[DemoCode下载] 新唐MINI51 PWM初始化设置及应用
 楼主| C洛达尔多 发表于 2016-3-8 20:40 | 显示全部楼层 |阅读模式
  1. #include "Register_Bit.h"   //包含位定义文件
  2. //#define       PWM_DIV1    (uint8_t)1  //不能设置1分频 否则定时器停止工作
  3. #define     PWM_DIV2    (uint8_t)2
  4. #define     PWM_DIV4    (uint8_t)4
  5. #define     PWM_DIV8    (uint8_t)8
  6. #define     PWM_CYC (uint16_t)750
  7. #define     PWM1_CPIEN_ENB  PIER |= (1<<9) //使能PWM1比较中断 用于检测过流
  8. #define     PWM1_CPIEN_DIS  PIER &= ~(1<<9)
  9. #define     PWM0_PIN_ENB    PWMPOE |= (PWM0_OE)//PWMPOE |= (1<<0)
  10. #define     PWM0_PIN_DIS    PWMPOE  &= ~(PWM0_OE)
  11. #define     PWM2_PIN_ENB    PWMPOE  |= (PWM2_OE)
  12. #define     PWM2_PIN_DIS    PWMPOE  &= ~(PWM2_OE)
  13. #define     PWM4_PIN_ENB    PWMPOE  |= (PWM4_OE)
  14. #define     PWM4_PIN_DIS    PWMPOE  &= ~(PWM4_OE)
  15. //*************************************
  16. // 函数名称:Init_PWM
  17. // 函数功能:PWM定时器分频系数 PWM重载值
  18. // 入口参数:无
  19. // 出口参数:无
  20. //***************************************/
  21. void Init_PWM(uint8_t psc,uint32_t Tcon)
  22. {
  23.     uint8_t  Tmp = 0 ;
  24.     /* Select PWM01 clock source as HCLK */
  25.     CLKSEL1 = (CLKSEL1 & (~PWM01_CLK)) | PWM01_HCLK;
  26.     /* Select PWM23 clock source as HCLK */
  27.     CLKSEL1 = (CLKSEL1 & (~PWM23_CLK)) | PWM23_HCLK;
  28.     /* Select PWM45 clock source as HCLK */
  29.     CLKSEL2 = (CLKSEL2 & (~PWM45_CLK)) | PWM45_HCLK;
  30.     /* Switch P2.2~P2.4 P2.6 to PWM0 2 4 output */
  31.     P2_MFP = P2_MFP & (~(P22_MFSEL | P24_MFSEL | P26_MFSEL))
  32.              | (P22_PWM0 | P24_PWM2 | P26_PWM4);
  33.     /* Reset PWM IP  外设先复位再使能 */
  34.     IPRSTC2 |= PWM_RST;
  35.     IPRSTC2 &= ~PWM_RST;
  36.     /* Enable pwm01 23 45 clock source */
  37.     APBCLK |= PWM01_CLKEN ;
  38.     APBCLK |= PWM23_CLKEN ;
  39.     APBCLK |= PWM45_CLKEN ;
  40.     //PWM 预分频
  41.     Tmp = psc - 1 ;   //不能设置1分频 否则定时器停止工作
  42.     PPR |= (Tmp << 0) | (Tmp << 8) | (Tmp << 16);
  43.     //时钟源选择 在PWM输入时钟时分频 现设置不分频 T0-T5
  44.     /* Select PWM0~5 clock divider */
  45.     CSR |= (CSR0_CLK_1 | CSR1_CLK_1 | CSR2_CLK_1
  46.             | CSR3_CLK_1 | CSR4_CLK_1 | CSR5_CLK_1);
  47.     /* Select PWM edge-aligned. */
  48.     PCR &= EDGE_ALIGN;
  49.     /* PWM under auto-reload (continuous) mode, select output channel non-invertion, set independent mode */
  50.     PCR = PCR & (~PWMMODE) | INDEPENDENT;   //独立模式
  51.     PCR |= (CH0_AU_RL | CH2_AU_RL | CH4_AU_RL
  52.            | CH1_AU_RL | CH3_AU_RL | CH5_AU_RL);    //自动重载
  53.      //设置组模式 PWM0 PWM2 PWM4 同步由PWM0控制
  54.      PCR |= (1<<30) ;
  55.      //PWM 计数重载值
  56.      CNR0 = Tcon ;//1500
  57.      CNR2 = Tcon ;
  58.      CNR4 = Tcon ;
  59. /*
  60.      CNR1 = Tcon ;
  61.      CNR3 = Tcon ;
  62.      CNR5 = Tcon ;
  63.     */
  64.      //PWM占空比寄存器
  65.      CMR0 = 0 ;
  66.      CMR2 = 0 ;
  67.      CMR4 = 0 ;
  68. /*
  69.      CMR1 = 0 ;
  70.      CMR3 = 0 ;
  71.      CMR5 = 0 ;
  72.      */
  73.     /* Reset PWM counter */
  74.     PCR |= CLRPWM;
  75.     PWMPOE  &= 0X00 ; //禁止使能PWM0 PWM2 PWM4 输出到引脚上
  76.     /* PWM circuit enable and start to run 开始计数 */
  77.     PCR |= (CH0EN | CH2EN | CH4EN);
  78.     PCR |= (CH1EN);
  79. }
  80. //*************************************
  81. // 函数名称:ToPwm_Value
  82. // 函数功能:重置PWM比较寄存器 ->设置占空比
  83. // 入口参数:占空比参数
  84. // 出口参数:无
  85. //***************************************/
  86. void ToPwm_Value(uint16_t InValue)
  87. {
  88.      CMR0 = InValue ;   //组模式下 PWM2 PWM4 与PWM0同步
  89. //   CMR2 = InValue ;
  90. //   CMR4 = InValue ;
  91. }
  92. //---实例应用------
  93.     //设置8KPWM
  94.     Init_PWM(PWM_DIV2,PWM_CYC) ;    //12M/2=6M 计750次 8M_PWM
734774645 发表于 2016-3-8 22:15 | 显示全部楼层
此例子为何没有提供系统时钟配置的函数呢,还是只是一个完整程序的一部分呢。
