SOPC学习 https://bbs.21ic.com/?436058 [收藏] [复制] [RSS]
日志
VHDL学习之时序逻辑电路
已有 1659 次阅读2006-8-18 21:54 |个人分类:EDA基础学习|系统分类:EDA/PLD
 第四章节    时序逻辑电路
4.1    寄存器的设计
源程序:
library ieee;
usr ieee.std_logic_1164.all;
entity jcq is
   port(clk:in std_logic;
      r:in std_logic;
      d:in std_logic_vector(3 dowmto 0);
      q:out std_logic_vector(3 downto 0);
end jcq;
architecture rtl lf jcq is
signal q_temp:std_logic_vecter(3 dowmto 0);
begin
process(clk,r)
begin
  if(r='1')then
  q_temp<="0000";
  elsif(clk'event and clk='1')then
     q_temp<=d;
   end if;
q<=q_temp;
end process;
end rtl;
4.2  双向移位寄存器的设计
源程序:
library ieee;
use ieee.std_logic_1164.all;
package shift_type is
subtype std4 is std_logic_vector(3 downto 0);
end shift_type;
library ieee;
use work.shift_type.all;
entiyt ywjcq is
   port(din:in std4;
       clk,load,left_right:in std_logic;
       dout:inout std4);
end ywjcq;
architecture rtl lf ywjcq is
signal shift_val:std4;
begin
   nxt:process(load,left_right,din,dout)
   begin
      if load='1'then
         shift_val<=din;
      elsif left_right='0'then
         shift_val(2 downto 0)<=dout(3 downto 1);
         shift_val(3)<='0';
      else
         shift_val(3 downto 1)<=dout(2 downto 0);
         shift_val(0)<='0';
      end if
end process nxt;
current:process(clk)
begin
      if clk'event and clk='1' then
          dout<=shift_val;
        end if;
end process current;
end rtl;
4.3,4位同步二进制计数器的设计
源程序 ;
library ieee;
use ieee.std_logic_unsigned.all;
entity b19 is
       port(cp,r,ld,ep,et:in std_logic;
           d:in std_logic_vector(3 downto 0);
            c:out std_logic;
 end b19;
architecture b19_arc of b19 is
begin
      process(cp,r,ld,ep)
      variable tmp:std_logic_vector(3 downto 0);
     begin
           if r='0' then
              tmp:="0000";
           elsif vp'event and cp='1' then
                if ld='0' then
                     tmp:=d;
                elsif ep='1' and et='1' then
                      if tmp="1111" then
                           tmp:="0000";
                           c<='0';
                     end if;
                end if;
           end if;
          q<=tmp;
     edn process;
end b19_arc;
4.4。单时钟同步十六进制加/减计数器的设计
源程序 :
library ieee;
entity ls191 is
    prot(cp,s,ld,ud,d0,d1,d2,d3:in std_logic;
          c:out std_logic;
end ls191;
architecture rtl of ls191 is
signal y,d:std_logic_vector(3 downto 0);
begin
process(cp,s,ld ud)
begin
   d<=d3&d2&d1&d0;
   if(ld='0')then
     y<=d;
     c<='0';
    elsitf(cp'event and cp='1')then
      if s='0' then
        if ud='0' then
          if(y="1111")then
            y<="0000";
            c<='1';
          else
            y<=y+1;
            c<='0';
          end if;
         elsif ud='1' then
          if(y="0000")then
            y<="1111";
             c<='1';
          else
            y<=y-1;
            c<='0';
          end if;
         elsif s='1'then
           y<=y;
         end if;
       end if;
   end process;
q<=y;
end rtl;
4.5 双时钟同步十六进制加/减计数器的设计
源程序:
library ieee;
entity b21add is
    port(clk1,ld,r:in std_logic;
         co:out std_logic;
        q:out std_logic_vector(3 downto 0));
end b21add;
 architecture b21_arc of b21add is
begin
    process(clk1,ld,r)
    variable tmpLstd_logic_vector(3 downto 0);
bigin
     if r='1' then
     tmp:="0000";
    co<='0';
      elsifld='0'then
     tmp:=d;
      elsif clk1'event and clk1='1'then
        if tmp="1111"then
       tmp:="0000";
       co<='1';
      else
      tmp:=tmp+1;
       co<='0';
