SOPC学习 https://bbs.21ic.com/?436058 [收藏] [复制] [RSS]
日志
VHDL学习之组合逻辑电路
已有 1078 次阅读2006-8-18 21:51 |个人分类:EDA基础学习|系统分类:EDA/PLD
第二章、组合逻辑电路
1、监视交通信号工作状态的逻辑电路
library ieee;
use ieee.std_logic_1164.all;
entity hld is
   port(r,a,g:in std_login;
        z:out std_logic);
end hld;
architecture rtl of hld is
begin
     process(r,a,g)
     variable conb:std_logic_vector(2 downto 0);
     begin
       comb:=r&a&g;
       case comb is
         when"000"=>z<='1';
         when"001"=>z<='0';
         when"010"=>z<='0';
         when"011"=>z<='1';
         when"100"=>z<='0';
         when"101"=>z<='1';
         when"110"=>z<='1';
         when others=>z<='1';
      end case;
    end process;
   end rtl;
2、8线---3线编码器的设计
library ieee;
entity bm8_3 is
       port(a:in std_logic_vector(7 downto 0);
            b:out std_logic_vector(2 downto 0));
end bm8_3;
architecture rtl ofbm8_3 is
begin
   process(a)
   begin
   case a is
   when"00000001"=>b<="000";
   when"00000010"=>b<="001";
   when"00000100"=>b<="010";
   when"00001000"=>b<="011";
   when"00010000"=>b<="100";
   when"00100000"=>b<="101";
   when"01000000"=>b<="110";
   when others=>b<="111";
   end case;
    end process;
end rtl;
3、8线---3线优先编码器的设计
library ieee;
entity yxbm8_3 is
   port(i:in std_logic_vector(7 downto 0);
        s:in std_logic;
        y:out std_logic_vector(2 cownto 0);
        ys,yex:out std_logic);
end yxbm8_3
architecture rtl of yxbm8_3 is
begin
  process(i,s)
  begin
      if s='1'then
      y<="111";
      ys<='1';
      ysx<='0';
    else
       if i(7)='0'then
          y<="001";
          ys<='1';
          ysx<='0';
     else
       if i(6)='0'then
          y<="001";
          ys<='1';
          ysx<='0';
      else
       if i(5)='0'then
          y<="010";
          ys<='1';
          ysx<='0';
       else
       if i(4)='0'then
          y<="011";
          ys<='1';
          ysx<='0';
       else
       if i(3)='0'then
          y<="100";
          ys<='1';
          ysx<='0';
       else
       if i(2)='0'then
          y<="101";
          ys<='1';
          ysx<='0';
       else
       if i(1)='0'then
          y<="110";
          ys<='1';
          ysx<='0';
       else
       if i(0)='0'then
          y<="111";
          ys<='1';
          ysx<='0';
       else
       if i='11111111'then
          y<="111";
          ys<='1';
          ysx<='0';
       end if;
      end if;
     end process;
   end rtl;
4、二---十进制编码器的设计
library ieee;
entity bmq is
     port(i:in std_logic_vector(8 downto 0);
          yLout std_logic_vctor(3 downto 0));
end bmq;
architecture rtl of bmq is
begin
process(i);
begin
        if i(8)='0'then
               y<="0110";
        elsif i(7)='0'then
               y<="0111";
        elsif i(6)='0'then
               y<="1000";
        elsif i(5)='0'then
               y<="1001";
        elsif i(4)='0'then
               y<="1010";
        elsif i(3)='0'then
               y<="1011";
        elsif i(2)='0'then
               y<="1100";
        elsif i(1)='0'then
               y<="1101";
        elsif i(0)='0'then
               y<="1110";
        elsif i='11111111'then
               y<="1111";
