afei9527的笔记 https://bbs.21ic.com/?576826 [收藏] [复制] [RSS]
日志
驱动lcd_t6963_可配置屏大小_io模拟时序
已有 783 次阅读2011-12-28 05:01 |个人分类:51单片机|系统分类:单片机| 51单片机
//屏大小配置
#define lcd_x_size  240
#define lcd_y_size  128
#define lcdxdev8   (lcd_x_size/8)
#include"reg51.h"
#define uchar unsigned  char
#define uint unsigned short
#define port P3
sbit cd=P2^0;
sbit rd=P2^1;
sbit wr=P2^2;
sbit ce=P2^3;
void lcd_writecom_two(uchar onedat,uchar twodat,uchar com);
void lcd_writedat_onebyte(uchar onedat,uchar com);
uchar lcd_readdat_onebyte(uchar com);
void lcd_writedat_nbyte(uchar *dat,uchar len);
void lcd_readdat_nbyte(uchar *dat ,uchar len);
void clear_point(uchar x,uchar y);
void sel_point(uchar x,uchar y);
void sel_rmiddling(uchar x,uchar y);
void clr_rmiddling(uchar x,uchar y);
void sel_rbig(uchar x,uchar y);
void clr_rbig(uchar x,uchar y);
void graph_mode_writeword(uchar x,uchar y,uchar *dat);
void graph_mode_write_letter(uchar x,uchar y,uchar *dat);
void rhorizontal(uchar x0,uchar x1,uchar y);
void erect(uchar y0,uchar y1,uchar x);
void Draw_line(uchar x0,uchar y0,uchar x1,uchar y1);
void draw_circle(int x, int y, int r);
void lcd_init();
         驱动名:T6963驱动 (液晶)
   设计者:阿飞
    修正:全面优化 画点 划线 数据处理等(采用读修改些方式)
   版本: v4
       读取lcd状态
#include "lcd.h"
uchar lcd_readcom()
  uchar temp;
  port=0xff;
  cd=1;
  ce=0;
  rd=0;
  wr=1;
  temp=port;
  rd=1;
  return temp;
   判断指令/数据读写忙碌状态
void check_busy()
 uchar temp;
 do{
   temp=lcd_readcom();
   }while((temp&0x03)!=0x03);
   判断数据自动写忙碌状态
void check_auto_write_busy()
 uchar temp;
 do{
   temp=lcd_readcom();
   }while((temp&0x08)!=0x08);
   判断数据自动读忙碌状态
void check_auto_read_busy()
 uchar temp;
 do{
   temp=lcd_readcom();
   }while((temp&0x04)!=0x04);
       向lcd写命令
void lcd_writecom(uchar dat)
check_busy();
 cd=1;
 ce=0;
 port=dat;
 wr=0;
 rd=1;
 wr=1;
        向lcd写数据
void lcd_writedat(uchar dat)
check_busy();
 port=0xff;
 cd=0;
 ce=0;
 wr=0;
 rd=1;
 port=dat;
 wr=1;
     从lcd读数据
uchar lcd_readdat()
  uchar temp;
   cd=0;
  port=0xff;
  wr=1;
  ce=0;
  rd=0;
  temp=port;
  rd=1;
  cd=1;
  return temp;
  发出命令控制 参数 低onedat  高twodat 命令com
 lcd_writedat(onedat);
 lcd_writedat(twodat);
 lcd_writecom(com);
      一次写一个数据    对应地址指针位置
 lcd_writecom(com);
      一次读一个数据   对应地址指针位置
 uchar dat;
 lcd_writecom(com);
 dat=lcd_readdat();
 return dat;
      一次写n个数据    对应地址指针位置
   lcd_writecom(0xb0);
  check_auto_write_busy();
   while(len)
     lcd_writedat(*dat);
  dat++;
     len--;
   lcd_writecom(0xb2);
       一次读n个数据   对应地址指针位置
   lcd_writecom(0xb1);
   check_auto_read_busy();
    while(len)
