//---------------------STYLE #2------------------------- module fifo2 (rdata, wfull, rempty, wdata, winc, wclk, wrst_n, rinc, rclk, rrst_n); parameter DSIZE = 8; parameter ASIZE = 4; output [DSIZE-1:0] rdata; output wfull; output rempty; input [DSIZE-1:0] wdata; input winc, wclk, wrst_n; input rinc, rclk, rrst_n; wire [ASIZE-1:0] wptr, rptr; wire [ASIZE-1:0] waddr, raddr;
async_cmp #(ASIZE) async_cmp(.aempty_n(aempty_n), .afull_n(afull_n), .wptr(wptr), .rptr(rptr), .wrst_n(wrst_n));
fifomem2 #(DSIZE, ASIZE) fifomem2(.rdata(rdata), .wdata(wdata), .waddr(wptr), .raddr(rptr), .wclken(winc), .wclk(wclk));
rptr_empty2 #(ASIZE) rptr_empty2(.rempty(rempty), .rptr(rptr), .aempty_n(aempty_n), .rinc(rinc), .rclk(rclk), .rrst_n(rrst_n));
wptr_full2 #(ASIZE) wptr_full2(.wfull(wfull), .wptr(wptr), .afull_n(afull_n), .winc(winc), .wclk(wclk), .wrst_n(wrst_n)); endmodule module fifomem2 (rdata, wdata, waddr, raddr, wclken, wclk); parameter DATASIZE = 8; // Memory data word width parameter ADDRSIZE = 4; // Number of memory address bits parameter DEPTH = 1<<ADDRSIZE; // DEPTH = 2**ADDRSIZE output [DATASIZE-1:0] rdata; input [DATASIZE-1:0] wdata; input [ADDRSIZE-1:0] waddr, raddr; input wclken, wclk; `ifdef VENDORRAM // instantiation of a vendor's dual-port RAM VENDOR_RAM MEM (.dout(rdata), .din(wdata), .waddr(waddr), .raddr(raddr), .wclken(wclken), .clk(wclk)); `else reg [DATASIZE-1:0] MEM [0: DEPTH-1]; assign rdata = MEM[raddr]; always @(posedge wclk) if (wclken) MEM[waddr] <= wdata; `endif endmodule module async_cmp (aempty_n, afull_n, wptr, rptr, wrst_n); parameter ADDRSIZE = 4; parameter N = ADDRSIZE-1; output aempty_n, afull_n; input [N:0] wptr, rptr; input wrst_n; reg direction; wire high = 1'b1; wire dirset_n = ~( (wptr[N]^rptr[N-1]) & ~(wptr[N-1]^rptr[N])); wire dirclr_n = ~((~(wptr[N]^rptr[N-1]) & (wptr[N-1]^rptr[N])) | ~wrst_n); always @(posedge high or negedge dirset_n or negedge dirclr_n) if (!dirclr_n) direction <= 1'b0; else if (!dirset_n) direction <= 1'b1; else direction <= high; //always @(negedge dirset_n or negedge dirclr_n) //if (!dirclr_n) direction <= 1'b0; //else direction <= 1'b1; assign aempty_n = ~((wptr == rptr) && !direction); assign afull_n = ~((wptr == rptr) && direction); endmodule module rptr_empty2 (rempty, rptr, aempty_n, rinc, rclk, rrst_n); parameter ADDRSIZE = 4; output rempty; output [ADDRSIZE-1:0] rptr; input aempty_n; input rinc, rclk, rrst_n; reg [ADDRSIZE-1:0] rptr, rbin; reg rempty, rempty2; wire [ADDRSIZE-1:0] rgnext, rbnext; //--------------------------------------------------------------- // GRAYSTYLE2 pointer //--------------------------------------------------------------- always @(posedge rclk or negedge rrst_n) if (!rrst_n) begin rbin <= 0; rptr <= 0; end else begin rbin <= rbnext; rptr <= rgnext; end //--------------------------------------------------------------- // increment the binary count if not empty //--------------------------------------------------------------- assign rbnext = !rempty ? rbin + rinc : rbin; assign rgnext = (rbnext>>1) ^ rbnext; // binary-to-gray conversion always @(posedge rclk or negedge aempty_n) if (!aempty_n) {rempty,rempty2} <= 2'b11; else {rempty,rempty2} <= {rempty2,~aempty_n}; endmodule module wptr_full2 (wfull, wptr, afull_n, winc, wclk, wrst_n); parameter ADDRSIZE = 4; output wfull; output [ADDRSIZE-1:0] wptr; input afull_n; input winc, wclk, wrst_n; reg [ADDRSIZE-1:0] wptr, wbin; reg wfull, wfull2; wire [ADDRSIZE-1:0] wgnext, wbnext; //--------------------------------------------------------------- // GRAYSTYLE2 pointer //--------------------------------------------------------------- always @(posedge wclk or negedge wrst_n) if (!wrst_n) begin wbin <= 0; wptr <= 0; end else begin wbin <= wbnext; wptr <= wgnext; end //--------------------------------------------------------------- // increment the binary count if not full //--------------------------------------------------------------- assign wbnext = !wfull ? wbin + winc : wbin; assign wgnext = (wbnext>>1) ^ wbnext; // binary-to-gray conversion always @(posedge wclk or negedge wrst_n or negedge afull_n) if (!wrst_n ) {wfull,wfull2} <= 2'b00; else if (!afull_n) {wfull,wfull2} <= 2'b11; else {wfull,wfull2} <= {wfull2,~afull_n}; endmodule
细心的读者会发现,第一种写法(本人做的修改)把所有信号写在同一个module里,而第二种写法则分了很多模块。哪种写法更好呢?有兴趣的可以想一想,事实上,第二种写法是推荐的写法:原因如下: 异步的多时钟设计应按以下几个原则进行设计: 1,尽可能的将多时钟的逻辑电路(非同步器)分割为多个单时钟的模块,这样有利于静态时序分析工具来进行时序验证。 2,同步器的实现应使得所有输入来自同一个时钟域,而使用另一个时钟域的异步时钟信号采样数据。 3,面向时钟信号的命名方式可以帮助我们确定那些在不同异步时钟域间需要处理的信号。 4,当存在多个跨时钟域的控制信号时,我们必须特别注意这些信号,保证这些控制信号到达新的时钟域仍然能够保持正确的顺序。
