GD32F150G8 USART1 REA接收状态无法使能
 楼主| faithswss 发表于 2021-3-4 15:33 | 显示全部楼层 |阅读模式
void rs422_uart_init(uint32_t baudrate, uint16_t data_bits,uint16_t parity, uint16_t stopbits)
        rcu_periph_clock_enable(AS32_GPIO_RX_RCC);
        rcu_periph_clock_enable(AS32_GPIO_TX_RCC);
        rcu_periph_clock_enable(AS32_UART_RCC);
        /* connect port to USARTx_Tx */
    gpio_af_set(AS32_GPIO_TX_PORT, AS32_UART_AF, AS32_GPIO_TX_PIN);
    /* connect port to USARTx_Rx */
    gpio_af_set(AS32_GPIO_RX_PORT, AS32_UART_AF, AS32_GPIO_RX_PIN);
    /* configure USART Tx as alternate function push-pull */
    gpio_mode_set(AS32_GPIO_TX_PORT, GPIO_MODE_AF, GPIO_PUPD_PULLUP, AS32_GPIO_TX_PIN);
    gpio_output_options_set(AS32_GPIO_TX_PORT, GPIO_OTYPE_PP, GPIO_OSPEED_10MHZ, AS32_GPIO_TX_PIN);
    /* configure USART Rx as alternate function push-pull */
    gpio_mode_set(AS32_GPIO_RX_PORT, GPIO_MODE_AF, GPIO_PUPD_PULLUP, AS32_GPIO_RX_PIN);
    gpio_output_options_set(AS32_GPIO_RX_PORT, GPIO_OTYPE_PP, GPIO_OSPEED_10MHZ, AS32_GPIO_RX_PIN);
        usart_deinit(AS32_UART);
    usart_baudrate_set(AS32_UART, baudrate);
    usart_transmit_config(AS32_UART, USART_TRANSMIT_ENABLE);
    usart_receive_config(AS32_UART, USART_RECEIVE_ENABLE);
        nvic_irq_enable(AS32_UART_IRQ, 1, 1);
#ifdef AS32_DIR_PORT
        rcu_periph_clock_enable(AS32_DIR_RCC);
        gpio_output_options_set(AS32_DIR_PORT, GPIO_OTYPE_PP, GPIO_OSPEED_10MHZ, AS32_DIR_PIN);
        gpio_mode_set(AS32_DIR_PORT, GPIO_MODE_OUTPUT, GPIO_PUPD_NONE, AS32_DIR_PIN);
        gpio_bit_reset(AS32_DIR_PORT, AS32_DIR_PIN);
#endif
        usart_interrupt_flag_clear(RS485_UART,USART_INT_FLAG_RBNE_ORERR);
        usart_interrupt_enable(AS32_UART,USART_INT_RBNE);
        usart_enable(AS32_UART);
ST-link 调试, 寄存器STAT REA位,没法变换为1 , 也就是 接收核心部分没有工作,
同样的代码 使用USART0 就可以, 这是为什么?
 楼主| faithswss 发表于 2021-3-4 15:43 | 显示全部楼层
CTL0 的TEN REN UEN 都为1, 但是 STAT 的 REA为0, TEA为1 ,并且后面运行过程中一致为0.
是哪里设置错误吗?
 楼主| faithswss 发表于 2021-3-4 15:45 | 显示全部楼层
#define AS32_UART                        USART1
#define AS32_UART_IRQ                USART1_IRQn
#define AS32_UART_RCC                RCU_USART1
#define AS32_UART_AF                GPIO_AF_1
#define AS32_GPIO_TX_RCC        RCU_GPIOA
#define AS32_GPIO_TX_PORT        GPIOA
#define AS32_GPIO_TX_PIN        GPIO_PIN_2
#define AS32_GPIO_RX_RCC        RCU_GPIOA
#define AS32_GPIO_RX_PORT        GPIOA
#define AS32_GPIO_RX_PIN        GPIO_PIN_3
从逻辑分析仪上能 看到,能够发送出数据, 但无法接收数据
ccc228 发表于 2021-5-21 19:51 | 显示全部楼层
你好,楼主的问题解决了吗?我用GD130也遇到了这个问题
我也遇到了,不知道怎么解决的  发表于 2025-5-28 11:19
AJSJ 发表于 2021-5-30 13:12 | 显示全部楼层
6年前生产的GD32F150C8..,使用USART1 ,需要把 USART_CTL1寄存器STRP置位 .  接线 : TX-TX.   RX-RX .
不知道现在GD32F150是否改正了问题.
吴工康康 发表于 2023-9-13 20:14 | 显示全部楼层
我用 GD32E230F8P6 遇到和你一样的问题了,联系了FAE,还没有答复
jiayuzhang90 发表于 2024-1-11 10:52 | 显示全部楼层
有答复吗?这边也是同样的问题
Lin@7989 发表于 2024-1-26 20:40 | 显示全部楼层
我用 GD32E230K8U6 也遇到同样问题了,原厂例程 USART1 REA 始终为 0 。
两只袜子 发表于 2024-1-29 20:57 来自手机 | 显示全部楼层
硬件交接或者时钟配置问题
两只袜子 发表于 2024-1-29 20:58 来自手机 | 显示全部楼层
此外还有中断和寄存器配置看看有无问题
吴工康康 发表于 2024-4-17 10:55 | 显示全部楼层
有答复吗?这边也是同样的问题
不要判断这个标志位, 直接用
shenxiaolin 发表于 2024-4-30 16:03 | 显示全部楼层
是不是没有引脚功能重映射?
kzlzqi 发表于 2024-7-31 22:01 | 显示全部楼层
在你的 rs422_uart_init 函数中配置 RS-422 (或 RS-485) 的 UART,发现寄存器 STAT REA 位无法变为 1,这表明接收部分没有正常工作。相同的代码在 USART0 上可以正常工作,说明问题可能与 AS32_UART 相关。
qwerldx 发表于 2025-5-28 11:22 | 显示全部楼层
楼主怎么解决的,我也有同样的问题
