1.我的小车在遇到左边的黑线时停不下来,慢慢开是能停的。。是我的程序太臃肿了嘛
2.我想在我的小车上实现,在条件达成之后在冲一段时间,这在程序中怎么实现
附程序,希望大佬们帮帮我这个菜鸟,第一次做小车
- #include <reg52.h>
- #define uint unsigned int
- unsigned char zifuchuan[]="abcd"; //待显示字符
- volatile unsigned char sending;
- int add_left1,add_left2,add_right1,add_right2;
- int flag=0;
- int flag2=0;
- int r,l,z=0;
- /*******PWM波调节参数********/
- #define push_left1 1
- #define push_left2 1
- #define push_right1 1
- #define push_right2 1
- /*******黑白检测传感器输出********/
- sbit sign_left1=P2^0;
- sbit sign_left2=P2^1;
- sbit sign_left3=P2^2;
- //sbit sign_right1=P2^2;
- sbit sign_left4=P2^3;
- sbit sign_right1=P2^4;
- sbit sign_right2=P2^5;
- sbit sign_right3=P2^6;
- sbit sign_back2=P2^7;
- sbit sign_back=P3^1;
- /*******四轮电机信号输入********/
- sbit left_moto1_in1=P0^0;
- sbit left_moto1_in2=P0^1;
- sbit left_moto2_in1=P0^2;
- sbit left_moto2_in2=P0^3;
- sbit right_moto1_in1=P0^4;
- sbit right_moto1_in2=P0^5;
- sbit right_moto2_in1=P0^6;
- sbit right_moto2_in2=P0^7;
- /*******四轮电机信号使能********/
- sbit Left_moto1_pwm_ENA=P1^0;
- sbit Left_moto2_pwm_ENB=P1^1;
- sbit Right_moto1_pwm_ENA=P1^2;
- sbit Right_moto2_pwm_ENB=P1^3;
- /*******电机占空比参量定义********/
- unsigned char pwm_val_left1 =0; //变量定义
- unsigned char push_val_left1 =0; //左1电机占空比N/10
- unsigned char pwm_val_left2 =0; //变量定义
- unsigned char push_val_left2 =0; //左2电机占空比N/10
- unsigned char pwm_val_right1 =0; //变量定义
- unsigned char push_val_right1=0; //右电机占空比N/10
- unsigned char pwm_val_right2 =0; //变量定义
- unsigned char push_val_right2=0; //右电机占空比N/10
- bit Left_moto1_stop =1;
- bit Left_moto2_stop =1;
- bit Right_moto1_stop=1;
- bit Right_moto2_stop=1;
- unsigned int time=0;
- /*******左1电机前进********/
- void left_moto1_go()
- left_moto1_in1=1;
- left_moto1_in2=0;
- /*******左1电机后退********/
- void left_moto1_back()
- left_moto1_in1=0;
- left_moto1_in2=1;
- /*******左1电机停止********/
- void left_moto1_stp()
- left_moto1_in1=0;
- left_moto1_in2=0;
- /*******左2电机前进********/
- void left_moto2_go()
- left_moto2_in1=1;
- left_moto2_in2=0;
- /*******左2电机后退********/
- void left_moto2_back()
- left_moto2_in1=0;
- left_moto2_in2=1;
- /*******左2电机停止********/
- void left_moto2_stp()
- left_moto2_in1=0;
- left_moto2_in2=0;
- /*******右1电机前进********/
- void right_moto1_go()
- right_moto1_in1=1;
- right_moto1_in2=0;
- /*******右1电机后退********/
- void right_moto1_back()
- right_moto1_in1=0;
- right_moto1_in2=1;
- /*******右1电机停止********/
- void right_moto1_stp()
- /*******右2电机前进********/
- void right_moto2_go()
- right_moto2_in1=1;
- right_moto2_in2=0;
- /*******右2电机后退********/
- void right_moto2_back()
- right_moto2_in1=0;
- right_moto2_in2=1;
- /*******右2电机停止********/
- void right_moto2_stp()
- /*******小车停止********/
- void car_stp()
- push_val_left1 = push_left1+add_left1; //PWM 调节参数1-10 1为最慢,10是最快 改这个值可以改变其速度
- push_val_left2 = push_left2+add_left2;
- push_val_right1 = push_right1+add_right1; //PWM 调节参数1-10 1为最慢,10是最快 改这个值可以改变其速度
