[Quartus] QUATTUS的问题
1570|4
 楼主| 胡斯哲 发表于 2014-12-2 13:47 | 显示全部楼层 |阅读模式
这个这样放置在边沿检测编译不通过
  1. ADJUST2:PROCESS(down) BEGIN
  2.                IF adj_bit = 6 THEN v60s1<="000000";v60m1<="000000";END IF;--problem--
  3.                         IF down' EVENT AND down='0' THEN
  4.                                 CASE adj_bit IS
  5.                                         WHEN "0001"=>v60s1<=v60s1+1;
  6.                                         WHEN "0010"=>v60m1<=v60m1+1;
  7.                                         WHEN OTHERS=>NULL;
  8.                                 END CASE;
  9.                         END IF;
  10.
  11.                 END PROCESS;
放置在后面就编译通过
  2.                         IF down' EVENT AND down='0' THEN
  3.                                 CASE adj_bit IS
  4.                                         WHEN "0001"=>v60s1<=v60s1+1;
  5.                                         WHEN "0010"=>v60m1<=v60m1+1;
  6.                                         WHEN OTHERS=>NULL;
  7.                                 END CASE;
  8.                         END IF;
  9.                         IF adj_bit = 6 THEN v60s1<="000000";v60m1<="000000";END IF;---------++++++++——————————
  10.                 END PROCESS;
而另一则放置在边沿检测前可以通过
SEC:        PROCESS(clk)
                VARIABLE v60s2:STD_LOGIC_VECTOR(5 DOWNTO 0);
                        BEGIN
                        IF adj_bit/=0 THEN v60s2:=v60s1; END IF;
                        IF  clk' EVENT AND clk='1'
                        THEN
                        IF stop='0' THEN
                                if v60s=59 THEN v60s<="000000";clk_60s_m<='1';--59
                                        ELSE v60s<=v60s+1+v60s2;clk_60s_m<='0';
                                        END IF;
                                END IF;
                        END IF;
                END PROCESS;
 楼主| 胡斯哲 发表于 2014-12-3 18:17 | 显示全部楼层
 楼主| 胡斯哲 发表于 2014-12-3 18:18 | 显示全部楼层
分都给不了了
个人签名:读书喝茶,不争朝夕
141
