- * ADS1115.h
- * Created on: 2012-7-30
- * Author: Piao
- #ifndef ADS1115_H_
- #define ADS1115_H_
- /**********ADDR宏定义***************/
- #define ADDRESS_0 0x90 //ADDR PIN ->GND
- #define ADDRESS_1 0x92 //ADDR PIN ->VDD
- #define ADDRESS_2 0x94 //ADDR PIN ->SDA
- #define ADDRESS_3 0x96 //ADDR PIN ->SCL
- /************POINTER REGISTER*****************/
- #define Pointer_0 0x00 //Convertion register
- #define Pointer_1 0x01 //Config register
- #define Pointer_2 0x02 //Lo_thresh register
- #define Pointer_3 0x03 //Hi_thresh register
- /************CONFIG REGISTER*****************/
- #define OS_0 0x0000
- #define OS_1 0x8000
- #define MUX_0 0x0000 //AINp=AIN0, AINn=AIN1
- #define MUX_1 0x1000 //AINp=AIN0, AINn=AIN3
- #define MUX_2 0x2000 //AINp=AIN1, AINn=AIN3
- #define MUX_3 0x3000 //AINp=AIN2, AINn=AIN3
- #define MUX_4 0x4000 //AINp=AIN0, AINn=GND
- #define MUX_5 0x5000 //AINp=AIN1, AINn=GND
- #define MUX_6 0x6000 //AINp=AIN2, AINn=GND
- #define MUX_7 0x7000 //AINp=AIN3, AINn=GND
- #define PGA_0 0x0000 //FS=6.144V
- #define PGA_1 0x0200 //FS=4.096V
- #define PGA_2 0x0400 //FS=2.048V
- #define PGA_3 0x0600 //FS=1.024V
- #define PGA_4 0x0800 //FS=0.512V
- #define PGA_5 0x0A00 //FS=0.256V
- #define PGA_6 0x0C00 //FS=0.256V
- #define PGA_7 0x0E00 //FS=0.256V
- #define MODE_0 0x0000
- #define MODE_1 0x0100
- #define DR_0 0x0000 //Data Rate = 8
- #define DR_1 0x0020 //Data Rate = 16
- #define DR_2 0x0040 //Data Rate = 32
- #define DR_3 0x0060 //Data Rate = 64
- #define DR_4 0x0080 //Data Rate = 128
- #define DR_5 0x00A0 //Data Rate = 250
- #define DR_6 0x00C0 //Data Rate = 475
- #define DR_7 0x00E0 //Data Rate = 860
- #define COMP_MODE_0 0x0000
- #define COMP_MODE_1 0x0010
- #define COMP_POL_0 0x0000
- #define COMP_POL_1 0x0008
- #define COMP_LAT_0 0x0000
- #define COMP_LAT_1 0x0040
- #define COMP_QUE_0 0x0000
- #define COMP_QUE_1 0x0001
- #define COMP_QUE_2 0x0002
- #define COMP_QUE_3 0x0003
- void Delay(void);
- void Delay_1ms(void);
- void Start(void);
- void Stop(void);
- void ACK(void);
- void NACK(void);
- unsigned char Check(void);
- void Write_1_Byte(unsigned char DataByte);
- unsigned char Write_N_Byte(unsigned char *writebuffer,unsigned char n);
- unsigned char Read_1_Byte(void);
- void Read_N_Byte(unsigned int *readbuff,unsigned char n);
- void InitADS1115(void);
- void WriteWord(void);
- void ReadWord(void);
- void ADS1115(void);
- void ShowInt(long int x);
- #endif /* ADS1115_H_ */
- #include <MSP430F149.h>
- #include "ADS1115.h"
- * ADDR---> GND
- * VDD ---> 3.3V
- * SCL ---> P2.6
- * SDA ---> P2.7
- * AINp=AIN0, AINn=GND
- /***************引脚定义*****************/
- #define SCL 0x40
- #define SDA 0x80
- #define SCL_SEL P2SEL &= ~SCL
- #define SCL_DDR_OUT P2DIR |= SCL
- #define SCL_OUT P2OUT
- #define SCL_H SCL_OUT |= SCL
- #define SCL_L SCL_OUT &= ~SCL
- #define SDA_SEL P2SEL &= ~SDA
- #define SDA_DDR_OUT P2DIR |= SDA
- #define SDA_DDR_IN P2DIR &= ~SDA
- #define SDA_OUT P2OUT
- #define SDA_IN P2IN
- #define SDA_H SDA_OUT |= SDA
- #define SDA_L SDA_OUT &= ~SDA
- #define TRUE 1
- #define FALSE 0
- /*************ADDR Initial********************/
- #define ADDRESS ADDRESS_0 //ADDR PIN ->GND
- #define ADDRESS_W ADDRESS |0x00 //写地址
- #define ADDRESS_R ADDRESS|0x01 //读地址
- /*************Config Initial*********************/
- #define OS OS_1
- #define MUX MUX_4 //AINp=AIN0, AINn=GND
- #define PGA PGA_0 //FS=6.144V
