- int main(void)
- u8 t=0;
- int i = 0;
- Init();
- while(1)
- t=KEY_Scan(0); //µÃµ½¼üÖµ
- switch(t)
- case KEY0_PRES:
- depending = (depending + 1) % 7;
- LCD_ShowxNum(80,00,depending,1,16,0);
- break;
- case KEY1_PRES:
- if(depending == 0) {
- pwm_hz += 100;
- tim1 = 72000000 / pwm_hz;
- Init();
- if(depending == 1) {
- pwm_hz += 10;
- Init();
- if(depending == 2) {
- pwm_hz += 1;
- Init();
- if(depending == 3) {
- k += 100;
- tim2 = 1000000 / k;
- TIM2_Config(tim2, 0);
- if(depending == 4) {
- k += 10;
- if(depending == 5) {
- k += 1;
- if(depending == 6) {
- Dac3_Init();
- MYDMA1_Config( (u32) & (DAC->DHR12R1), (u32)WAVE72, 72);
- TIM1_PWM_Init(tim1,0);
- TIM_SetCompare1(TIM1,(tim1 + 1) / 2);
- LCD_ShowString(0,40,200,16,16," Triangle ");
- LCD_ShowxNum(120,20,pwm_hz,5,16,0);
- LCD_ShowxNum(120,40,k,5,16,0);
- break;
- case WKUP_PRES:
- pwm_hz -= 100;
- Init();
- pwm_hz -= 10;
- Init();
- pwm_hz -= 1;
- Init();
- k -= 100;
- k -= 10;
- k -= 1;
- Dac3_Init();
- MYDMA1_Config( (u32) & (DAC->DHR12R1), (u32)SIN72, 72);
- LCD_ShowString(0,40,200,16,16," SIN ");
- break;
- default:
- delay_ms(10);
- void Init(void)
- uart_init(9600);
- delay_init();
- KEY_Init();
- LCD_Init();
- POINT_COLOR=BLUE;//ÉèÖÃ×ÖÌåΪÀ¶É«
- Dac3_Init();
- LCD_ShowString(0,0,200,16,16,"PENDING: ");
- LCD_ShowString(0,20,200,16,16,"WAVE: Square ");
- LCD_ShowString(200,20,200,16,16,"Hz");
- LCD_ShowString(200,40,200,16,16,"Hz");