      end if;
     end process;
   end rtl;
5、译码器(3线---8线)的设计
library ieee;
entity ym3_8 is
   port(A0,A1,A2:in bit;
        s1,s2,s3:in bit;
        y0,y1,y2,y3,y4,y5,y6,y7:out bit);
end ym3_8;
architecture rtl of ym3_8 is
     signal s:bit;
     signal A:bit_vector(2 downto 0);
     signal y:bit_vector(7 downto 0);
begin
     process(A,s1,s2,s3)
     begin
       s<=s2 or s3;
      A<=A2&A1&A0;
         if s1='0'then
     y<="11111111"
    elsif s='1'then
    y<="11111111";
    else
  case A is
  when"000"=>y<="11111110";
  when"001"=>y<="11111101";
  when"010"=>y<="11111011";
  when"011"=>y<="11110111";
  when"100"=>y<="11101111";
  when"101"=>y<="11011111";
  when"110"=>y<="10111111";
  when others=>y<="01111111";
  end case;
  end if;
end process;
y0<=y(0);
y1<=y(1);
y2<=y(2);
y3<=y(3);
y4<=y(4);
y5<=y(5);
y6<=y(6);
y7<=y(7);
end rtl;
6、二---十进制译码器的设计
library ieee;
entity ym2_10 is
   port(a:in atd_logic_vector(3 downto 0);
        y:out atd_logic_vector(9 downto 0));
end ym2_10:
architecture rtl of ym2_10 is
bigin
    process(a)
    bigin
    case a is
   when"0000"=>y<="1111111110";
   when"0001"=>y<="1111111101";
   when"0010"=>y<="1111111011";
   when"0011"=>y<="1111110111";
   when"0100"=>y<="1111101111";
   when"0101"=>y<="1111011111";
   when"0110"=>y<="1110111111";
   when"0111"=>y<="1101111111";
   when"1000"=>y<="1011111111";
   when"1001"=>y<="0111111111";
   when pthers=>y<="11111111";
  end case;
 end process;
end rtl;
7、BCD七段显示译码器的设计
library ieee;
entity qdym is
        y:out atd_logic_vector(6 downto 0));
end qdym;
architecture rtl of qdym is
begin
  process(a)
  begin
     case a is
         when"0000"=>Y<="0111111";
         when"0001"=>Y<="0000110";
         when"0010"=>Y<="1011011";
         when"0011"=>Y<="1001111";
         when"0100"=>Y<="1100110";
         when"0101"=>Y<="1101101";
         when"0110"=>Y<="1111101";
         when"0111"=>Y<="0100111";
         when"1000"=>Y<="1111111";
         when"1001"=>Y<="1101111";
         when"1010"=>Y<="1110111";
         when"1011"=>Y<="1111100";
         when"1100"=>Y<="0111001";
         when"1101"=>Y<="1011110";
         when"1110"=>Y<="1111001";
         when OTHERS=>Y<="1110001";
        end case;
 end process;
end rtl;
8、代码转换
library ieee;
entity zhuanhuan is
    port(x0,x1,x2,x3:in std_logic;
         c:in std_logic;
         y0,y1,y2,y3:out std_logic);
end zhuanhuan;
architecture rtl of zhuanhuan is
begin
  y3<=x3;
  y2<=(x3 and(not x2))or((not x3)and x2);
  y1<=((not c)and((x3 and x2 and x1)or((not x3)and(not x2)andx1)or((not x3)and x2 and(not
x1))or(x3 and(out x2)and(out x1))))or(c and((x2 and(notx1))or((not x2)and x1)));
  y0<=((not c)and(((not x3)and(not x2)and(not x1)and x0)or((not x3)and(not x2)and(not x0)
and x1)or((notand(not x0)and(not x1)and x2)or((not x3)and x2 and x1 and x0)or(x3 and x2 and
(not x1)and x0)or((not x0)and x2 and x1 and x3)or((not x0)and(not x2)and(not x1)and x3)0r(x3
 and(not x2)and x1 and x0)))or(c and((x1 and(not x0))or((not x1)and x0)));
end rtl;
9、四选一数据选择器的设计
library ieee;
entity cxy is
    port(d0,d1,d2,d3,a0,a1,s:in std_logic;
         y:out std_logic);
end cxy;
architecture rtl of cxy is