       end if;
     q<=tmp;
   end process;
end b21_arc;
B21SUB.VHD
library ieee;
entity b21sub is
         co:out std_logic;
end b21sub;
begin
    process(clk1,ld,r)
bigin
     if r='1' then
     tmp:="1111";
    co<='0';
      elsifld='0'then
     tmp:=d;
        if tmp="0000"then
       tmp:="1111";
       co<='1';
      else
      tmp:=tmp+1;
       co<='0';
       end if;
       end if;
     q<=tmp;
   end process;
end b21_arc;
B21B.VHD
library ieee;
end b21b is;
       port(sel:in std_logic;
            d1,d0:in std_logic;
            q:out std_logic);
end b21b;
architecture b21_arc of b21b is
begin
        q<=d1 when sel='1'else
            d0;
end b21b_arc;
BUS21A.VHD
library ieee;
entity bUS21a is
          d1,d0:in std_logic_vector(3 downto 0);
         co:out std_logic;
end bus21a;
architecture b21_arc of bus21a is
begin
            d0;
end b21b_arc;
4.6 同步十进制加法计数器的设计
源程序:
library ieee;
entity 1s160 is
     port(cp,rd,ld,ep,et,d0,d1,d2,d3:in std_logic;
           c:out std_logic;
           y:out std_logic_vector(3 downto 0));
end 1s160;
architecture rtl of 1s160 is
     signal d,q:std_logic_vector(3 downto 0);
begin
process(cp,rd,ld,ep,et)
begin
    d<=d3&d2&d1&d0;
    if rd='0'then
       q<="0000";
      c<='0';
      elsif(cp'event and cp='1')then
       if rd='0'then
       q<=d;
      elsif(ep='0'and cp='1')then
        q<=q;
        elsif(et='0')then
        q<=q;
        c<='0';
        elsif(ep='1'and cp='1')then
        elsif(q=9)then;
        q<="0000";
        c<='1';
        else
       q<=q+1;
      c<='0';
     end if;
    end if;
  end if;
 end process;
 y<=q;
 end rtl;
4.7 单时钟,同步十进制可逆计数器的设计
源程序:
library ieee;
entity 1s190 is
     port(cp,s,ld,ud,d0,d1,d2,d3:in std_logic;
           c:out std_logic;
end 1s190;
architecture rtl of 1s190 is
begin
process(cp,s,ld,ud)
begin
    d<=d3&d2&d1&d0;
    if(ld='0')then
       y<=d;
      c<='0';
     if s='0'then
    if ud='0'then
   if(y="1001")then
      y<="0000";
      c<='1';
    else
    y<=y+1;
    c<='0';
    end if;
    elsif ud='1'then
    if(y='0000')then
     y<="1001";
      c<='1';
    else
     y<=y-1;
     c<='0';
    end if;
   end if;
  elsif s='1'then
  y<=y;
  end if;
   end if;
   end process;
 q<=y;
end rtl;
4.8 异步二进制加法计数器的设计
源程序:
library ieee;
entity 1s293 is
     port(cp,rd,:in std_logic;
end 1s293;
architecture rtl of 1s293 is
begin
process(cp)
begin
   if(cp'event and cp='0')then
    if rd='0'then
     y<="0000";
     else
      y<=y+1;
      end if;
    end if;
   end if;
   end process;
  q<=y;
end rtl;
4.9 同步100进制计数器的设计
源程序:
library ieee;
use ieee.std_logic_arith.all;
entity h27 is
         qa:out std_logic_vector(3 downto 0);
         qb:out std_logic_vector(3 downto 0));
end h27;
 architecture rtl of h27 is
begin
   signal qan:std_logic_vector(3 downto 0);
   signal qbn:std_logic_vector(3 downto 0);
    signal cin:std_logic;
bigin
 process(clk)
bigin
   if clk'event and clk='1'then
     if qan=9 then
       qan<="0000";cin<='1';
   else
      qan<=qan+1;cin<='0';
      end if;
    end if;
   end process;
  ptovrss(clk,cin)
bigin
        if cin='1'then
          if qbn=9 then
            qbn<="0000";
  else
      qbn<=qbn+1;
        end if;
    end if;
   end if;
   end process;
  qa<=qan;qb<=qbn;
end rtl;
4.10 同步29进制计数器的设计
源程序:
library ieee;
entity h28 is
port(cp:in std_logic;
         q:out std_logic_vector(7 downto 0);
        c:out std_logic);
end h28;
 architecture w of h28 is
   signal qa:std_logic_vector(3 downto 0);