- push_val_right2 = push_right2+add_right2;
- left_moto1_stp();
- left_moto2_stp();
- right_moto1_stp();
- right_moto2_stp();
- /*******小车直线前进********/
- void car_run_straight()
- left_moto1_go();
- left_moto2_go();
- right_moto1_go();
- right_moto2_go();
- /*********小车右转**********/
- void car_turn_left()
- right_moto1_go();
- right_moto2_go();
- left_moto1_stp();
- left_moto2_stp();
- /*********小车左转**********/
- void car_turn_right()
- left_moto1_stp();
- left_moto2_stp();
- right_moto1_go();
- right_moto2_go();
- void car_translate_right()
- left_moto1_go();
- left_moto2_back();
- right_moto1_back();
- right_moto2_go();
- /*******左1电机调速(调节push_val_left的值改变电机转速,占空比)********/
- void pwm_out_left_moto1(void)
- if(Left_moto1_stop)
- if(pwm_val_left1<=push_val_left1)
- Left_moto1_pwm_ENA=1;
- else
- Left_moto1_pwm_ENA=0;
- if(pwm_val_left1>=10)
- pwm_val_left1=0;
- else
- /*******左2电机调速(调节push_val_left的值改变电机转速,占空比)********/
- void pwm_out_left_moto2(void)
- if(Left_moto2_stop)
- if(pwm_val_left2<=push_val_left2)
- Left_moto2_pwm_ENB=1;
- else
- Left_moto2_pwm_ENB=0;
- if(pwm_val_left2>=10)
- pwm_val_left2=0;
- else
- /*******右1电机调速(调节push_val_left的值改变电机转速,占空比)********/
- void pwm_out_right_moto1(void)
- if(Right_moto1_stop)
- if(pwm_val_right1<=push_val_right1)
- Right_moto1_pwm_ENA=1;
- else
- Right_moto1_pwm_ENA=0;
- if(pwm_val_right1>=10)
- pwm_val_right1=0;
- else
- /*******右2电机调速(调节push_val_left的值改变电机转速,占空比)********/
- void pwm_out_right_moto2(void)
- if(Right_moto2_stop)
- if(pwm_val_right2<=push_val_right2)
- Right_moto2_pwm_ENB=1;
- else
- Right_moto2_pwm_ENB=0;
- if(pwm_val_right2>=10)
- pwm_val_right2=0;
- else
- * 名称 : Delay()
- * 功能 : 延时,延时时间为 10ms * del
- void Delay(uint del)
- uint i,j;
- for(i=0; i<del; i++)
- for(j=0; j<1827; j++)
- /*******串口初始化********/
- void initcom(void)
- EA=0; //暂时关闭中断
- AUXR=0x15;
- BRT=0xdc;
- SCON=0x50; //串口工作在模式1
- ES=1; //串行中断允许
- REN=1; //允许接收
- EA=1; //允许中断
- /*******定时器0和定时器1初始化********/
- void initime(void)
- EA=0; //暂时关闭中断
- TMOD=0x11; //模式1设置(M1=0,M0=1)
- TR0=1; //打开定时器
- TH0=0XFC; //1Ms定时定时器设置,每隔1Ms发起一次中断。
- TL0=0X18;
- ET0=1; //开定时器0中断
- TR1=1;
- TH1=0Xfd; //定时器设置,每隔100微秒发起一次中断。
- TL1=0xfd;
- ET1=1; //开定时器1中断
- EA=1; //允许中断
- /*********发送一个字节的数据,形参d即为待发送数据**********/
- void send(unsigned char d)
- SBUF=d; //将数据写入到串口缓冲
- sending=1; //设置发送标志
- while(sending); //等待发送完毕
- /**********发送字符串,直到遇到0才结束**********/
- void sendc(unsigned char * pd)
- int n;
- /* while((*pd)!='\0')
- send(*pd); //发送一个字符
- pd++; //移动到下一个字符
- for(n=0;n<5;n++)
- ES=0;
- SBUF=pd[n];
- while(!TI);
- TI=0;
- // while((*pd)!='\0')
- // send(*pd); //发送一个字符
- // pd++; //移动到下一个字符
- /**********主程序**********/
- void main()
- initcom(); //串口初始化
- initime(); //定时器0和定时器1初始化
- IPH=IPH|0x10;
- IP=IP|0x10;
- sign_left1=1;
- sign_left2=1;
- sign_left3=1;
- add_left1=3;
- add_left2=3;
- add_right1=3;
- add_right2=3;
- flag=1;
- sign_back=1;