    *dat=lcd_readdat();
    dat++;
     len--;
   lcd_writecom(0xb2);
 清除一个点坐标 X,Y  左上角第一个点为0,0
 uint addr;
 uchar temp1,temp2;
 addr=y*lcdxdev8+(x>>3);//32+8
 temp1=addr;//&0x00ff;
 temp2=addr>>8;
 lcd_writecom_two(temp1,temp2,0x24);
 lcd_writecom(0xf7-(x&0x07));
 点亮一个点 坐标 X,Y  左上角第一个点为0,0
 uint addr;
 uchar temp1,temp2;
 temp2=addr>>8;
 lcd_writecom(0xff-(x&0x07));
  画中等大小的点 4*4(用画点方法   效率低)
/*sel_middling(uchar x,uchar y)
  uint addr;
  uchar temp1,temp2,n;
 addr=y*lcdxdev8*4+(x>>1);//x/8*4;
 for(n=0;n<4;n++)
  temp1=addr%256;
  temp2=addr>>8;
  if(x%2)
  lcd_writecom(0xfb);
  lcd_writecom(0xfa);
  lcd_writecom(0xf9);
  lcd_writecom(0xf8);
  else
  lcd_writecom(0xff);
  lcd_writecom(0xfe);
  lcd_writecom(0xfd);
  lcd_writecom(0xfc);
  addr+=40;
  画中等大小的点 4*4(用读修改写   效率高)
  uint addr;
  uchar temp1,temp2,n,dat;
 addr=y*lcdxdev8*4+(x>>1);//x/8*4;//128+32
 for(n=0;n<4;n++)
  temp1=addr;//&0x0ff;
  temp2=addr>>8;
  if(x&0x01)//x%2
  dat=(lcd_readdat_onebyte(0xc5))|0x0f;
  lcd_writedat_onebyte(dat,0xc4);
  else
  dat=(lcd_readdat_onebyte(0xc5))|0xf0;
  addr+=lcdxdev8;
  清楚中等大小的点 4*4(用清点方式   效率底)
/*clr_middling(uchar x,uchar y)
  uint addr;
 for(n=0;n<4;n++)
  temp1=addr%256;
  temp2=addr>>8;
  if(x%2)
  lcd_writecom(0xf3);
  lcd_writecom(0xf2);
  lcd_writecom(0xf1);
  lcd_writecom(0xf0);
  else
  lcd_writecom(0xf7);
  lcd_writecom(0xf6);
  lcd_writecom(0xf5);
  lcd_writecom(0xf4);
  addr+=lcdxdev8;
  清楚中等大小的点 4*4(用读修改写   效率高)
  uint addr;
 for(n=0;n<4;n++)
  temp1=addr;//&0xff;
  temp2=addr>>8;
  if(x&0x01)
  dat=(lcd_readdat_onebyte(0xc5))&0xf0;
  else
  dat=(lcd_readdat_onebyte(0xc5))&0x0f;
  addr+=lcdxdev8;
      画8*8的大点(用画点方式  速度慢)
/*void sel_big(uchar x,uchar y)
  uint addr;
 addr=lcdxdev8*8+(x);//x/8*4;y*320=y*(256+64)=(y<<8)+(y<<6)
 for(n=0;n<8;n++)
  temp1=addr&0x00ff;//addr%256
  temp2=addr>>8;
  lcd_writecom(0xfb);
  lcd_writecom(0xfa);
  lcd_writecom(0xf9);
  lcd_writecom(0xf8);
  lcd_writecom(0xff);
  lcd_writecom(0xfe);
  lcd_writecom(0xfd);
  lcd_writecom(0xfc);
  addr+=lcdxdev8;
      画8*8的大点(用读改写方式  速度快)
  uint addr;
 addr=y*lcdxdev8*8+(x);//x/8*4;y*320=y*(256+64)=(y<<8)+(y<<6)
 for(n=0;n<8;n++)
  temp1=addr;//&0x00ff;//addr%256
  temp2=addr>>8;
  //dat=(lcd_readdat_onebyte(0xc5))|0xff;
  dat=0xff;
  addr+=lcdxdev8;
       清楚8*8的大点(用画点方式  速度慢)
/*void clr_big(uchar x,uchar y)
  uint addr;
 for(n=0;n<8;n++)
  temp2=addr>>8;
  lcd_writecom(0xf3);
  lcd_writecom(0xf2);
  lcd_writecom(0xf1);
  lcd_writecom(0xf0);
  lcd_writecom(0xf7);
  lcd_writecom(0xf6);
  lcd_writecom(0xf5);
  lcd_writecom(0xf4);
