- // 马尔科夫链增强平滑版本
- struct MarkovState {
- uint8_t baseHue; // 当前色相
- uint8_t targetHue; // 目标色相(新增)
- uint8_t speed;
- uint8_t targetSpeed; // 新增目标速度
- int8_t direction;
- float directionF; // 新增浮点方向(用于平滑过渡)
- uint8_t intensity;
- MarkovState currentState = {200, 200, 3, 3, 1, 1.0f, 150};
- const uint8_t transitionProb[4][4] = {
- {90, 5, 3, 2}, // 提高保持色相的概率
- {10, 85, 3, 2}, // 降低速度变化频率
- {5, 5, 88, 2}, // 增强方向稳定性
- {3, 2, 2, 93} // 提高强度保持率
- uint32_t z = 0; // 改为32位防溢出
- const float DIRECTION_TRANSITION = 0.1f; // 方向过渡系数
- void applyMarkovTransition() {
- static uint32_t lastChange = 0;
- const uint32_t CHANGE_INTERVAL = 3000; // 延长状态变化间隔
- if(millis() - lastChange < CHANGE_INTERVAL) return;
- lastChange = millis();
- uint8_t randVal = random8();
- uint8_t probSum = 0;
- uint8_t targetDim = 0;
- // 概率累计方式优化
- while(targetDim < 4 && randVal > (probSum += transitionProb[targetDim][targetDim])) {
- targetDim++;
- // 有限渐变状态转移
- switch(targetDim) {
- case 0: // 色相渐变
- currentState.targetHue = constrain(currentState.baseHue + random8(-8, 9), 180, 255);
- break;
- case 1: // 速度渐变
- currentState.targetSpeed = constrain(currentState.speed + random8(-1, 2), 1, 5);
- break;
- case 2: // 方向平滑过渡
- currentState.directionF = -currentState.directionF; // 缓慢反转
- break;
- case 3: // 强度渐变
- currentState.intensity = constrain(currentState.intensity + random8(-8, 9), 100, 200);
- break;
- void smoothUpdateStates() {
- // 色相线性插值
- currentState.baseHue = lerp8by8(currentState.baseHue, currentState.targetHue, 10);
- // 速度指数平滑
- currentState.speed = (currentState.speed * 7 + currentState.targetSpeed * 1) / 8;
- // 方向浮点过渡
- currentState.directionF += (currentState.direction - currentState.directionF) * DIRECTION_TRANSITION;
- void generateWindPattern() {
- const float dirFactor = currentState.directionF; // 使用浮点方向因子
- for(uint8_t y=0; y<MATRIX_HEIGHT; y++) {
- for(uint8_t x=0; x<MATRIX_WIDTH; x++) {
- // 改进的噪声参数(增加Z轴细分)
- uint8_t noise = inoise8(
- (x * 25) + (z * dirFactor * 0.7f),
- y * 35 + z * 0.3f,
- currentState.intensity * 8 + (z >> 6)
- // 循环色相映射(替代硬约束)
- uint8_t hue = currentState.baseHue + map(noise, 0,255, -15,15);
- hue = 180 + ((hue - 180) % 76); // 180-255循环
- // 亮度S曲线处理
- uint8_t val = cubicwave8(noise);
- val = map(val, 30, 225, 50, 220); // 压缩两端
- leds[XY(x,y)] = CHSV(hue, 235, val);
- // 使用标准二维模糊 + 逐行模糊替代方案
- blur2d(leds, MATRIX_WIDTH, MATRIX_HEIGHT, 64);
- // 手动实现行模糊
- CRGB* rowStart = &leds[XY(0, y)];
- blur1d(rowStart, MATRIX_WIDTH, 32);
- z += currentState.speed;
- void wind_vision() {
- static uint32_t lastUpdate = 0;
- if(millis() - lastUpdate > 33) { // 30FPS
- lastUpdate = millis();
- smoothUpdateStates(); // 先更新状态
- applyMarkovTransition();
- generateWindPattern();
- // 添加残影效果
- fadeToBlackBy(leds, NUM_LEDS, 220);
- FastLED.show();
