手头一个项目,用SL811 + usb hub 芯片 + 读卡器芯片来做一个方案。 我移植了SL811的地址和中断, 但是发现板子还不能工作。
linux启动过程如下。 请大侠帮我看一下我的usb驱动现在是哪里出问题了。是读写hub芯片出问题了么? 谢谢了!
Loading .text @ 0x00001000 (1272816 bytes) Loading .rodata @ 0x00138000 (307972 bytes) Loading __ksymtab @ 0x00183304 (15016 bytes) Loading __ksymtab_gpl @ 0x00186dac (4264 bytes) Loading __ksymtab_gpl_future @ 0x00187e54 (24 bytes) Loading __ksymtab_strings @ 0x00187e6c (46376 bytes) Loading __param @ 0x00193394 (420 bytes) Loading .data @ 0x00194000 (73728 bytes) Loading .init.text @ 0x001a6000 (90768 bytes) Loading .init.data @ 0x001bc290 (3240 bytes) Loading .init.setup @ 0x001bcf38 (584 bytes) Loading .initcall.init @ 0x001bd180 (444 bytes) Loading .con_initcall.init @ 0x001bd33c (4 bytes) Loading .init.ramfs @ 0x001bd340 (5388800 bytes) Loading .text_l1 @ 0xffa00000 (5732 bytes) sh_addr: FFA00000, p_paddr: 006E0D40 Loading from: 016E1000 to 006E0D40, size: 5732 Loading .data_l1 @ 0xff800000 (192 bytes) sh_addr: FF800000, p_paddr: 006E23A4 Loading from: 016E3000 to 006E23A4, size: 192 Clearing .bss @ 0x006e3000 (63120 bytes) ## Starting application at 0x001a6000 ... Linux version 2.6.22.18-ADI-2008R1-svn (root@localhost.localdomain) (gcc version 4.1.2 (ADI svn)) #39 Thu Jul 10 16:26:42 CST 2008 early printk enabled on early_BFuart0 Hardware Trace Active and Enabled Blackfin support (C) 2004-2007 Analog Devices, Inc. Compiled for ADSP-BF527 Rev 0.0 Warning: Unsupported Chip Revision ADSP-BF527 Rev 0.0 detected Blackfin Linux support by http://blackfin.uclinux.org/ Processor Speed: 387 MHz core clock and 96 MHz System Clock Board Memory: 32MB Kernel Managed Memory: 32MB Memory map: text = 0x00001000-0x00137bf0 rodata = 0x00138000-0x00193538 data = 0x00194000-0x001a6000 stack = 0x00194000-0x00196000 init = 0x001a6000-0x006e3000 bss = 0x006e3000-0x006f2690 available = 0x006f2690-0x01eff000 DMA Zone = 0x01f00000-0x02000000 Instruction Cache Enabled Data Cache Enabled (write-through) Built 1 zonelists. Total pages: 7874 Kernel command line: root=/dev/mtdblock0 rw earlyprintk=serial,uart1,57600 console=tty0 console=ttyBF0,57600 Configuring Blackfin Priority Driven Interrupts PID hash table entries: 128 (order: 7, 512 bytes) console handover: boot [early_BFuart0] -> real [ttyBF0] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes) Inode-cache hash table entries: 2048 (order: 1, 8192 bytes) Memory available: 24328k/32768k RAM, (5364k init code, 1242k kernel code, 503k data, 1024k dma, 304k reserved) Blackfin Scratchpad data SRAM: 4 KB Blackfin Data A SRAM: 16 KB (15 KB free) Blackfin Data B SRAM: 16 KB (16 KB free) Blackfin Instruction SRAM: 48 KB (42 KB free) Security Framework v1.0.0 initialized Mount-cache hash table entries: 512 NET: Registered protocol family 16 Blackfin GPIO Controller Blackfin DMA Controller stamp_init(): registering device resources Generic PHY: Registered new driver usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 1024 (order: 1, 8192 bytes) TCP bind hash table entries: 1024 (order: 0, 4096 bytes) TCP: Hash tables configured (established 1024 bind 1024) TCP reno registered NTFS driver 2.1.28 [Flags: R/W DEBUG]. io scheduler noop registered io scheduler anticipatory registered (default) io scheduler cfq registered bfin-otp: initialized bfin-wdt: initialized: timeout=20 sec (nowayout=0) Serial: Blackfin serial driver bfin-uart.1: ttyBF0 at MMIO 0xffc02000 (irq = 31) is a BFIN-UART RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize bfin_mac_mdio: probed bfin_mac: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0:00, irq=-1, mdc_clk=2500000Hz(mdc_div=18)@sclk=96MHz) bfin_mac: Version 1.1, Blackfin BF53[67] BF527 on-chip Ethernet MAC driver bfin-spi bfin-spi.0: Blackfin BF5xx on-chip SPI Contoller Driver, Version 1.0, regs_base@ffc00500, dma channel@7 sl811: driver sl811-hcd, 19 May 2005 SL811 is probing sl811-hcd sl811-hcd.0: SL811HS v1.5 sl811-hcd sl811-hcd.0: new USB bus registered, assigned bus number 1 sl811-hcd sl811-hcd.0: irq 87, io mem 0x20100000 usb usb1: Product: SL811HS v1.5 usb usb1: Manufacturer: Linux 2.6.22.18-ADI-2008R1-svn sl811-hcd usb usb1: SerialNumber: sl811-hcd.0 usb usb1: configuration #1 chosen from 1 choice hub 1-0:1.0: USB hub found hub 1-0:1.0: 1 port detected rtc-bfin rtc-bfin: rtc core: registered rtc-bfin as rtc0 TCP cubic registered NET: Registered protocol family 1 NET: Registered protocol family 17 rtc-bfin rtc-bfin: setting the system clock to 1970-01-01 00:08:50 (530) Freeing unused kernel memory: 5364k freed speed=full usb 1-1: new full speed USB device using sl811-hcd and address 2 _____________________________________ a8888b. / Welcome to the uClinux distribution \ d888888b. / _ _ \ 8P"YP"Y88 / | | |_| __ __ (TM) | 8|o||o|88 _____/ | | _ ____ _ _ \ \/ / | 8' .88 \ | | | | _ \| | | | \ / | 8`._.' Y8. \ | |__ | | | | | |_| | / \ | d/ `8b. \ \____||_|_| |_|\____|/_/\_\ | dP . Y8b. \ For embedded processors including | d8:' " `::88b \ the Analog Devices Blackfin / d8" 'Y88b \___________________________________/ :8P ' :888 8a. : _a88P For further information, check out: ._/"Yaa_: .| 88P| - http://blackfin.uclinux.org/ \ YP" `| 8P `. - http://docs.blackfin.uclinux.org/ / \.___.d| .' - http://www.uclinux.org/ `--..__)8888P`._.' jgs/a:f - http://www.analog.com/blackfin
Have a lot of fun...
BusyBox v1.4.1 (2008-03-21 18:17:38 CST) Built-in shell (msh) Enter 'help' for a list of built-in commands.
root:/> usb 1-1: device not accepting address 2, error -110 speed=full usb 1-1: new full speed USB device using sl811-hcd and address 3 usb 1-1: unable to read config index 0 descriptor/start usb 1-1: chopping to 0 config(s) usb 1-1: string descriptor 0 read error: -110 usb 1-1: no configuration chosen from 0 choices |
