182006的笔记 https://bbs.21ic.com/?447560 [收藏] [复制] [RSS]
日志
1602液晶多列显示C
已有 622 次阅读2007-11-14 13:52 |系统分类:单片机| aa
#include <reg52.h>
#include <intrins.h>
#ifndef uchar
#define uchar unsigned char
#endif
#ifndef uint
#define uint  unsigned int
#endif
#define DATA  P1
sbit RS=P3^7;
sbit RW=P3^6;
sbit E =P3^5;
sbit BS=P1^7;
void busy()        //???????
 do
  DATA=0xFF;
  RS=0;
  RW=1;
  E=0;
  _nop_();
  E=1;
 }while(BS);
void command(uchar dat)
 DATA=dat;
 RS=0;
 RW=0;
 E=0;
 busy();
 E=1;
void write(uchar dat)
 DATA=dat;
 RS=1;
 RW=0;
 E=0;
 busy();
 E=1;
void clear(uchar dat)     //???  1 ??
 command(dat);
void back(uchar a)        //????
 a;
 command(0x02);
void mov(uchar id,uchar s)                      //id ?????????1?? 0 ??
{                                               //s???????????1? 0 ?
 command(0x04|(id<<1)|s);
void run(uchar d,uchar c,uchar b)               //??????
{                                               //d  ??????   1 ?  2 ?
 command(0x08|(d<<2)|(c<<1)|b);                 //c  ??????   1 ?  2 ?
                                                //b  ??????   1 ?  2 ?
void shift(uchar sc,uchar rl)                   //sc 1 ?????? 0 ??????
{                                               //rl 1 ??         0 ??
 command(0x10|(sc<<3)|(rl<<2));
void function(uchar dl,uchar n,uchar f)          //dl 1 ????     0 ????
                                                 //??dl 1????  0  ???? ????????
{                                                //n  1 ????     0 ????
 command(0x20|(dl<<4)|(n<<3)|(f<<2));            //f  1 5*10??     0 5*7 ??
void charaddr(uchar agg)                         //????????
 command(0x40|agg);
void dataaddr(uchar add)                         //?????????
 command(add|0x80);
void text(uchar dat)      //?????
 write(dat);
void delay(uint t)
 uint i;
 while(!((t--)==0x0))
   for(i=0;i<0xffff;i++);
void print(uchar row ,char *p)   //????  row??????  *p??????
 uchar a=0x0;
 dataaddr(row);
 while((*p)!='\0')
  text(*p++);
  a++;
  if(((a+row)>=16)||((*p)=='\n'))
  {dataaddr(0x40);a=0;}
/*main.c**************************************/
void initial()
 clear(1);
 clear(1);
 clear(1);
 function(1,1,0);
 run(1,0,1);
 clear(0);
void main()
 uchar s;
 s=1;
 initial();
 do
 clear(1);
 back(2);
 print(0x00,"hello everyone !\n   welcome!");
 delay(1);
 _nop_();
 delay(0x00);
 clear(1);
 clear(1);
 clear(1);
 back(2);
 print(0x00,"    I can !    \n  belive me!");
 delay(1);
 _nop_();
 delay(0x00);
 while(s--);
 while(1);
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