   signal qb:std_logic_vector(3 downto 0);
bigin
   q(7 downto 4)>=qb;
   q(7 downto 0)>=qb;
    ptovrss(cp)
begin
  if cp'event and cp='1'then
     if(qa=9)or((qa=8 and qb=2)then
       qa<="0000";cin<='0';
       elsif qa=8 then cin<='1';qa<=qa+1;
       else qa<=qa+1;cin<='0';
       end if;
   end if;
   end process;
   process(cin,cp)
begin
     if(qa=8 and qb=2)then
       qa<="0000";cin<='1';
    else c<='0';
   end if;
  if cin='1'then
    qb<=qb+1;
     end if;
   end if;
   end process;
end w;
4.11 顺序脉冲发生器
源程序:
library ieee;
entity sxmc is
port(cp,rd:in std_logic;
       qo,q1,q2:out std_logic);
end sxmc;
 architecture rtl of sxmc is
   signal y,x:std_logic_vector(2 downto 0);
begin
    process(cp,rd)
begin
     if(rd='1')then
      y<="0000";
      x<="001";
else
      y<=x;
      x>=x(1 downto 0)&x(2);
       end if;
   end if;
   end process;
    q0<=y(0);
    q1<=y(1);
    q2<=y(2);
end rtl;
4.12 序列信号发生器
源程序:
library ieee;
entity xlfs is
port(reg,clk:in std_logic;
      y:out std_logic);
end xlfs;
 architecture rtl of xlfs is
   signal reg:std_logic_vector(7 downto 0);
begin
    process(clk,res)
begin
     if res='1' then
      y<="0";
      reg<="11101010";
else
      y<=reg(7);
      reg<=reg(6 downto 0)&x(0);
       end if;
   end if;
   end process;
end rtl;
4.13用状态机方法设计十三进制计数器
源程序:
library ieee;
entity h31 is
        op:out std_logic);
end h31;
 architecture rtl of h31 is
 type state is(s0,s1,s2,s3,s4,s5,s6,s7,s8,s9,s10,s11,s12);
 signal presentstate:state;
 signal nextstate:state;
 signal qn:std_logic_vector(3 downto 0);
begin
   switchtonextstate:process(cp)
begin
     presentstate<=nextstate;
 end if;
end process switchtonextstate;
changestatemode:pricess(presentstate)
begin
    case prisentstate is
          when s0=>nextstate<=s1;
             qn<="0001"
             op<='0';
          when s1=>nextstate<=s2;
             qn<="0010"
             op<='0';
          when s2=>nextstate<=s3;
             qn<="0011"
             op<='0';
          when s3=>nextstate<=s4;
             qn<="0100"
             op<='0';
          when s4=>nextstate<=s5;
             qn<="0101"
             op<='0';
          when s5=>nextstate<=s6;
             qn<="0110"
             op<='0';
          when s6=>nextstate<=s7;
             qn<="0111"
             op<='0';
          when s7=>nextstate<=s8;
             qn<="1000"
             op<='0';
          when s8=>nextstate<=s9;
             qn<="1001"
             op<='0';
          when s9=>nextstate<=s10;
             qn<="1010"
             op<='0';
          when s10=>nextstate<=s11;
             qn<="1011"
             op<='0';
          when s11=>nextstate<=s12;
             qn<="1100"
             op<='0';
          when s12=>nextstate<=s0;
             qn<="0000"
             op<='1';
       end case
   end process changestatemode;
   q<=qn;
end rtl;
4.14 串行数据检测器
源程序:
library ieee;
entity h32 is
port(x,cp:in std_logic;
         y:out std_logic);
end h32;
 architecture w of h32 is
 type state is(s0,s1,s2,s3);
 signal p:state;
 signal n:state;
begin
    s:process(cp)
  begin
      p<=n;
   end if;
   end process:s
   c:process(x,p)
begin
   case p is
       when s0=>if x<='1'then
           n<=s1;
        else
           n<=s0;
        end if;
        y<='0';
       when s1=>if x<='1'then
           n<=s2;
        else
           n<=s0;
        end if;
        y<='0';
       when s2=>if x<='1'then
           n<=s3;
           y<='0';
        else
           n<=s0;
