用PIC单片机做的白噪声产生
 楼主| zhangmangui 发表于 2013-6-17 11:08 | 显示全部楼层 |阅读模式
下面是汇编的代码   又能看懂的帮忙翻译一下   确认一下是否可行  谢啦
title  "White Noise Generator"
;  Tom Wiltshire for Elecric Druid, March 2008
;  This program provides a replacement for the notorious
;  MM5837 digital noise source chip. It provides pure
;  white noise by outputting random bits at >90KHz.
;  This gives a pure noise spectrum to well above audio
;  range (3dB dip at 45KHz).
;  Hardware Notes:
;   PIC12F675 running at 4 MHz using internal clock
;  The hardware is very simple. There are no inputs.
; One output
;   GP4: NOISE output
        list      p=12f675           ; list directive to define processor
        #include <p12f675.inc>        ; processor specific variable definitions
        errorlevel  -302              ; suppress message 302 from list file
        __CONFIG   _CP_OFF & _CPD_OFF & _BODEN_OFF & _MCLRE_OFF & _WDT_OFF & _PWRTE_ON & _INTRC_OSC_NOCLKOUT
;        Variables
CBLOCK 0x020
        ; LFSR 1, a 31-bit register
        LFSR1_1
        LFSR1_2
        LFSR1_3
        LFSR1_4
        ; LFSR 2, a 23-bit register
        LFSR2_1
        LFSR2_2
        LFSR2_3
        ; Temporary storage
        TEMP
ENDC
;        DEFINE STATEMENTS
; Useful bit definitions for clarity
#define ZEROBIT                STATUS,Z        ; Zero Flag
#define CARRY                STATUS,C        ; Carry Flag
#define BORROW                STATUS,C        ; Borrow is the same as Carry
; Begin Executable Code Segment
        org     0x000                ; processor reset vector
        goto        Main                ; Avoid the interrupt vector
;        org     0x004           ; interrupt vector location
Main:
; Do the setting up
        bsf        STATUS, RP0        ; Bank 1
;        call        0x3FF                ; Retrieve factory calibration value
;        movwf   OSCCAL                ; Store cal value
        clrf        ANSEL                ; Turn off analog inputs
        movlw   b'101111'        ; GP4 Output, all others unused inputs
        movwf   TRISIO
        bcf        STATUS, RP0        ; Bank 0
        clrf        GPIO
        movlw        0x07
        movwf        CMCON
        ; Set up initial values of the registers
        movlw        0x45
        movwf        LFSR1_1
        movlw        0x57
        movwf        LFSR1_2
        movlw        0x9F
        movwf        LFSR1_3
        movlw        0xF2
        movwf        LFSR1_4
        movlw        0xD7
        movwf        LFSR2_1
        movlw        0xC8
        movwf        LFSR2_2
        movlw        0x79
        movwf        LFSR2_3
MainLoop:
;        movlw        0x3F
;        movwf        GPIO
;        movlw        0xFF
;        movwf        TEMP
;DelayLoop:
;        nop
;        nop
;        decfsz        TEMP, F
;        goto        DelayLoop
;        clrf        GPIO
;        movlw        0xFF
;        movwf        TEMP
;DelayLoop2:
;        nop
;        nop
;        decfsz        TEMP, F
;        goto        DelayLoop2
;        goto        MainLoop
; 31-bit LFSR with taps at 31 and 28
        swapf        LFSR1_4, W        ; Get bit 28
        movwf        TEMP
        rlf        LFSR1_4, W        ; Get bit 31
        xorwf        TEMP, F
        ; Shift the XORd bit into carry
        rlf        TEMP, F
        ; Shift the register
        rlf        LFSR1_1, F
        rlf        LFSR1_2, F
        rlf        LFSR1_3, F
        rlf        LFSR1_4, F
        ; Output the noise bit
        movf        LFSR1_1, W
        movwf        GPIO
; 21-bit LFSR with taps at 21 and 19
        rrf        LFSR2_3, W        ; Get bit 19
        movwf        TEMP
        rrf        TEMP, F
        swapf        LFSR2_3, W        ; Get bit 21
        xorwf        TEMP, F
        rrf        TEMP, F
        rlf        LFSR2_1, F
        rlf        LFSR2_2, F
        rlf        LFSR2_3, F
        movf        LFSR2_1, W
        movwf        GPIO
        goto        MainLoop
; We never reach here
        end
wangch_sh 发表于 2014-9-9 15:36 | 显示全部楼层
汇编代码看起来很费劲的
yewuyi 发表于 2014-9-9 16:11 | 显示全部楼层
LZ这个像是反汇编的代码。
白噪声要结合硬件,纯粹的软件运算弄不出白噪声。
zhimagod 发表于 2014-9-9 17:33 | 显示全部楼层
这个看起来就是把一串数组一位一位发送出去……
个人签名:欢迎进入【TI DSP 论坛】 & 【DSP 技术】           TI忠诚粉丝!
935
