[STM8] 关于 新版IAR for STM8 的问题,怎么解决
 楼主| 大王123 发表于 2018-5-24 16:50 | 显示全部楼层 |阅读模式
举个列子:
__no_init  volatile  unsigned char PA_ODR  @0x5000;
__no_init  volatile  unsigned char PA_ODR1 @0x5000;
// 指向同一个地址要报错,老版本的IAR 就不会有这个问题
Error[Lp025]: absolute section .near.noinit (main.o #11) ([0x005000-0x005000]) overlaps with absolute section .near.noinit (main.o #9) ([0x005000-0x005000])
xinpian101 发表于 2018-5-24 18:03 | 显示全部楼层
法克,你重叠位置了。
xinpian101 发表于 2018-5-24 18:04 | 显示全部楼层
这个版本不许定义重叠的变量。
 楼主| 大王123 发表于 2018-5-24 19:09 | 显示全部楼层
这个版本不许定义重叠的变量。
我两个地方都要用到啊
typedef struct
   unsigned char B0: 1;
   unsigned char B1: 1;
   unsigned char B2: 1;
   unsigned char B3: 1;
   unsigned char B4: 1;
   unsigned char B5: 1;
   unsigned char B6: 1;
   unsigned char B7: 1;
}  SBitChar;
typedef  struct
        SBitChar  ODR;
        SBitChar  IDR;
        SBitChar  DDR;
        SBitChar  CR1;
        SBitChar  CR2;
}  GPIO;
__no_init volatile   GPIO    PA @ 0x5000;
__no_init volatile   GPIO    PB @ 0x5005;
__no_init volatile   GPIO    PC @ 0x500A;
__no_init volatile   GPIO    PD @ 0x500F;
__no_init volatile   GPIO    PE @ 0x5014;
__no_init volatile   GPIO    PF @ 0x5019;
__no_init volatile   GPIO    PG @ 0x501E;
__no_init volatile   GPIO    PI @ 0x5028;
----------------------------------------------------------------------------------------------------------------------------------------#define DEF_8BIT_REG_AT(NAME,ADDRESS)   __no_init  volatile  unsigned char NAME @ADDRESS
#define DEF_16BIT_REG_AT(NAME,ADDRESS)  __no_init  volatile  unsigned int  NAME @ADDRESS
/* Port A data output latch register */
DEF_8BIT_REG_AT(PA_ODR,0x5000);
/* Port A input pin value register */
DEF_8BIT_REG_AT(PA_IDR,0x5001);
/* Port A data direction register */
DEF_8BIT_REG_AT(PA_DDR,0x5002);
/* Port A control register 1 */
DEF_8BIT_REG_AT(PA_CR1,0x5003);
/* Port A control register 2 */
DEF_8BIT_REG_AT(PA_CR2,0x5004);
/* Port B */
/* Port B data output latch register */
DEF_8BIT_REG_AT(PB_ODR,0x5005);
/* Port B input pin value register */
DEF_8BIT_REG_AT(PB_IDR,0x5006);
/* Port B data direction register */
DEF_8BIT_REG_AT(PB_DDR,0x5007);
/* Port B control register 1 */
DEF_8BIT_REG_AT(PB_CR1,0x5008);
/* Port B control register 2 */
DEF_8BIT_REG_AT(PB_CR2,0x5009);
/* Port C */
/* Port C data output latch register */
DEF_8BIT_REG_AT(PC_ODR,0x500a);
/* Port C input pin value register */
DEF_8BIT_REG_AT(PC_IDR,0x500b);
/* Port C data direction register */
DEF_8BIT_REG_AT(PC_DDR,0x500c);
/* Port C control register 1 */
DEF_8BIT_REG_AT(PC_CR1,0x500d);
/* Port C control register 2 */
DEF_8BIT_REG_AT(PC_CR2,0x500e);
gejigeji521 发表于 2018-5-25 12:05 来自手机 | 显示全部楼层
如果需要你可以用联合体
戈卫东 发表于 2018-5-25 13:55 | 显示全部楼层
用个宏替换一下不行么?
xinpian101 发表于 2018-5-30 21:05 | 显示全部楼层
楼上说的有道理,试试宏替换。
 楼主| 大王123 发表于 2018-5-31 18:02 | 显示全部楼层
用个宏替换一下不行么?
怎么替换,举个列子说说
aizaixiyuanqian 发表于 2018-5-31 18:59 | 显示全部楼层
变量被重叠,可以考虑联合体。