           y<='0';
        end if;
       when s3=>if x<='1'then
           n<=s3;y<='1';
        else
           n<=s0;
           y<='0';
        end if;
       when others=>null;
     end case;
    end pricess c;
end w;
4.15 自动饮料销售机的逻辑电路
源程序:
library ieee;
entity h33 is
port(x,:in std_logic_vector(1 downto 0);
         cp:in std_logic;
         y,z:out std_logic);
end h33;
 architecture w of h33 is
 type state is(s0,s1,s2);
 signal p:state;
 signal n:state;
begin
    process(cp)
  begin
      p<=n;
   end if;
   end process;
   c:process(x,p)
begin
   case p is
       when s0=>if x<='00'then
           n<=s0;y<='0';z<='0';
         elsif x="01" then
           n<=s1;y<='0';z<='0';
         elsif x="10" then
            n<=s2;y<='0';z<='0';
         else if;
       when s1=>if x<='00'then
         elsif x="01" then
         elsif x="10" then
            n<=s2;y<='1';z<='0';
         else if;
       when s2=>if x<='00'then
         elsif x="01" then
           n<=s1;y<='1';z<='0';
         elsif x="10" then
            n<=s2;y<='';z<='1';
         else if;
     when others=>n<=s0;
      end case;
    end pricess;
end w;
4.16 能自启动的七进制计数器
源程序:
library ieee;
entity h34 is
      q:out std_logic_vector(2 downto 0);
           y:out std_logic);
end h34;
 architecture w of h34 is
 type state is array(2 downto 0) of std_logic;
       constant s0:state:="001";
       constant s1:state:="100";
       constant s2:state:="010";
       constant s3:state:="101";
       constant s4:state:="110";
       constant s5:state:="111";
       constant s6:state:="011";
   signal p:state;
   signal n:state;
begin
    s:process(cp)
  begin
      p<=n;
      end if;
     end process(p)
begin
    case p is
        when s0=>n=<=s1;y<='0';q<="100";
        when s1=>n=<=s2;y<='0';q<="010";
        when s2=>n=<=s3;y<='0';q<="101";
        when s3=>n=<=s4;y<='0';q<="110";
        when s4=>n=<=s5;y<='0';q<="100";
        when s5=>n=<=s6;y<='0';q<="111";
        when s6=>n=<=s0;y<='1';q<="001";
        when others=>n=<=s0;y<='0';
      end case;
    end pricess m;
end w;
4.17 能自启动的3位环形计数器
源程序:
library ieee;
entity h35 is
port(q:out std_logic_vector(2 downto 0);
         cp:in std_logic);
end h35;
 architecture w of h35 is
 signal p:state;
 signal n:state;
begin
    s:process(cp)
  begin
      p<=n;
   end if;
   end process s;
   c:process(p)
begin
   case p is
    when s0=>n=<=s1;q<="010";
    when s1=>n=<=s2;q<="001";
    when s2=>n=<=s0;q<="100";
    when others=>n=<=s1;
      end case;
    end pricess;
end w;
4.18 8421编码的异步十进制减法计数器
源程序:
library ieee;
entity h36 is
end h36;
 architecture w of h36 is
 type state is(s0,s1,s2,s3,s4,s5,s6,s7,s8,s9);
 signal p:state;
 signal n:state;
  begin
    process(cp)
  begin
      p<=n;
   end if;
   end process;
       process(p)
begin
   case p is
        when s0=>n=<=s1;
                 qn<="1001";
        when s1=>n=<=s2;
                 qn<="1000";
        when s2>n=<=s3;
                 qn<="0111";
        when s3=>n=<=s4;
                 qn<="0110";
        when s4=>n=<=s5;
                 qn<="0101";
        when s5=>n=<=s6;
                 qn<="0100";
        when s6=>n=<=s7;
                 qn<="0011";
        when s7=>n=<=s8;
                 qn<="0010";
        when s8=>n=<=s9;
                 qn<="0001";
        when s9=>n=<=s0;
                 qn<="0000";
        when other=>n=<=s0;
     end case;
    end pricess;
   q<=qn;
end w;
路过
鸡蛋
鲜花
握手
雷人
发表评论 评论 (2 个评论)
回复 xiaoqiang 2009-7-15 07:28
有关于时序的程序吗
有关于时序的程序吗
