定位cortex-m3的hard fault的方法
7731|13
 楼主| 李富贵 发表于 2011-12-17 17:13 | 显示全部楼层 |阅读模式
1,  用Keil的话,可以这样:
先将fault中断函数的内容改为:
HardFault_Handler\
                PROC
                ;EXPORT  HardFault_Handler         [WEAK]
                ;B                  .
                                IMPORT hard_fault_handler_c
                                TST LR, #4
                                ITE EQ
                                MRSEQ R0, MSP
                                MRSNE R0, PSP
                                B hard_fault_handler_c
                ENDP
然后在源程序里添加下面的函数代码:
// hard fault handler in C,
// with stack frame location as input parameter
void hard_fault_handler_c(unsigned int * hardfault_args)
unsigned int stacked_r0;
unsigned int stacked_r1;
unsigned int stacked_r2;
unsigned int stacked_r3;
unsigned int stacked_r12;
unsigned int stacked_lr;
unsigned int stacked_pc;
unsigned int stacked_psr;
stacked_r0 = ((unsigned long) hardfault_args[0]);
stacked_r1 = ((unsigned long) hardfault_args[1]);
stacked_r2 = ((unsigned long) hardfault_args[2]);
stacked_r3 = ((unsigned long) hardfault_args[3]);
stacked_r12 = ((unsigned long) hardfault_args[4]);
stacked_lr = ((unsigned long) hardfault_args[5]);
stacked_pc = ((unsigned long) hardfault_args[6]);
stacked_psr = ((unsigned long) hardfault_args[7]);
printf ("[Hard fault handler]\n");
printf ("R0 = %x\n", stacked_r0);
printf ("R1 = %x\n", stacked_r1);
printf ("R2 = %x\n", stacked_r2);
printf ("R3 = %x\n", stacked_r3);
printf ("R12 = %x\n", stacked_r12);
printf ("LR = %x\n", stacked_lr);
printf ("PC = %x\n", stacked_pc);
printf ("PSR = %x\n", stacked_psr);
printf ("BFAR = %x\n", (*((volatile unsigned long *)(0xE000ED38))));
printf ("CFSR = %x\n", (*((volatile unsigned long *)(0xE000ED28))));
printf ("HFSR = %x\n", (*((volatile unsigned long *)(0xE000ED2C))));
printf ("DFSR = %x\n", (*((volatile unsigned long *)(0xE000ED30))));
printf ("AFSR = %x\n", (*((volatile unsigned long *)(0xE000ED3C))));
while(1)
如果使用调试器,则可以在第一个printf处设置断点.没有的话看串口打印结果
通过查看stacked_lr的内容可以知道程序运行到哪个位置出现fault
然后查看编译后汇编代码,可以知道源程序是哪个函数哪一步出现问题,
配合其它寄存器的内容来分析找出原因
2.用IAR的话,把startup_ewarm.c文件中的FaultISR()函数的内容改为:
volatile unsigned int stacked_r0;
volatile unsigned int stacked_r1;
volatile unsigned int stacked_r2;
volatile unsigned int stacked_r3;
volatile unsigned int stacked_r12;
volatile unsigned int stacked_lr;
volatile unsigned int stacked_pc;
volatile unsigned int stacked_psr;
//unsigned long cc;
  while(1)
配合其它寄存器的内容来分析找出原因
tuzihog 发表于 2014-11-2 21:05 | 显示全部楼层
别怪我挖坟
好东东,关注一下
dong_abc 发表于 2014-11-2 21:09 | 显示全部楼层
+1
评分
参与人数 1威望 +1 收起 理由
Just_Beat_It + 1 很给力!
查看全部评分
xlsbz 发表于 2014-11-6 13:12 | 显示全部楼层
富贵 有两把刷子  以前还小看你了
xlsf1048 发表于 2014-12-24 15:44 | 显示全部楼层
myqq12 发表于 2014-12-24 17:21 | 显示全部楼层
牛X+威武
冒泡的鱼儿 发表于 2014-12-30 21:32 | 显示全部楼层
多谢分享
tangqiiln 发表于 2015-1-30 20:12 | 显示全部楼层
liu100149 发表于 2015-3-8 11:16 | 显示全部楼层
我的根据stacked_lr=0x00004c29
C是这句 liuhuaqiang=SPI_SendByte(dat);
汇编代码
0x00004C28 4905      LDR      r1,[pc,#20]  ; @0x00004C40
0x00004C2A 7008      STRB     r0,[r1,#0x00]
是什么问题
nyszx 发表于 2015-3-8 13:57 | 显示全部楼层
很强大,有时间试一下。谢谢分享
wmslecz 发表于 2015-3-9 18:42 | 显示全部楼层
非常给力呀。。。好东西。赞一个。。。
firstfox 发表于 2016-11-4 09:41 | 显示全部楼层
如果能在实例讲解一下就更好了
yu0405jie 发表于 2016-11-4 16:35 | 显示全部楼层
getappple 发表于 2016-12-23 20:21 | 显示全部楼层
FUK****** 老朴
个人签名:上联:subway railway highway,way way to die 下联:investigator officer announcer,sir sir to lie 横批:welcome to china
29
