- #include "common.h"
- #include "systick.h"
- #include "bme.h"
- #include "gpio.h"
- #include "sysinit.h"
- #include "start.h"
- #define LD0_Off GPIOB_OutPut1(7)
- #define LD0_On GPIOB_OutPut0(7) //PE7
- #define LD1_Off GPIOB_OutPut1(25)
- #define LD1_On GPIOB_OutPut0(25) //PH1
- #define LD2_Off GPIOB_OutPut1(26)
- #define LD2_On GPIOB_OutPut0(26) //PH2
- #define LD0_Off PE_OutPut1(7)
- #define LD0_On PE_OutPut0(7)
- #define LD1_Off PH_OutPut1(1)
- #define LD1_On PH_OutPut0(1)
- #define LD2_Off PH_OutPut1(2)
- #define LD2_On PH_OutPut0(2)
- int main (void);
- int main (void)
- sysinit();
- BME_BIT_SET(&GPIOB->PDDR,7); //set PE7 output
- BME_BIT_SET(&GPIOB->PDDR,25); //set PH1 output
- BME_BIT_SET(&GPIOB->PDDR,26); //set PH2 output
- while(1)
- delay_ms(1000);
- LD0_Off;
- delay_ms(1000);
- LD1_Off;
- delay_ms(1000);
- LD2_Off;
- delay_ms(1000);
- LD2_On;
- delay_ms(1000);
- LD1_On;
- delay_ms(1000);
- LD0_On;
- delay_ms(1000);
- LD0_Off;
- LD1_Off;
- LD2_Off;
- delay_ms(1000);
- LD0_On;
- LD1_On;
- LD2_On;