- while(1)
- if(flag==1&&sign_left1==0&&sign_left2==1&&sign_left3==0&&sign_left4==0&&sign_right2==0&&sign_right3==0)//中间灯扫描
- add_left1=2;
- add_left2=2;
- add_right1=2;
- add_right2=2;
- car_run_straight();
- if(flag==1&&sign_left1==0&&sign_left2==0&&sign_left3==1&&sign_left4==0&&sign_right2==0&&sign_right3==0)//中间灯扫描
- add_left1=2;
- add_left2=2;
- add_right1=2;
- add_right2=2;
- if(flag==1&&sign_left1==0&&sign_left2==1&&sign_left3==1&&sign_left4==0&&sign_right2==0&&sign_right3==0)//中间灯扫描
- add_left1=2;
- add_left2=2;
- add_right1=2;
- add_right2=2;
- if(flag==1&&sign_left1==1&&sign_left2==0&&sign_left3==0&&sign_left4==0&&sign_right2==0&&sign_right3==0)//左边碰黑线一个灯 右转
- add_right1=2;
- add_right2=2;
- add_left1=3;
- add_left2=3;
- left_moto1_go();
- left_moto2_go();
- right_moto2_back();
- if(flag==1&&sign_left1==0&&sign_left2==0&&sign_left3==0&&sign_left4==1&&sign_right2==0&&sign_right3==0)//右边边碰黑线一个灯 左转
- add_right1=3;
- add_right2=3;
- add_left1=2;
- add_left2=2;
- left_moto1_back();
- right_moto1_go();
- right_moto2_go();
- if(flag==1&&sign_left1==1&&sign_left2==1&&sign_left3==0&&sign_left4==0)//左边碰黑线两个灯 右转
- add_right1=2;
- add_right2=2;
- add_left1=3;
- add_left2=3;
- left_moto1_go();
- left_moto2_go();
- if(flag==1&&sign_left1==0&&sign_left2==0&&sign_left3==1&&sign_left4==1&&sign_right2==0&&sign_right3==0)//右边碰黑线两个灯 左转
- add_left1=2;
- add_left2=2;
- car_turn_right();
- if(flag==1&&sign_left1==0&&sign_left2==0&&sign_left3==0&&sign_left4==0&&sign_right2==0&&sign_right3==0) // 左转
- add_right1=3;
- add_right2=3;
- add_left1=2;
- add_left2=2;
- right_moto1_go();
- right_moto2_go();
- if(flag==1&&sign_left1==1&&sign_left2==1&&sign_left3==1&&sign_left4==0&&sign_right2==0&&sign_right3==0)
- add_left1=0;
- add_left2=0;
- add_right1=0;
- add_right2=0;
- /********串口中断程序**********/
- void uart(void) interrupt 4
- if(RI) //收到数据
- RI=0; //清中断请求
- else //发送完一字节数据
- TI=0;
- sending=0; //清正在发送标志
- /********定时器0中断程序**********/
- void time0() interrupt 1
- if((flag2==0)&&(sign_right2==1||sign_right3==1))
- left_moto1_stp();
- left_moto2_stp();
- if(sign_back2==0) //光电开关扫描到//
- flag=0;
- if(flag==0)
- add_left1=9;
- add_left2=9;
- add_right1=5;
- add_right2=5;
- left_moto1_go();
- left_moto2_go();
- flag2=1;
- r++;
- if(r>=2000)
- if(sign_left1==0&&sign_left2==0&&sign_left3==0&&sign_left4==0)
- add_left1=2;
- add_left2=2;
- add_right1=2;
- add_right2=2;
- left_moto1_go();
- left_moto2_go();
- right_moto1_go();
- right_moto2_go();
- if(sign_left1==1||sign_left2==1||sign_left3==1||sign_left4==1)
- { z++;
- if(z>=5000)
- flag2=0;
- z=0;
- flag=1;
- r=0;
- TH0=0XFC; //1Ms定时
- TL0=0X18;
- time++;
- pwm_val_left1++;
- pwm_val_left2++;
- pwm_val_right1++;
- pwm_val_right2++;
- pwm_out_left_moto1();
- pwm_out_left_moto2();
- pwm_out_right_moto1();
- pwm_out_right_moto2();
- /********定时器1中断程序**********/
- void time1() interrupt 3
- TH1=0Xfd; //定时器设置
- TL1=0Xfd;
