[KungFu8位 MCU] 芯旺微KF8F中断编译错误
 楼主| AWAYWSNB 发表于 2025-2-13 14:38 | 显示全部楼层 |阅读模式
KF8CC 编译器在将 C 语言的中断函数(如 void int_fun0() __interrupt (0) 和 void int_fun1() __interrupt (1) )转换为汇编代码时,自动生成了相同的 interrupt_service_routine 标签,从而导致了重复定义错误。这个问题怎么解决??
KungFu 8 MCU Compiler V2.3.2 Rev (Nov 17 2021 11:51:03)
main.asm:441:Error [115] Duplicate label or redefining symbol that cannot be redefined. (interrupt_service_routine)
make: *** [main.o] Error 1
make: Target `all' not remade because of errors.
func._int_fun0        .code
;  PostBlock Stats: dbName = I
;entry:  _int_fun0        ;Function start
; 0 exit points
;; Starting PostCode block
;        .def _int_fun0_function_begin, debug, value=$
;        ::->op : LABEL
;        ::->op : FUNCTION
; 0 exit points
;        ::->op : GET_VALUE_AT_ADDRESS
; R3 resprent for wsave,R4 resprent for ssave, R5 resprent for psave
;        .line        44; "../main.c"        if(T1IF)
        JB        _EIF1_bits, 0
        JMP        _00012_DS_
;        ::->op :*  =
;        .line        46; "../main.c"        T1IF = 0;                                        //清零中断标志
        CLR        _EIF1_bits, 0
;        ::->op : =
;        .line        47; "../main.c"        T1H = 0xFC;                                        //T1计数器重新赋值
        MOV        R0,# 0xfc
        MOV        _T1H, R0
;        ::->op : =
;        .line        48; "../main.c"        T1L = 0x18;
        MOV        R0,# 0x18
        MOV        _T1L, R0
;        ::->op : =
;        .line        50; "../main.c"        SMFlag_Start = 1;  // 设置状态机启动标志位
        MOV        R0,# 0x01
        BANKSEL        _SMFlag_Start
        MOV        _SMFlag_Start, R0
        CLR        (_SMFlag_Start + 1)
;        ::->op : LABEL
;        ::->op : ENDFUNCTION
_00012_DS_
        MOV        R1, R2
        MOV        PCH, R5
        MOV        PSW, R4
        MOV        R0, R3
        IRET
;        .def _int_fun0_function_end, debug, value=$
func._int_fun1        .code
;entry:  _int_fun1        ;Function start
; 0 exit points
;        .def _int_fun1_function_begin, debug, value=$
;        ::->op : LABEL
;        ::->op : FUNCTION
; 0 exit points
;        ::->op : LABEL
_00015_DS_
;        .line        59; "../main.c"        }
        IRET
;        .def _int_fun1_function_end, debug, value=$
 楼主| AWAYWSNB 发表于 2025-2-13 14:43 | 显示全部楼层
型号KF8F3122,有没有大佬知道的?
钟爱柳州 发表于 2025-2-14 11:43 | 显示全部楼层
提供信息有限,可以把详细信息发邮件到support@chipon-ic.com