  addr+=lcdxdev8;
       清除8*8的大点(用读修改写方式  速度快)
  uint addr;
 for(n=0;n<8;n++)
  temp2=addr>>8;
  //dat=(lcd_readdat_onebyte(0xc5))|0x00;
  dat=0x00;
  addr+=lcdxdev8;
          图形方式   屏上写汉字 16*16
  uint addr;
  uint temp1;
  uchar n;
  temp1=y;temp1=lcdxdev8*16;//30*16
  addr=temp1+(x<<1);
   for(n=0;n<16;n++)
  lcd_writecom_two((addr&0x00ff),(addr>>8),0x24);
  lcd_writedat_onebyte(*dat,0xc0);
  dat++;
  lcd_writedat_onebyte(*dat,0xc4);
  dat++;
  addr=addr+lcdxdev8;
       图形方式   屏上写字母,数字 8*16
  uint addr;
  uint temp1;
  uchar n;
  temp1=y;temp1=lcdxdev8*16;//512+128//lcdxdev8  40*16
  addr=temp1+(x<<1);
   for(n=0;n<16;n++)
  dat++;
  addr=addr+lcdxdev8;
     用画点的方式划横线  (可以用读改写的方式)
/*void horizontal(uchar x0,uchar x1,uchar y)
 uchar temp,n;
 if(x0>x1)
  temp=x0;
  x0=x1;
  x1=temp;
 n=x1-x0;
 for(;n>0;n--)
  sel_point(x0+n,y);
    划横线  (用读改写的方式)
uchar get_num(uchar x0)
uchar dat;
  switch(x0)
  case 0: dat=0xff;break;
  case 1: dat=0x7f;break;
  case 2: dat=0x3f;break;
  case 3: dat=0x1f;break;
  case 4: dat=0x0f;break;
  case 5: dat=0x07;break;
  case 6: dat=0x03;break;
  case 7: dat=0x01;break;
 return dat;
uchar get_num_n(uchar x1)
uchar dat;
  switch(x1)
  case 0: dat=0x80;break;
  case 1: dat=0xc0;break;
  case 2: dat=0xe0;break;
  case 3: dat=0xf0;break;
  case 4: dat=0xf8;break;
  case 5: dat=0xfc;break;
  case 6: dat=0xfe;break;
  case 7: dat=0xff;break;
 return dat;
 uint addr;
 uchar temp,n,temp1,temp2,dat,dat1;
 if(x0>x1)
  temp=x0;
  x0=x1;
  x1=temp;
  addr=y*lcdxdev8+(x0>>3);
  temp1=addr;//&0xff;
  temp2=addr>>8;
   n=x1-x0;
  dat1=lcd_readdat_onebyte(0xc5);
   if((x0>>3)!=(x1>>3))
   lcd_writedat_onebyte((get_num(x0&0x3)|dat1),0xc0);
    temp1=x0>>3;
    temp2=x1>>3;
     temp=temp2-temp1-1;
      lcd_writecom(0xb0);
         while(temp)
          lcd_writedat(0xff);
          temp--;
          lcd_writecom(0xb2);
   lcd_writedat_onebyte((get_num_n(x1&0x03)|dat1),0xc4);
    else
    x0=x0&0x07;
    x1=x1%0x07;
   dat =~(get_num(x0)^get_num_n(x1));
   lcd_writedat_onebyte((dat|dat1),0xc4);
       用画点的方式画竖线
  uchar temp,n;
 if(y0>y1)
  temp=y0;
  y0=y1;
  y1=temp;
 n=y1-y0;
 for(;n>0;n--)
  sel_point(x,y0+n);
布兰森汉姆(Bresenham)算法画线  两端点(x0,y0) (x1,y1)
int dx,dy;                //定义X.Y轴上增加的变量值
int  sub;
int temp;                //起点、终点大小比较,交换数据时的中间变量
uchar flag;
if(x0>x1)                //X轴上,起点大于终点,交换数据
   temp=x1;
   x1=x0;
   x0=temp;
   temp=y1;
   y1=y0;
   y0=temp;
dx=x1-x0;                //X轴方向上的增量
dy=y1-y0;                //Y轴方向上的增量
   if(dx==0)
   erect(y0,y1,x0);
