[ZLG-ARM] JTAG下载线驱动安装及NAND烧写步骤(转)
 楼主| yoyowodeai 发表于 2011-12-23 17:58 | 显示全部楼层 |阅读模式
驱动:GIVEIO
烧写程序:sjf2410.exe
一、安装JTAG并口下载工具驱动程序
驱动在文件夹GIVEIO,安装方法如下:
For Windows* 2000, use the following procedure:
1) Login as administrator
2) Copy the giveio.sys file to %systemroot%\system32\drivers.
3) Choose Control Panel, and choose Add/Remove Hardware.
4) Select ''''Add/Troubleshoot a device''''
5) Select ''''Add a new device'''' and choose Next, and select ''''No, I want to select the hardware from a list''''
6) Select Other devices and choose ''''Have Disk...''''.
7) Choose ''''Browse...'''', locate the folder where giveio.inf file.
8) Complete the remained process.
二、烧写NAND FLASH,参考如下步骤
