PIC单片机编译问题求解
 楼主| zhengxinydc 发表于 2014-1-10 11:50 | 显示全部楼层 |阅读模式
各位高手,本人新手一个,出现以下问题求解!编译成功了,但程序不能运行,配置位:内部振荡,关看门狗等。用的是PICC8.05版本的编译器。谢谢!
Clean: Deleting intermediary and output files.
Clean: Deleted file "D:\zqq20140108\zqq.obj".
Clean: Deleted file "D:\zqq20140108\zqq.cce".
Clean: Deleted file "D:\zqq20140108\zqq.lde".
Clean: Deleted file "zqq.cof".
Clean: Done.
Executing: "C:\HT-PIC\bin\picc.exe" -C -E"zqq.cce" "zqq.c" -O"zqq.obj" -Zg9 -O -Q -MPLAB -12F508
Executing: "C:\HT-PIC\bin\picc.exe" -E"zqq.lde" "D:\zqq20140108\zqq.obj" -O"zqq.cof" -O"zqq.hex" -Q -MPLAB -12F508
Memory Usage Map:
Program ROM   $0000 - $0021  $0022 (    34) words
Program ROM   $015C - $01FE  $00A3 (   163) words
                             $00C5 (   197) words total Program ROM
Bank 0 RAM    $0007 - $001E  $0018 (    24) bytes total Bank 0 RAM
Program statistics:
Total ROM used      197 words (38.6%)
Total RAM used       24 bytes (96.0%)
Loaded D:\zqq20140108\zqq.cof.
BUILD SUCCEEDED: Fri Jan 10 11:37:36 2014
chen3bing 发表于 2014-9-22 10:53 | 显示全部楼层
哪个片子?程序?
jinjian75 发表于 2014-9-24 08:42 | 显示全部楼层
芯片应该是12F508 查查你的程序呗
jinjian75 发表于 2014-9-24 08:44 | 显示全部楼层
那么老的帖子 怎么被翻出来了啊?
