8核测试PFC886
 楼主| 34af9uc 发表于 2020-11-21 22:31 | 显示全部楼层 |阅读模式
PFC, AN, LED, se, go
//测试结果未知
/********************PFC886MF520*************************/
/********************8核测试******************************/
#include        "extern.h"
led1                bit                pa.2;
led2                bit                pa.3;
led3                bit                pa.4;
led4                bit                pa.5;
led5                bit                pa.1;
led6                bit                pa.0;
led7                bit                pa.7;
led8                bit                pa.6;
anjian1                bit                pb.0;
anjian2                bit                pb.1;
anjian3                bit                pb.2;
anjian4                bit                pb.3;
void        FPPA0 (void)
        .ADJUST_IC        SYSCLK=IHRC/4                //        SYSCLK=IHRC/4
        pmode        Program_Mode;                        //        if has more FPPAs than 2
        fppen        =        0xFF;
$                led1                out,low;
$                led2                out,low;
$                led3                out,low;
$                led4                out,low;
$                led5                out,low;
$                led6                out,low;
$                led7                out,low;
$                led8                out,low;
$                anjian1                in,pull;
$                anjian2                in,pull;
$                anjian3                in,pull;
$                anjian4                in,pull;
while (1)
void        FPPA1 (void)
        if(anjian1==0)
                led1=0;
        else
                led1=1;
        goto        $;
void        FPPA2 (void)
        if(anjian2==0)
                led2=0;
        else
                led2=1;
        goto        $;
void        FPPA3 (void)
                if(anjian2==0)
                led2=0;
        else
                led2=1;
        goto        $;
void        FPPA4 (void)
                if(anjian2==0)
                led2=0;
        else
                led2=1;
        goto        $;
void        FPPA5 (void)
                if(anjian2==0)
                led2=0;
        else
                led2=1;
        goto        $;
void        FPPA6 (void)
                if(anjian2==0)
                led2=0;
        else
                led2=1;
        goto        $;
void        FPPA7 (void)
                if(anjian2==0)
                led2=0;
        else
                led2=1;
        goto        $;
void        Interrupt (void)
        pushaf;
        if (Intrq.T16)
        {        //        T16 Trig
                //        User can add code
                Intrq.T16        =        0;
        popaf;
319
