;
rdata_point = 0;
// Enable interrupts required for this example
PieCtrlRegs.PIECRTL.bit.ENPIE = 1; // Enable the PIE block
PieCtrlRegs.PIEIER6.bit.INTx1=1; // Enable PIE Group 6, INT 1
PieCtrlRegs.PIEIER6.bit.INTx2=1; // Enable PIE Group 6, INT 2
IER=0x20; // Enable CPU INT6
EINT; // Enable Global Interrupts
// Step 6. IDLE loop. Just sit and loop forever (optional):
for(;;);
// Some Useful local functions
void delay_loop()
long i;
for (i = 0; i < 1000000; i++) {}
void error(void)
asm(" ESTOP0"); //Test failed!! Stop!
for (;;);
void spi_fifo_init()
// Initialize SPI FIFO registers
SpiaRegs.SPICCR.bit.SPISWRESET=0; // Reset SPI
SpiaRegs.SPICCR.all=0x001F; //16-bit character, Loopback mode
SpiaRegs.SPICTL.all=0x0017; //Interrupt enabled, Master/Slave XMIT enabled
SpiaRegs.SPISTS.all=0x0000;
SpiaRegs.SPIBRR=0x0063; // Baud rate
SpiaRegs.SPIFFTX.all=0xC028; // Enable FIFO's, set TX FIFO level to 8
SpiaRegs.SPIFFRX.all=0x0028; // Set RX FIFO level to 8
SpiaRegs.SPIFFCT.all=0x00;
SpiaRegs.SPIPRI.all=0x0010;
SpiaRegs.SPICCR.bit.SPISWRESET=1; // Enable SPI
SpiaRegs.SPIFFTX.bit.TXFIFO=1;
SpiaRegs.SPIFFRX.bit.RXFIFORESET=1;
Uint16 i;
for(i=0;i<8;i++)
SpiaRegs.SPITXBUF=sdata[i]; // Send data
for(i=0;i<8;i++) // Increment data for next cycle
sdata[i]++;
SpiaRegs.SPIFFTX.bit.TXFFINTCLR=1; // Clear Interrupt flag
PieCtrlRegs.PIEACK.all|=0x20; // Issue PIE ACK
Uint16 i;
for(i=0;i<8;i++)
rdata[i]=SpiaRegs.SPIRXBUF; // Read data
for(i=0;i<8;i++) // Check received data
if(rdata[i] != rdata_point+i) error();
rdata_point++;
SpiaRegs.SPIFFRX.bit.RXFFOVFCLR=1; // Clear Overflow flag
SpiaRegs.SPIFFRX.bit.RXFFINTCLR=1; // Clear Interrupt flag
PieCtrlRegs.PIEACK.all|=0x20; // Issue PIE ack
// No more.
