最近参与做了一个扫码设备的上位机软件。
扫码器扫码后读取到数据提交给服务器写入数据库。
那么HID上位机的服务软件该如何写呢?
这里使用Python实现。
相关的资料链接
- https://pypi.org/project/hidapi
- https://trezor.github.io/cython-hidapi/api.html#device-class
- https://trezor.github.io/cython-hidapi/genindex.html
通过PIP的安装方式
示例
功能:查找设备,列出所有设备的所有信息
- import hid
- for device_dict in hid.enumerate():
- keys = list(device_dict.keys())
- keys.sort()
- for key in keys:
- print("%s : %s" % (key, device_dict[key]))
- print()
示例
功能:链接设备、读写操作
- try:
- print("Opening the device")
- h = hid.device()
- h.open(0x534C, 0x0001) # TREZOR VendorID/ProductID
- print("Manufacturer: %s" % h.get_manufacturer_string())
- print("Product: %s" % h.get_product_string())
- print("Serial No: %s" % h.get_serial_number_string())
- # enable non-blocking mode
- h.set_nonblocking(1)
- # write some data to the device
- print("Write the data")
- h.write([0, 63, 35, 35] + [0] * 61)
- # wait
- time.sleep(0.05)
- # read back the answer
- print("Read the data")
- while True:
- d = h.read(64)
- if d:
- print(d)
- else:
- break
- print("Closing the device")
- h.close()
- except IOError as ex:
- print(ex)
- print("You probably don't have the hard-coded device.")
- print("Update the h.open() line in this script with the one")
- print("from the enumeration list output above and try again.")
- print("Done")
