参照我们所提供的“i.MX6 Ubuntu12.04上编译LTIB”文档操作时。然后在执行
~/I.MX6/L3.0.35_4.1.0_130816_source/source/ltib$ ./ltib
ltib cannot be run because one or more of the host packages needed to run it
are either missing or out of date or not in ltib's standard path. Please
install/upgrade these packages on your host. If you have your own utilities
in non-standard paths, please add an entry into the .ltibrc file for example:
%path_std
/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/X11R6/bin:/my/own/exes
Package Minimum ver Installed info
zlib 0 not installed
Died at ./ltib line 1409.
traceback:
main::host_checks:1409
main:554
Started: Fri Dec 18 16:14:18 2015
Ended: Fri Dec 18 16:14:19 2015
Elapsed: 1 seconds
Build Failed
Exiting on error or interrupt
这个帖子也看了https://bbs.21ic.com/icview-823396-1-1.html,问题还是没有解决。
我用的文件是L3.0.35_4.1.0_130816_source,32位系统。
zlib => sub { my @f = (glob('/usr/lib/libz.so*'),
glob('/lib/libz.so*'),
glob('/lib64/libz.so*'),
glob('/usr/lib/i386-linux-gnu/libz.so*'),
glob('/usr/lib32/libz.so*'),
glob('/usr/lib/x86_64-linux-gnu/libz.so*') ); @f > 1 ? 1 : 0 },
这个也一样。请教楼主。。