signal a:std_logic_vector(1 downto 0);
begin
  process(a0,a1)
  begin
     a<=a1&a0;
     if(s='0')then
          case a is
            when"00"=>y<=d0;
            when"01"=>y<=d1;
            when"10"=>y<=d2;
            when others=>y<=d3;
      end case;
   end if;
 end process;
end rtl;
10、八选一数据选择器的设计
library ieee;
entity 1334 is
       port(d0,d1,d2,d3,d4,d5,d6,d7,a0,a1,a2:in std_logic;
         y:out std_logic);
end 1334;
architecture rtl of 1334 is
signal a:std_logic_vector(2 downto 0);
begin
    process(a0,a1,a2)
     begin
       a<=a2&a1&a0;
     case a is
         when"000"=>y<=d0;
         when"001"=>y<=d1;
         when"010"=>y<=d2;
         when"011"=>y<=d3;
         when"100"=>y<=d4;
         when"101"=>y<=d5;
         when"110"=>y<=d6;
         when others=>y<=d7;
            end case;
 end process;
end rtl;
11、4位全加器的设计
   (1)1位全加器
library ieee;
use ieee.std_logic_unsigned.all;
entity qjq is
    port(a,b:in std_logic;
         ci:in std_logic;
         co:out std_logic;
         s:out std_logic);
end qjq;
architecture rtl of qjq is
begin
process(a,b,ci);
begin
   if(a='0'and b='0'and ci='0')then
      s<='0';
      so<='0';
  elsif(a='1'and b='0'and ci='0')then
      s<='1';
      so<='0';
  elsif(a='0'and b='1'and ci='0')then
      s<='1';
      so<='0';
  elsif(a='1'and b='1'and ci='0')then
      s<='0';
      so<='1';
  elsif(a='0'and b='0'and ci='1')then
      s<='1';
      so<='0';
     elsif(a='0'and b='1'and ci='1')then
      s<='0';
      so<='1';
  elsif(a='1'and b='0'and ci='1')then
      s<='0';
      so<='1';
     else
    s<='1';
    co<='1';
  end if;
 end process;
end rtl;
12、8位加法器的设计
程序一:
library ieee;
entity adder4b is
        port (cin:in std_logic;
              a,b:in std_logic_vector(3 downto 0);
              s:out std_logic_vector(3 downto 0);
             cout:out std_logic);
end adder4b;
architecture behav of adder4b is
       signal sint:std_logic_vector(4 downto 0);
       signal aa:std_logic_vector(4 downto 0);
begin
   aa<='0'&a(3 downto 0);
   bb<='0'&b(3 downto 0);
   sint<=aa+bb+cin;
   s(3 downto 0)<=sint(3 downto 0);
  cout<=sint(4)
end behav;
程序二:
library ieee;
entity adder8b is
              a,b:in std_logic_vector(7 downto 0);
              s:out std_logic_vector(7 downto 0);
end adder8b;
architecture behav of adder8b is
component adder4b
end component;
      signal carry_out:std_logic;
      begin
        u1:adder4b  port  map(cin=>cin,a=>a(3 downto 0),b=>b(3 downto 0),s=>(3 downto 0),
        cout=>carry_out);
        u2:adder4b  port  map(cin=>carry_out,a=>a(7 downto 4),b=>b(7 downto 4),s=>s(7 downto 4),cout=>cout);
end struc;
13、多位数值比较器的设计
library ieee;
entity cc14585 is
        port(a,b:in std_logic_vector(3 downto 0);
              cc14585y1,y2,y3:out std_logic);
end cc14585;
architecture rtl of cc14585 is
begin
process(a,b)
   begin
     if(a>b)then
        y1<='1';
        y2<='0';
        y3<='0';
     elsif(a=b)then
        y1<='0';
        y2<='1';
        y3<='0';
     else
        y1<='0';
        y2<='0';
        y3<='1';
          end if;
 end process;
end rtl;
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