- #define DR DR_7 //Data Rate = 860
- #define COMP_QUE COMP_QUE_3
- unsigned int Config;
- unsigned char Writebuff[4],Readbuff[3];
- unsigned int Result[2];
- int D_ADS; //转换的数字量
- float VIN_DAS; //输入的电压值
- unsigned char t_DAS;
- int Format[5]={0}; //转换的数字量转换成十进制
- 函数名称:delay
- 功 能:延时约15us的时间
- 参 数:无
- 返回值 :无
- void Delay(void)
- unsigned char i;
- for(i = 0;i < 15;i++)
- _NOP();
- /******************延时1ms的时间*********************/
- unsigned char i;
- for(i = 150;i > 0;i--) _NOP();
- 函数名称:Start
- 功 能:完成IIC的起始条件操作
- 参 数:无
- 返回值 :无
- void Start(void)
- SCL_H;
- SDA_H;
- Delay();
- SDA_L;
- Delay();
- SCL_L;
- Delay();
- 函数名称:Stop
- 功 能:完成IIC的终止条件操作
- 参 数:无
- 返回值 :无
- void Stop(void)
- SDA_L;
- Delay();
- SCL_H;
- Delay();
- SDA_H;
- Delay();
- 函数名称:ACK
- 功 能:完成IIC的主机应答操作
- 参 数:无
- 返回值 :无
- void ACK(void)
- SDA_L;
- _NOP(); _NOP();
- SCL_H;
- Delay();
- SCL_L;
- _NOP(); _NOP();
- SDA_H;
- Delay();
- 函数名称:NACK
- 功 能:完成IIC的主机无应答操作
- 参 数:无
- 返回值 :无
- void NACK(void)
- SDA_H;
- _NOP(); _NOP();
- SCL_H;
- Delay();
- SCL_L;
- _NOP(); _NOP();
- SDA_L;
- Delay();
- /**********检查应答信号函数******************/
- /*如果返回值为1则证明有应答信号,反之没有*/
- 函数名称:Check
- 功 能:检查从机的应答操作
- 参 数:无
- 返回值 :从机是否有应答:1--有,0--无
- unsigned char slaveack;
- SDA_H;
- _NOP(); _NOP();
- SCL_H;
- _NOP(); _NOP();
- SDA_DDR_IN;
- _NOP(); _NOP();
- slaveack = SDA_IN&SDA; //读入SDA数值
- SCL_L;
- Delay();
- SDA_DDR_OUT;
- if(slaveack) return FALSE;
- else return TRUE;
- /***************Write a Byte****************/
- int i;
- for(i=0;i<8;i++)
- if(DataByte&0x80) //if((DataByte<<i)&0x80)
- SDA_H;
- else
- SDA_L;
- Delay();
- SCL_H;
- Delay();
- SCL_L;
- Delay();
- DataByte <<= 1;
- SDA_H;
- _NOP();
- /***************Write N Byte****************/
- int i;
- for(i=0;i<n;i++)
- Write_1_Byte(*writebuffer);
- if(Check())
- writebuffer ++;
- else
- Stop();
- return FALSE;
- Stop();
- return TRUE;
- /***************Read a Byte****************/
- unsigned char data=0,FLAG, i;
- for(i=0;i<8;i++)
- SDA_H;
- Delay();
- SCL_H;
- SDA_DDR_IN; //端口为输入
- Delay();
- FLAG=SDA_IN& SDA;
- data <<= 1;
- if( FLAG)
- data |= 0x01;
- SDA_DDR_OUT;
- SCL_L;
- Delay();
- return data;
- /***************Read N Byte****************/
- void Read_N_Byte(unsigned int*readbuff,unsigned char n)
- unsigned char i;
- for(i=0;i<n;i++)
- readbuff[i]=Read_1_Byte();
- if(i==n-1)
- NACK(); //不连续读字节
- else
- ACK(); //连续读字节
- Stop();
- /*****************初始化******************/
- SCL_SEL;
- SDA_SEL;
- SCL_DDR_OUT;
- SDA_DDR_OUT;
- SDA_H;
- Config = OS+MUX+PGA+DR+COMP_QUE;
- Writebuff[0]=ADDRESS_W;
- Writebuff[1]=Pointer_1;
- Writebuff[2]=Config/256;
- Writebuff[3]=Config%256;
- Readbuff[0]=ADDRESS_W;
- Readbuff[1]=Pointer_0;
- Readbuff[2]=ADDRESS_R;
- /***************Write a Word***********************/
- int t;
- Start(); //写入4个字节
- do
- t=Write_N_Byte(Writebuff,4);
- }while(t==0);
- /***************Read Word***********************/
- int t;
- Start(); //写入2个字节
- do
- t=Write_N_Byte(Readbuff,2);
- }while(t==0);
- Start(); //写入2个字节
- do
- t=Write_N_Byte(&Readbuff[2],1);
- }while(t==0);
- Read_N_Byte(Result,2); //读出2个字节
- /***************ADS1115********************/
- InitADS1115();
- WriteWord();
- Delay_1ms();
- ReadWord();
- D_ADS=Result[0]*256+Result[1]; //转换的数字量
- t_DAS=0;
- ShowInt(D_ADS); //转换的数字量转换成十进制
- VIN_DAS=6.144*D_ADS/32768; //输入的电压值
- //用递归方法将正整数x转换为10进制格式
- if(x)
- Format[t_DAS]= x%10;
- t_DAS ++;
- ShowInt(x/10);