if(dy==0)
  rhorizontal(x0,x1,y0);
   if(dy>0)
    flag=1;
    else
    flag=0;
if((dx!=0)&&(dy!=0))
// 布兰森汉姆(Bresenham)算法画线 /
if(flag==1)
  if(dx>=dy)                  //靠近X轴
   sub=2*dy-dx;              //计算下个点的位置
   while(x0!=x1)
   sel_point(x0,y0);        //画起点
     x0++;                  // X轴上加1
     if(sub>0)                // 判断下下个点的位置
       y0++;                  // 为右上相邻点,即(x0+1,y0+1)
       sub+=2*dy-2*dx;
     else
       sub+=2*dy;            // 判断下下个点的位置
   sel_point(x0,y0);
   else
   sub=2*dy-dx;              //靠近Y轴
   while(y0!=y1)
   y0++;
     if(sub>0)              //判断下下个点的位置
       x0++;
       sub+=2*dx-2*dy;
     else
       sub+=2*dx;
    sel_point(x0,y0);
else
   dy=y0-y1;
   if(dx>=dy)                  //靠近X轴
   while(x0!=x1)
     x0++;                  // X轴上加1
       y0--;                  // 为右上相邻点,即(x0+1,y0+1)
       sub+=2*dy-2*dx;
     else
   sel_point(x0,y0);
 else
    sub=2*dx-dy;              //靠近Y轴
   while(y0!=y1)
     y0--;
       x0++;
       sub+=2*dx-2*dy;
     else
       sub+=2*dx;
    sel_point(x0,y0);
             画圆 圆点(x,y) 半径 r
    int a, b, num;
    a = 0;
    b = r;
    while(2 * b * b >= r * r)          // 1/8圆即可
        sel_point(x + a, y - b); // 0~1
        sel_point(x - a, y - b); // 0~7
        sel_point(x - a, y + b); // 4~5
        sel_point(x + a, y + b); // 4~3
        sel_point(x + b, y + a); // 2~3
        sel_point(x + b, y - a); // 2~1
        sel_point(x - b, y - a); // 6~7
        sel_point(x - b, y + a); // 6~5
        a++;
        num = (a * a + b * b) - r*r;
        if(num > 0)
            b--;
            a--;
void lcd_init()
     lcd_writecom_two(0x00,0x00,0x24);
        lcd_writecom_two(0x00,0x00,0x21);
        lcd_writecom_two(0x00,0x00,0x42);
        lcd_writecom_two(lcdxdev8,0x00,0x43);//28
        lcd_writecom_two(0x00,0x00,0x40);
        lcd_writecom_two(lcdxdev8,0x00,0x41);//1e
        lcd_writecom(0xa0);
        lcd_writecom(0x98);
        lcd_writecom(0x80);
#include "lcd.h"
int main()
    lcd_init();
    sel_point(239,5);
    clear_point(239,5);
    sel_rmiddling(1,1);
    clr_rmiddling(1,1);
    sel_rbig(3,3);
//void graph_mode_writeword(uchar x,uchar y,uchar *dat);
//void graph_mode_write_letter(uchar x,uchar y,uchar *dat);
 rhorizontal(0,128,20);
 erect(0,100,100);
 draw_circle(80, 64, 60);
    //clr_rbig(3,3);
 /* Draw_line(0,0,127,127);
  Draw_line(0,127,239,0);
  Draw_line(0,0,239,0);
  Draw_line(0,127,239,127);
  Draw_line(0,0,0,127);
  Draw_line(239,0,239,127);  */
 while(1);
路过
鸡蛋
鲜花
握手
雷人
全部作者的其他最新日志
评论 (0 个评论)
