[资料分享与下载] 飞思卡尔单片机DZ60---时钟初始化
niuyaliang 发表于 2015-2-27 19:40 | 显示全部楼层 |阅读模式
  1. [cpp] view plaincopy
  2. /* Derivative peripheral declarations */
  3. #include "derivative.h"
  4.
  5. /* Definitions and function prototypes */
  6. #include "DZ60_init.h"
  7.
  8. //FEI切换到PEE模式,外部晶振=4MHZ,总线频率=8MHZ(  中文手册,P144页)
  9. /* External crystal oscillator = 4MHz */
  10. /* FOR PEE mode:
  11. Bus_Clock = (1/2)*[(Osc_clock/Ref_div)*VCO_div]/(Bus_div) = 8MHz */
  12.
  13. #define BUS_DIV 0       /* Bus divider = 0, divide by 1 */
  14. #define REF_DIV 2       /* Reference divider = 2, divide by 4 */
  15. #define VCO_DIV 4       /* VCO divider = 4, multiply by 16 */
  16.
  17.
  18. void MCG_Init(void)
  19. {
  20.    SOPT1_COPT = 0;
  21.
  22. //1
  23.    //a)
  24.     MCGC2_BDIV    = BUS_DIV; //0
  25.     MCGC2_RANGE   = 1;
  26.     MCGC2_HGO     = 1;
  27.     MCGC2_EREFS   = 1;
  28.     MCGC2_ERCLKEN = 1;
  29.
  30.     //b)
  31.     while(!MCGSC_OSCINIT); //循环检测,表明EREFS选择的晶体已经完成初始化
  32.
  33.     //c)
  34.     MCGC1_CLKS = 0X02;
  35.     MCGC1_RDIV = 0X07;
  36.     MCGC1_IREFS = 0;
  37.
  38.     //d)
  39.     while( MCGSC_IREFST );
  40.
  41.     //e)
  42.     while( (MCGSC_CLKST ^ 0X02));
  43.
  44. //2
  45.     //a)
  46.     MCGC2_LP = 1;
  47.
  48.     //b)
  49.     MCGC1_RDIV = REF_DIV;//2;
  50.
  51.     //c)
  52.     MCGC3_PLLS = 1;
  53.     MCGC3_VDIV = VCO_DIV;//4;
  54.
  55.     //d)
  56.     MCGC2_LP = 0;
  57.
  58.
  59.     //e)
  60.     while(!MCGSC_PLLST);
  61.
  62.
  63.     //f)
  64.     while(!MCGSC_LOCK);
  65.
  66.   //3
  67.     //a)
  68.     MCGC1_CLKS = 0X00;
  69.
  70.     //b)
  71.     while((MCGSC_CLKST ^ 0X03));
  72.
  73. }
 楼主| niuyaliang 发表于 2015-2-27 19:45 | 显示全部楼层
  2. <pre class="cpp" name="code">/******************************************************************************************
  3. | FUNCTION NAME    :  MCU_SetBusClock
  4. | CALLED BY        :  xxxx
  5. | PRECONDITIONS    :  xxxx
  6. | INPUT PARAMETERS :  xxxx
  7. | OUTPUT PARAMETERS:  xxxx
  8. | RETURN VALUE     :  xxxx
  9. | DESCRIPTION      :  set MCGOUT and bus frequency,BDIV = 1, VDIV = 16, RDIV = 4, OSC = 4.332MHz
  10. |                     MCGOUT = [(OSC / RDIV) * VDIV] / BDIV;
  11. |                     MCGOUT = [(4.332MHz / 4) * 16] / 1 = 17.328MHz;
  12. |                     Bus frequency = MCGOUT / 2 = 8.664MHz
  13. | NOTE             :  xxxx
  14. |*******************************************************************************************/
  15.
  16. void MCU_SetBusClock(void)    /* XOSC 4.332MHZ,BUS clock 8.664MHZ */
  17. {
  18.
  19.   //SOPT1 = 0;                  /* STOP WATCH DOG */
  20.    SOPT1_COPT =3;               /* enable watchdog 1s timeout*/
  21.   /*After RESET start in FEI Mode
  22.   FEI > FBE     ***************************************
  23.   Set MCGC2:
  24.   BDIV[6:7] | RANGE | HGO | LP | EFERS | ERCLKEN | EREFSTEN | */
  25.   MCGC2 = 0X36;
  26.   while(!MCGSC_OSCINIT);      /* Wait till OSCINIT in MCGSC is one */
  27.   _asm SEI;                   /* MUST BLOCK INTERRUPTS  */
  28.   MCGC1 = 0XB8;               /* Set MCGC1:| CLKS[6:7] | RDIV[3:5] | IREFS | IRCLKEN | IREFSTEN | */
  29.   while(MCGSC_IREFST);        /* Wait till IRFEST in MCGSC is zero */
  30.   while((MCGSC_CLKST)^(0x02));/* Wait till external clock source is selected */
  31.
  32.   /* FBE > BLPE **************************************** */
  33.   MCGC2_LP = 1;
  34.   MCGC1 = 0X90;               /* Set the range of frequency divider  4.332m/4  (1mhz~2mhz) */
  35.   MCGC3 = 0X44;
  36.   while(!MCGSC_PLLST);        /* Wait till Source of PLLS clock is set to PLL clock */
  37.
  38.   /* BLPE > PBE **************************************** */
  39.   /* Clear LP to switch to PBE Mode*/
  40.   MCGC2_LP = 0;
  41.   while(!MCGSC_LOCK);         /* Wait for PLL to lock */
  42.
  43.   /* PBE > PEE ***************************************** */
  44.   /* Select clock source */
  45.   MCGC1 = 0X10;
  46.     while((MCGSC_CLKST)^(0x03));/* Check if output of the PLL is selected as current clock mode */
  47.   _asm CLI;                   /* CAN ENEBLE INTERRUPTS */
  48. }</pre><br>
  49. <pre></pre>
  50. <p> </p>
  51. <p> </p>
  52. <p> </p>
  53. <p> </p>
  54. <p> </p>
  55. <p>  </p>
  56. <pre> </pre>
  57. <pre> </pre>
  58. <pre></pre>
  59. <pre></pre>
  60. <pre></pre>
ccw1986 发表于 2015-2-28 08:43 | 显示全部楼层
谢谢分享啊
