[DSP编程] F2812 SPI
2444|1
 楼主| 臻至水 发表于 2013-9-17 10:33 | 显示全部楼层 |阅读模式
我对TI官网上的例程“spi_loopback_interrupts”进行了测试,为什么我sdata[i]里的数据总是比rdata[i]要大3,想不明白,请教啊!程序如下
#include "DSP281x_Device.h"     // DSP281x Headerfile Include File
#include "DSP281x_Examples.h"   // DSP281x Examples Include File
// Prototype statements for functions found within this file.
// interrupt void ISRTimer2(void);
interrupt void spiTxFifoIsr(void);
interrupt void spiRxFifoIsr(void);
void delay_loop(void);
void spi_fifo_init(void);
void error();
Uint16 sdata[8];     // Send data buffer
Uint16 rdata[8];     // Receive data buffer
Uint16 rdata_point;  // Keep track of where we are
                     // in the data stream to check received data
void main(void)
   Uint16 i;
// Step 1. Initialize System Control:
// PLL, WatchDog, enable Peripheral Clocks
// This example function is found in the DSP281x_SysCtrl.c file.
   InitSysCtrl();
// Step 2. Initalize GPIO:
// This example function is found in the DSP281x_Gpio.c file and
// illustrates how to set the GPIO to it's default state.
// InitGpio();  // Skipped for this example
// Setup only the GP I/O only for SPI functionality
   EALLOW;
   GpioMuxRegs.GPFMUX.all=0x000F; // Select GPIOs to be SPI pins
                                    // Port F MUX - x000 0000 0000 1111
   EDIS;
// Step 3. Initialize PIE vector table:
// Disable and clear all CPU interrupts
   DINT;
   IER = 0x0000;
   IFR = 0x0000;
// Initialize PIE control registers to their default state:
// This function is found in the DSP281x_PieCtrl.c file.
   InitPieCtrl();
// Initialize the PIE vector table with pointers to the shell Interrupt
// Service Routines (ISR).
// This will populate the entire table, even if the interrupt
// is not used in this example.  This is useful for debug purposes.
// The shell ISR routines are found in DSP281x_DefaultIsr.c.
// This function is found in DSP281x_PieVect.c.
   InitPieVectTable();
// Interrupts that are used in this example are re-mapped to
// ISR functions found within this file.
   EALLOW; // This is needed to write to EALLOW protected registers
   PieVectTable.SPIRXINTA = &spiRxFifoIsr;
   PieVectTable.SPITXINTA = &spiTxFifoIsr;
   EDIS;   // This is needed to disable write to EALLOW protected registers
// Step 4. Initialize all the Device Peripherals:
// This function is found in DSP281x_InitPeripherals.c
// InitPeripherals(); // Not required for this example
   spi_fifo_init();   // Initialize the SPI only
// Step 5. User specific code, enable interrupts:
// Initalize the send data buffer
   for(i=0; i<8; i++)
      sdata[i] = i;
   rdata_point = 0;
// Enable interrupts required for this example
   PieCtrlRegs.PIECRTL.bit.ENPIE = 1;   // Enable the PIE block
   PieCtrlRegs.PIEIER6.bit.INTx1=1;     // Enable PIE Group 6, INT 1
   PieCtrlRegs.PIEIER6.bit.INTx2=1;     // Enable PIE Group 6, INT 2
   IER=0x20;                            // Enable CPU INT6
   EINT;                                // Enable Global Interrupts
// Step 6. IDLE loop. Just sit and loop forever (optional):
for(;;);
// Some Useful local functions
void delay_loop()
    long      i;
    for (i = 0; i < 1000000; i++) {}
void error(void)
    asm("     ESTOP0");  //Test failed!! Stop!
    for (;;);
void spi_fifo_init()
// Initialize SPI FIFO registers
   SpiaRegs.SPICCR.bit.SPISWRESET=0; // Reset SPI
   SpiaRegs.SPICCR.all=0x001F;       //16-bit character, Loopback mode
   SpiaRegs.SPICTL.all=0x0017;       //Interrupt enabled, Master/Slave XMIT enabled
   SpiaRegs.SPISTS.all=0x0000;
   SpiaRegs.SPIBRR=0x0063;           // Baud rate
   SpiaRegs.SPIFFTX.all=0xC028;    // Enable FIFO's, set TX FIFO level to 8
   SpiaRegs.SPIFFRX.all=0x0028;     // Set RX FIFO level to 8
   SpiaRegs.SPIFFCT.all=0x00;
   SpiaRegs.SPIPRI.all=0x0010;
   SpiaRegs.SPICCR.bit.SPISWRESET=1;  // Enable SPI
   SpiaRegs.SPIFFTX.bit.TXFIFO=1;
   SpiaRegs.SPIFFRX.bit.RXFIFORESET=1;
  Uint16 i;
    for(i=0;i<8;i++)
     SpiaRegs.SPITXBUF=sdata[i];      // Send data
    for(i=0;i<8;i++)                    // Increment data for next cycle
     sdata[i]++;
    SpiaRegs.SPIFFTX.bit.TXFFINTCLR=1;  // Clear Interrupt flag
PieCtrlRegs.PIEACK.all|=0x20;    // Issue PIE ACK
    Uint16 i;
    for(i=0;i<8;i++)
     rdata[i]=SpiaRegs.SPIRXBUF;  // Read data
for(i=0;i<8;i++)                    // Check received data
     if(rdata[i] != rdata_point+i) error();
rdata_point++;
SpiaRegs.SPIFFRX.bit.RXFFOVFCLR=1;  // Clear Overflow flag
SpiaRegs.SPIFFRX.bit.RXFFINTCLR=1;  // Clear Interrupt flag
PieCtrlRegs.PIEACK.all|=0x20;       // Issue PIE ack
// No more.
zhangmangui 发表于 2013-9-17 18:34 | 显示全部楼层
对比看看   那儿出错了
