[VHDL] 基于xilinx6的fir低通滤波器的代码,有人可以帮我看看是否ok
 楼主| jahveh123 发表于 2014-12-9 20:35 | 显示全部楼层 |阅读模式
-- Company:
-- Engineer:
-- Create Date:    16:57:10 12/02/2014
-- Design Name:
-- Module Name:    fir_total - Behavioral
-- Project Name:
-- Target Devices:
-- Tool versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity fir_total is
port (clk : in std_logic;
      reset: in std_logic;
                x: in std_logic_vector(7 downto 0);
                y: out std_logic_vector(14 downto 0)
end fir_total;
architecture Behavioral of fir_total is
signal x0,x1,x2,x3,x4,x5,x6,x7,x8,x9,x10,x11,x12,x13,x14,x15: std_logic_vector(7 downto 0);
signal p0,p1,p2,p3,p4,p5,p6,p7:integer;
signal sum: integer;
-- coefficient
constant h0: integer:=-831;
constant h1: integer:=-2102;
constant h2: integer:=918;
constant h3: integer:=-372;
constant h4: integer:=0;
constant h5: integer:=242;
constant h6: integer:=-278;
constant h7: integer:=118;
constant h8: integer:=118;
constant h9: integer:=-278;
constant h10: integer:=242;
constant h11: integer:=0;
constant h12: integer:=-372;
constant h13: integer:=918;
constant h14: integer:=-2102;
constant h15: integer:=-831;
begin
process (clk)
    begin
           if rising_edge(clk) then
                  if reset='1' then
                    x15 <=( others =>'0');
                         x14 <=( others =>'0');
                         x13 <=( others =>'0');
                         x12 <=( others =>'0');
                    x11 <=( others =>'0');
                    x10 <=( others =>'0');
                    x9 <=( others =>'0');
                    x8 <=( others =>'0');
                         x7 <=( others =>'0');
                         x6 <=( others =>'0');
                         x5 <=( others =>'0');
                         x4 <=( others =>'0');
                         x3 <=( others =>'0');
                         x2 <=( others =>'0');
                         x1 <=( others =>'0');
                         x0 <=( others =>'0');
                  else
                    x15 <= x14;
                         x14 <= x13;
                         x13 <= x12;
                         x12 <= x11;
                         x11 <= x10;
                         x10 <= x9;
                    x9 <= x8;
                    x8 <= x7;
          x7 <= x6;
                         x6 <= x5;
                         x5 <= x4;
                         x4 <= x3;
                         x3 <= x2;
                         x2 <= x1;
                         x1 <= x0;
                         x0 <= x;
                        end if;
                  end if;
   end process;
        p0 <= (conv_integer(x0)+conv_integer(x15))*h0;
        p1 <= (conv_integer(x1)+conv_integer(x14))*h1;
        p2 <= (conv_integer(x2)+conv_integer(x13))*h2;
        p3 <= (conv_integer(x3)+conv_integer(x12))*h3;
        p4 <= (conv_integer(x4)+conv_integer(x11))*h4;
        p5 <= (conv_integer(x5)+conv_integer(x10))*h5;
        p6 <= (conv_integer(x6)+conv_integer(x9))*h6;
        p7 <= (conv_integer(x7)+conv_integer(x8))*h7;
   sum <= p0+p1+p2+p3+p4+p5+p6+p7;
        y <= conv_std_logic_vector(sum,15);
end Behavioral;
--signal count: natural range 0 to 4;
--signal enable: std_logic;
--  process (clk,reset)
--    begin
--     if reset='1' then
--        count <= 0;
--     elsif rising_edge(clk) and (enable='0') then
--             count <= count +1;
--          end if;
--  end process;
--  enable <= '1' when (count=4)
--         else '0';
--  process(enable)
--   begin
--   if enable ='1'        then
我设计的fir滤波器,将数据在matlab里面显示,反而高频率的信号的输出好过低频率的
wajtmusic 发表于 2014-12-11 11:36 | 显示全部楼层
这是几阶的FIR滤波啊?楼主能说一下设计流程吗?
