nRF51 SDK v9.0.0
Release Date: Week 28
Highlights:
- Support for S210 SoftDevice v5.0.0
- Support for S310 SoftDevice v3.0.0
- Documentation moved to Infocenter
- DFU Signing using Elliptic Curve Cryptography added as experimental
- Available in the zip file only
- Running Speed and Cadence relay example showing concurrent
central/peripheral functionality of S130
The following toolchains/devices have been used for testing and verification:
- ARM: MDK-ARM version 5.14.0.0
- GCC: GCC ARM Embedded 4.9 2015q1
- IAR: IAR Workbench 7.20
- Windows XP SP3 32-bit
- Windows 7 SP1 64-bit
- Windows 8.1
Supported SoftDevices:
- S110 v8.0.0
- S120 v2.1.0
- S130 v1.0.0
- S210 v5.0.0
- S310 v3.0.0
Supported boards:
- PCA10028
- PCA10031
For other devices and boards, see the SDK documentation, section
"Using the SDK with other boards".
nRF51 SDK v. 8.1.1
This is a supplement to the nRF51 SDK v8.1.0 release notes.
This release does not include any code changes compared to nRF51 SDK v8.1.0., except for a minor addition that is described in the "Changes" section.
Fixed issues:
- Project does not compile if nrf_drv_ppi is used together with SoftDevice S110, S120 or S210.
Issue exists only in CMSIS PACK release.
Changes:
- Released new SoftDevice packs: nRF_SoftDevice_S110.8.0.1, nRF_SoftDevice_S120.2.0.1 and
nRF_SoftDevice_S210.4.0.1-5 with updated nrf_sd_def.h.
- S110 8.0.0
- S120 2.0.0
- S130 1.0.0
- S210 4.0.1
nRF51 SDK v8.1.0
Highlights:
- Support for SoftDevice S130 v1.0.0
- Serialization supporting SoftDevice S110, S120, and S130
- ANCS updated and no longer in experimental state
- GCC updated to new version: ARMGCC 4.9 q1-2015
- DFU example now has support for IAR and GCC
- ARM: MDK-ARM version 4.72.10, 5.13.0.0, 5.14.0.0
- GCC: gcc-arm-embedded 4.9 2015q1
- IAR: IAR Embedded Workbench for ARM version 7.20.2
- Windows 8.1
nRF51 SDK v8.0.0
Highlights:
- Support for the latest S110, S120, and S130 SoftDevices. (S310 is not supported.)
- SoftDevices included in the SDK.
- Greatly increased driver and HAL coverage.
- New service client and profile example: Current Time Service/Time Profile.
- IAR support for most examples.
- ARM: MDK-ARM Version 4.72.10, 5.13.0.0, 5.14.0.0
- GCC: gcc-arm-embedded 4.7 2013q1
- Windows 8.1
Supported devices:
- This SDK is optimized for IC revision 3.
For details, see the "nRF51 Series Compatibility Matrix" document (ATTN-51) available on
www.nordicsemi.com.
Note 1: To run the ANT examples, you must use an nRF51422 device.
Note 2: Some of the examples using the SoftDevice will not fit on the 128 kB variant of the
chip.
- S110 8.0.0
- S120 2.0.0
- S130 0.9.0-1.alpha
- S210 4.0.1
Supported boards:
- PCA10028
- PCA10031
For other devices and boards, see the SDK documentation, section "Using the SDK with other
boards", or use SDK v6.x.x.
Changes:
Toolchain/IDE:
- The nRF51 SDK now supports the following toolchains in most examples:
- Keil 5.14 (with packs)
- Keil 5.14 (without packs)
- Keil 4.72.10
- ARM GCC 4.7 2013q1
- IAR 7.20.2
- The supported SoftDevices are now included in the SDK and can be flashed directly from
Keil, as a separate target.
