[i.MX] Yocto Building Error
 楼主| loye 发表于 2014-12-11 21:43 | 显示全部楼层 |阅读模式
ERROR: QA Issue: File '/usr/bin/vconfig' from vlan was already stripped, this will prevent future debugging!
ERROR: QA run found fatal errors. Please consider fixing them.
ERROR: Function failed: do_package_qa
ERROR: Logfile of failure stored in: /home/fresxc/bin/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/vlan/1.9-r0/temp/log.do_package.7018
ERROR: Task 2684 (/home/fresxc/bin/fsl-release-bsp/sources/meta-fsl-bsp-release/imx/meta-fsl-demos/recipes-connectivity/vlan/vlan_1.9.bb, do_package) failed with exit code '1'
bitbake fsl-image-x11时,出现以上错误,不知如何解决,特此求教,感激不尽~~~
FSL_TICS_Jeremy 发表于 2015-2-12 17:32 | 显示全部楼层
楼主你好
通过和我们I.MX工程师的沟通:
建议你将此问题按照帖子   飞思卡尔申请样片与购买的论坛VIP通道开通了,小伙伴速来!   提交一个服务请求:
如果你尚未注册飞思卡尔官网账号,请先点击注册按钮:右侧图标完成注册。
如果你已有飞思卡尔官网账号,可以点击申请SR按钮:右侧图标提交一个服务请求。
最好使用英文详细描述一下遇到的问题,以便国内外工程师都能够帮助到你
