[i.MX] i.mx6q sabreauto 接USB鼠标出现问题 求各位前辈指点 在线等
 楼主| ruofeng1008 发表于 2015-12-23 15:52 | 显示全部楼层 |阅读模式
板子是官方的,代码没修改什么地方,编译下载完后,接上鼠标启动后,出现信息如下:
root@sabreauto_6q:/ # usb 2-1: device not accepting address 9, error -71
hub 2-0:1.0: unable to enumerate USB device on port 1
mxc_hdmi mxc_hdmi: Read EDID again
mxc_hdmi mxc_hdmi: No modes read from edid
mxc_hdmi mxc_hdmi: create default modelist
fbcvt: 1920x1080@60: CVT Name - 2.073M9
ERROR: v4l2 capture: slave not found!
usb 2-1: new low speed USB device number 10 using fsl-ehci
usb 2-1: device descriptor read/64, error -71
usb 2-1: new low speed USB device number 11 using fsl-ehci
usb 2-1: new low speed USB device number 12 using fsl-ehci
usb 2-1: device not accepting address 12, error -71
usb 2-1: new low speed USB device number 13 using fsl-ehci
usb 2-1: device not accepting address 13, error -71
usb 2-1: new low speed USB device number 14 using fsl-ehci
usb 2-1: new low speed USB device number 15 using fsl-ehci
usb 2-1: new low speed USB device number 16 using fsl-ehci
usb 2-1: device not accepting address 16, error -71
usb 2-1: new low speed USB device number 17 using fsl-ehci
usb 2-1: device not accepting address 17, error -71
warning: `zygote' uses 32-bit capabilities (legacy support in use)
period 0 ,timeout is 0, wake up is :0
usb 2-1: new low speed USB device number 18 using fsl-ehci
usb 2-1: new low speed USB device number 19 using fsl-ehci
usb 2-1: new low speed USB device number 20 using fsl-ehci
usb 2-1: device not accepting address 20, error -71
usb 2-1: new low speed USB device number 21 using fsl-ehci
usb 2-1: device not accepting address 21, error -71
request_suspend_state: wakeup (3->0) at 23911712671 (1970-01-02 00:55:21.577410669 UTC)
period 66 ,timeout is 0, wake up is :0
mma enable setting active
eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=1:01, irq=-1)
ADDRCONF(NETDEV_UP): eth0: link is not ready
usb 2-1: new low speed USB device number 22 using fsl-ehci
acc_open
acc_release
求救啊   没有屏,我就想用鼠标在显示器上解个锁而已
各位大神,该怎么办啊 !!!
版主!!呼叫支援啊!!
kris_fei 发表于 2015-12-23 15:59 | 显示全部楼层
可以先临时把锁屏功能移除掉呗
 楼主| ruofeng1008 发表于 2015-12-23 16:02 | 显示全部楼层
可以先临时把锁屏功能移除掉呗
请问该怎样做呢,网上找不到资料啊,新手一枚。求指点,谢谢啦
kris_fei 发表于 2015-12-23 16:13 | 显示全部楼层
移除keyguard.apk即可。
gardenhill 发表于 2015-12-23 16:41 | 显示全部楼层
这个好像是硬件的问题,查鼠标和usbhub.
评分
参与人数 1威望 +1 收起 理由
ruofeng1008 + 1 赞一个!
查看全部评分
C洛达尔多 发表于 2015-12-23 17:22 | 显示全部楼层
感觉这复杂的东西开发起来很难啊
far5810 发表于 2015-12-23 20:25 | 显示全部楼层
这是usb座子接触问题,  烙铁烫烫    热风枪吹吹  就好了
评分
参与人数 1威望 +2 收起 理由
ruofeng1008 + 2 赞一个!
查看全部评分
 楼主| ruofeng1008 发表于 2015-12-24 15:58 | 显示全部楼层
换了一个线就好了,嘿嘿
mini1986 发表于 2015-12-28 09:46 | 显示全部楼层
默认usb这些功能是都支持的,有问题的话,基本上往硬件方面找......
