afei9527的笔记 https://bbs.21ic.com/?576826 [收藏] [复制] [RSS]
日志
驱动_lcd1602
已有 640 次阅读2011-12-28 04:19 |个人分类:51单片机|系统分类:单片机| 51单片机
lcd1602
#include "reg51.h"
#define uchar unsigned char
#define port P3
sbit rs=P2^0;
sbit rw=P2^1;
sbit e=P2^2;
  ***00000  5*7  -> 0xff
  *****0** /5*8     0x40
  *****0**    0x40  ----> I
  *****0**    0x40  ---->
  *****0**    0x40
  *****0**    0x40
  ***00000    0x1f
  添加自己的自定义字符
code uchar ziku[]=
0x04,0x05,0x06,0x07,0x13,0x16,0X15,0x0C,
0xff,0xff,0x55,0xff,0x55,0xff,0xff,0xff
      函数声明区
uchar lcd_readcom(void);
void  check_busy(void);
void  lcd_writecom(uchar dat);
uchar lcd_readdat(void);
void  lcd_writedat(uchar dat);
void  lcd_gets(char *dat);
void  lcd_xy(uchar x,uchar y);
void  lcd_init(void);
   读取lcd1602状态
  uchar temp;
  e=0;
  port=0xff;
  rs=0;
  rw=1;
  e=1;
  temp=port;
  e=0;
  return temp;
   检测 lcd 是否忙碌   阿飞天天忙绿
   uchar temp;
   do{
   temp=lcd_readcom();
     }while((temp&0x80)==0x80);
      向lcd里写命令
check_busy();
 e=0;
 rs=0;
 rw=0;
 e=1;
 port=dat;
 e=0;
   读取lcd对应地址数据
  uchar temp;
  check_busy();
  e=0;
  port=0xff;
  rs=1;
  rw=1;
  e=1;
  temp=port;
  e=0;
  return temp;
       向lcd里写数据
check_busy();
 e=0;
 rs=1;
 rw=0;
 e=1;
 port=dat;
 e=0;
     向lcd写字符串
 while(*dat!=0)
 lcd_writedat(*dat);
 dat++;
      确定要写的位子即x y 坐标
 switch(y)
  case 0:lcd_writecom(0x80+x);break;
  case 1:lcd_writecom(0xc0+x);break;
 单行显示才有5*10  其他5*8 MODE=1 5*8  MODE=0 5*10
add_custom_word(uchar *dat,uchar len,uchar mode)
  uchar n,m;
  for(n=0;n<len;n++)
  if(mode)
   lcd_writecom(0x40+8*n);
    for(m=0;m<8;m++)
    lcd_writedat(*dat);
     dat++;
   else
    lcd_writecom(0x40+10*n);
    for(m=0;m<10;m++)
    lcd_writedat(*dat);
     dat++;
   初始化lcd
void lcd_init()
 lcd_writecom(0x01) ;//清屏
 lcd_writecom(0x03) ;
 lcd_writecom(0x3c) ;
 lcd_writecom(0x40) ;
 lcd_writecom(0x0c) ;
 add_custom_word(ziku,2,1); //初始化自定义字符
   主程序 实现显示
main()
 lcd_init();
 lcd_xy(0,0);
 lcd_gets("  I LOVE YOU");
 lcd_xy(0,1);
 lcd_gets("afei time:12:00");
 lcd_xy(0,0);
 lcd_writedat(0);
 lcd_xy(15,0);
 lcd_writedat(1);
  while(1);
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
