[DSP编程] 28335输出PWM波形求指导!
 楼主| 草上之风 发表于 2015-4-9 11:02 | 显示全部楼层 |阅读模式
各位前辈,小白想用28335输出PWM给驱动器驱动步进电机,编译过了,可是动不了,不知道哪里有问题求指导!! 或者直接给一个能输出PWM的28335的工程也许啊!!
多谢啦~~
这个是配置PWM程序
#include "DSP2833x_Device.h"
#include "DSP2833x_Examples.h"
#if (CPU_FRQ_150MHZ)
  #define CPU_CLK   150e6
#endif
#if (CPU_FRQ_100MHZ)
  #define CPU_CLK   100e6
#endif
#define PWM_CLK   10e3                // If diff freq. desired, change freq here.
#define SP        CPU_CLK/(2*PWM_CLK)
#define TBCTLVAL  0x200E             // Up-down cnt, timebase = SYSCLKOUT
void EPwmSetup()
//  InitEPwm1Gpio();
    InitEPwm();
        EPwm1Regs.TBSTS.all=0;
        EPwm1Regs.TBPHS.half.TBPHS=0;
        EPwm1Regs.TBCTR=0;
        EPwm1Regs.CMPCTL.all=0x50;        // Immediate mode for CMPA and CMPB
        EPwm1Regs.CMPA.half.CMPA =400;
        EPwm1Regs.CMPB=0;
        EPwm1Regs.AQCTLA.all=0x60;        // EPWMxA = 1 when CTR=CMPA and counter inc
                                                               // EPWMxA = 0 when CTR=CMPA and counter dec
        EPwm1Regs.AQCTLB.all=0;
        EPwm1Regs.AQSFRC.all=0;
        EPwm1Regs.AQCSFRC.all=0;
        EPwm1Regs.DBCTL.all=0xb;          // EPWMxB is inverted
        EPwm1Regs.DBRED=0;
        EPwm1Regs.DBFED=0;
        EPwm1Regs.TZSEL.all=0;
        EPwm1Regs.TZCTL.all=0;
        EPwm1Regs.TZEINT.all=0;
        EPwm1Regs.TZ标志寄存器.all=0;
        EPwm1Regs.TZCLR.all=0;
        EPwm1Regs.TZFRC.all=0;
        EPwm1Regs.ETSEL.all=0;            // Interrupt when TBCTR = 0x0000
        EPwm1Regs.ET标志寄存器.all=0;
        EPwm1Regs.ETCLR.all=0;
        EPwm1Regs.ETFRC.all=0;
        EPwm1Regs.PCCTL.all=0;
        EPwm1Regs.TBCTL.all=0x0010+TBCTLVAL;                        // Enable Timer
        EPwm1Regs.TBPRD=SP;
这个是输出PWM主程序
void EPwmSetup();
Uint16  i;
void main(void)
   InitSysCtrl();
   InitXintf16Gpio();
   DINT;
   InitPieCtrl();
   IER = 0x0000;
   IFR = 0x0000;
   InitPieVectTable();
   EALLOW;
    GpioCtrlRegs.GPAPUD.bit.GPIO18 = 0;    // Enable pull-up on GPIO18 驱动器方向控制信号
    GpioCtrlRegs.GPAPUD.bit.GPIO19 = 0;    // Enable pull-up on GPIO19  驱动器空转信号
    GpioDataRegs.GPASET.bit.GPIO18 = 1;    // Load output latch
    GpioCtrlRegs.GPAMUX2.bit.GPIO18 = 0;   // Configure GPI18 as IO
    GpioCtrlRegs.GPAMUX2.bit.GPIO19 = 0;   // Configure GPI19 as IO
    GpioCtrlRegs.GPADIR.bit.GPIO18 = 1;    // GPIO18 = output
        GpioCtrlRegs.GPADIR.bit.GPIO19 = 1;    // GPIO19 = output
    EDIS;
        EPwmSetup();
    for(; ;)
zhangmangui 发表于 2015-4-9 21:39 | 显示全部楼层
controlSUITE里面没有嘛     你先别接驱动器和电机   用示波器看看输出的波形是什么样子的
 楼主| 草上之风 发表于 2015-4-10 09:38 | 显示全部楼层
controlSUITE里面没有嘛     你先别接驱动器和电机   用示波器看看输出的波形是什么样子的 ...
谢谢回复,我用示波器看了输出三角波,我要的是方波啊。。不知道该改哪个寄存器。。
zhangmangui 发表于 2015-4-10 23:39 | 显示全部楼层
谢谢回复,我用示波器看了输出三角波,我要的是方波啊。。不知道该改哪个寄存器。。 ...
怎么会是三角波啊   数字口啊
负载有没有去掉   或者输出频率是不是过高
 楼主| 草上之风 发表于 2015-4-12 19:38 | 显示全部楼层
怎么会是三角波啊   数字口啊
负载有没有去掉   或者输出频率是不是过高 ...
谢谢回复,示波器上显示频率是50hz,我改了几次程序不过图像一点没变,有同学说可能是干扰,而且我板子只插上电,不开电源键就是那样的波形。。不知道怎么办。。。求指导
zhangmangui 发表于 2015-4-12 21:35 | 显示全部楼层
谢谢回复,示波器上显示频率是50hz,我改了几次程序不过图像一点没变,有同学说可能是干扰,而且我板子只 ...
不开电源就有那种波形?
是不是示波器的问题啊
快速回复 返回顶部 返回列表
