#include <reg52.h>
#include <intrins.h>
#ifndef uchar
#define uchar unsigned char
#endif
#ifndef uint
#define uint unsigned int
#endif
#define DATA P1
sbit RS=P3^7;
sbit RW=P3^6;
sbit E =P3^5;
sbit BS=P1^7;
uchar *h="hello everyone ! \n welcome! " ;
void busy() //???????
do
DATA=0xFF;
RS=0;
RW=1;
E=0;
_nop_();
E=1;
}while(BS);
void command(uchar dat)
DATA=dat;
RS=0;
RW=0;
E=0;
busy();
E=1;
void write(uchar dat)
DATA=dat;
RS=1;
RW=0;
E=0;
busy();
E=1;
void clear(uchar dat) //??? 1 ??
command(dat);
void back(uchar a) //????
a;
command(0x02);
void mov(uchar id,uchar s) //id ?????????1?? 0 ??
{ //s???????????1? 0 ?
command(0x04|(id<<1)|s);
void run(uchar d,uchar c,uchar b) //??????
{ //d ?????? 1 ? 2 ?
command(0x08|(d<<2)|(c<<1)|b); //c ?????? 1 ? 2 ?
//b ?????? 1 ? 2 ?
void shift(uchar sc,uchar rl) //sc 1 ?????? 0 ??????
{ //rl 1 ?? 0 ??
command(0x10|(sc<<3)|(rl<<2));
void function(uchar dl,uchar n,uchar f) //dl 1 ???? 0 ????
//??dl 1???? 0 ???? ????????
{ //n 1 ???? 0 ????
command(0x20|(dl<<4)|(n<<3)|(f<<2)); //f 1 5*10?? 0 5*7 ??
void charaddr(uchar agg) //????????
command(0x40|agg);
void dataaddr(uchar add) //?????????
command(add|0x80);
void text(uchar dat) //?????
write(dat);
void delay(uint t)
uint i;
while(!((t--)==0x0))
for(i=0;i<0x1fff;i++);
void print(uchar row ,char *p) //???? row?????? *p??????
uchar a=0x0,i=1;
dataaddr(row);
while(i--)
while((*p)!='\0')
text(*p++);
delay(2);
if(((*p)=='\n'))
back(2);
dataaddr(0x50);
p=&h[0];
dataaddr(0x10);
/*main.c**************************************/
void initial()
clear(1);
function(1,1,0);
mov(1,1);
shift(1,1);
run(1,0,0);
clear(0);
void main()
uchar s;
s=10;
initial();
do
clear(1);
back(2);
print(0x10,h);
delay(5);
_nop_();
delay(0x00);
clear(1);
back(2);
print(0x10,"I can ! belive me ! ");
delay(5);
_nop_();
delay(0x00);
while(s--);
clear(1);
while(1);
