使用CUBEMX生成stm32F030R8T6的工程文件,用HK32F030R8T6运行程序,GPIO能用,串口不能用,请大家帮忙看看。
- static void MX_USART1_UART_Init(void)
- /* USER CODE BEGIN USART1_Init 0 */
- /* USER CODE END USART1_Init 0 */
- /* USER CODE BEGIN USART1_Init 1 */
- /* USER CODE END USART1_Init 1 */
- huart1.Instance = USART1;
- huart1.Init.BaudRate = 9600;
- huart1.Init.WordLength = UART_WORDLENGTH_8B;
- huart1.Init.StopBits = UART_STOPBITS_1;
- huart1.Init.Parity = UART_PARITY_NONE;
- huart1.Init.Mode = UART_MODE_TX_RX;
- huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
- huart1.Init.OverSampling = UART_OVERSAMPLING_16;
- huart1.Init.OneBitSampling = UART_ONE_BIT_SAMPLE_DISABLE;
- huart1.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
- if (HAL_UART_Init(&huart1) != HAL_OK)
- Error_Handler();
- /* USER CODE BEGIN USART1_Init 2 */
- /* USER CODE END USART1_Init 2 */
- /***串口初始化***/
- void HAL_UART_MspInit(UART_HandleTypeDef* huart)
- GPIO_InitTypeDef GPIO_InitStruct = {0};
- if(huart->Instance==USART1)
- /* USER CODE BEGIN USART1_MspInit 0 */
- /* USER CODE END USART1_MspInit 0 */
- /* Peripheral clock enable */
- __HAL_RCC_USART1_CLK_ENABLE();
- __HAL_RCC_GPIOA_CLK_ENABLE();
- /**USART1 GPIO Configuration
- PA9 ------> USART1_TX
- PA10 ------> USART1_RX
- GPIO_InitStruct.Pin = GPIO_PIN_9|GPIO_PIN_10;
- GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
- GPIO_InitStruct.Pull = GPIO_NOPULL;
- GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
- GPIO_InitStruct.Alternate = GPIO_AF1_USART1;
- HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
- /* USART1 interrupt Init */
- HAL_NVIC_SetPriority(USART1_IRQn, 1, 0);
- HAL_NVIC_EnableIRQ(USART1_IRQn);
- /* USER CODE BEGIN USART1_MspInit 1 */
- /* USER CODE END USART1_MspInit 1 */
- int main(void)
- /* USER CODE BEGIN 1 */
- unsigned char a[5] ={0x11,0x22,0x33,0x44,0x55};
- /* USER CODE END 1 */
- /* MCU Configuration--------------------------------------------------------*/
- /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
- HAL_Init();
- /* USER CODE BEGIN Init */
- /* USER CODE END Init */
- /* Configure the system clock */
- SystemClock_Config();
- /* USER CODE BEGIN SysInit */
- /* USER CODE END SysInit */
- /* Initialize all configured peripherals */
- MX_GPIO_Init();
- HAL_UART_MspInit(&huart1);
- MX_USART1_UART_Init();
- /* USER CODE BEGIN 2 */
- /* USER CODE END 2 */
- /* Infinite loop */
- /* USER CODE BEGIN WHILE */
- while (1)
- /* USER CODE END WHILE */
- /* USER CODE BEGIN 3 */
- HAL_Delay(100);
- HAL_UART_Transmit(&huart1,a,5,0xFF);
- HAL_GPIO_TogglePin(OUT_1_GPIO_Port,OUT_1_Pin);
- /* USER CODE END 3 */
