TMS320F28335程序设计之外设模块配置1---SCI串行通信接口设计
 楼主| Plantt 发表于 2017-9-30 10:40 | 显示全部楼层 |阅读模式
一、SCI串口通信相关配置流程与内容(中断方式)
Step1:初始化GPIO
    InitSciGpio(); //只需设置SCIC和SCIB
Step2:初始化PIE中断向量表,(使用中断方式接收上位机数据)
    EALLOW;   //寄存器EALLOW保护
    PieVectTable.SCIRXINTC=&scicRxFifoIsr;//初始化PIE中断向量表
    // PieVectTable.SCITXINTC=&scicTxFifoIsr;
    EDIS;   //禁止写如EALLOW保护的寄存器
Step3:初始化SCI
SciSetup();
void SciSetup()
//SCIA设置
       // Note: Clocks were turned on to the SCIC peripheral
        // in the InitSysCtrl() function
    ScicRegs.SCICCR.all =0x0007;  // 1 stop bit,  No loopback
                                      // No parity,8 char bits,
                                      //async mode, idle-line protocol
    ScicRegs.SCICTL1.all =0x0003; // enable TX, RX, internal SCICLK,
                                      // Disable RX ERR, SLEEP, TXWAKE
    //ScicRegs.SCICTL2.all =0x0003;
    ScicRegs.SCICTL2.bit.TXINTENA = 1;
    ScicRegs.SCICTL2.bit.RXBKINTENA =1;
    #if (CPU_FRQ_150MHZ)
    ScicRegs.SCIHBAUD    =0x0001; // 9600baud @LSPCLK = 37.5MHz.
    ScicRegs.SCILBAUD    =0x00E7;
    #endif
    #if (CPU_FRQ_100MHZ)
     ScicRegs.SCIHBAUD    =0x0001; //9600 baud @LSPCLK = 20MHz.
    ScicRegs.SCILBAUD    =0x0044;
    #endif
//中断寄存器配置
    ScicRegs.SCIFFTX.all=0x8000;
    ScicRegs.SCIFFRX.all=0x0028;
    ScicRegs.SCIFFCT.all=0x0;
    ScicRegs.SCICTL1.all =0x0023; // Relinquish SCI from Reset
    ScicRegs.SCIFFTX.bit.TXFIFOXRESET=1;
    ScicRegs.SCIFFRX.bit.RXFIFORESET=1;
//SCIC接收中断服务程序
interrupt void scicRxFifoIsr(void)
    PieCtrlRegs.PIEACK.all=PIEACK_GROUP8;//第八组中断响应
    ReceivedChar = ScicRegs.SCIRXBUF.all;
    ScicRegs.SCIFFRX.bit.RXFIFORESET=0;//复位FIFO
    ScicRegs.SCIFFRX.bit.RXFIFORESET=1;// 使能FIFO
    ScicRegs.SCIFFRX.bit.RXFFOVRCLR=1;//清除溢出标志
    ScicRegs.SCIFFRX.bit.RXFFINTCLR=1;//清除中断标志
Step4:使能所需的中断
//使能所需的中断
    PieCtrlRegs.PIECTRL.bit.ENPIE=1;//使能PIE模块
//SCI-C
    PieCtrlRegs.PIEIER8.bit.INTx5=1;//PIE Group8,SCIRXINTC.
    // PieCtrlRegs.PIEIER8.bit.INTx6=1;//PIEGroup8,SCITXINTC
    IER|= M_INT8;// 使能CPU的第八组中断--SCIC中断
