利用中午休息的时间写了一下NV32与LCD1602的驱动,采用四线制接法,接口定义可以参考程序,程序还需要进一步完善,在此贴出来与大家分享。
lcd1602.c
- #include "main.h"
- //实际测试可用任意IO读写LCD1602//系统时钟16MHz
- ///////////////////////////////4线LCD1602////////////////////////////////////////////////
- //函数名: delay
- //函数功能:LCD1602延时
- //注释:
- void delay(unsigned char z)
- unsigned char x,y,j;
- for(j=0;j<4;j++)
- for(x=z;x>0;x--)
- for(y=110;y>0;y--);
- //函数名: LCD1602_GPIO_INIT
- //函数功能:LCD1602用GPIO初始化
- //注释:
- void LCD1602_GPIO_INIT(void)
- //控制位
- GPIO_Init(GPIOB, GPIO_PTE0_MASK, GPIO_PinOutput);
- GPIO_Init(GPIOB, GPIO_PTE1_MASK, GPIO_PinOutput);
- GPIO_Init(GPIOA, GPIO_PTC5_MASK, GPIO_PinOutput);
- //数据位
- GPIO_Init(GPIOB, GPIO_PTG0_MASK, GPIO_PinOutput);
- GPIO_Init(GPIOB, GPIO_PTG1_MASK, GPIO_PinOutput);
- GPIO_Init(GPIOB, GPIO_PTG2_MASK, GPIO_PinOutput);
- GPIO_Init(GPIOB, GPIO_PTG3_MASK, GPIO_PinOutput);
- //函数名: LCD1602_INIT
- //函数功能:LCD1602初始化
- //注释: DATA可以是指令或者数据
- void LCD1602_INIT(void)
- LCD1602_GPIO_INIT();
- //GPIO_Init(GPIOD,GPIO_PIN_ALL,GPIO_MODE_OUT_PP_LOW_FAST);
- //GPIO_Init(GPIOC,GPIO_PIN_5|GPIO_PIN_6|GPIO_PIN_7,GPIO_MODE_OUT_PP_LOW_FAST);
- RW_L();
- E_L();
- RS_L();//指令
- //GPIO_Write(GPIOB,0X20);
- //GPIO_Write(GPIOB,GPIOB->PDOR|0xFFF2FFFF);
- if(0X20&0x10)
- D4_H();
- else
- D4_L();
- if(0X20&0x20)
- D5_H();
- else
- D5_L();
- if(0X20&0x40)
- D6_H();
- else
- D6_L();
- if(0X20&0x80)
- D7_H();
- else
- D7_L();
- E_H();//允许
- delay(50);
- E_L();//4线制,在该位四线制通讯时,数据线切换必须是半字节的,之后延时必须超过40US
- // LCD1602_DATA_write(Write_order,0X28);//4位数据总线模式,显示2行数据,5*10点阵每字符 0X38为8位数据模式, 显示2行数据,5*10点阵每字符
- delay(10);
- LCD1602_DATA_write(Write_order,0x0c); //开显示,有光标,光标闪烁
- delay(10);
- LCD1602_Clear_Screen(); //清屏
- delay(10);
- LCD1602_DATA_write(Write_order,0x06); //写入数据光标右移,写入新数据显示屏不移动
- delay(10);
- LCD1602_DATA_write(Write_order,0x80); //
- //函数名: LCD1602_Clear_Screen
- //函数功能:LCD1602清屏
- //注释:
- void LCD1602_Clear_Screen(void)
- LCD1602_DATA_write(Write_order,0x01); //清屏
- //函数名: write_com
- //函数功能:LCD1602写指令
- //注释:
- void write_com(unsigned int dat)
- unsigned char j;
- RS_L();//指令
- for(j=0;j<2;j++)
- //GPIO_Write(GPIOB,(dat&0x00f0));
- //GPIO_Write(GPIOB,GPIOB->PDOR&(((dat&0x000000f0)<<12)|0xFFF0FFFF));
- //GPIO_Write(GPIOB,GPIOB->PDOR | ((dat&0x000000f0)<<12));
- if(dat&0x10)
- D4_H();
- else
- D4_L();
- if(dat&0x20)
- D5_H();
- else
- D5_L();
- if(dat&0x40)
- D6_H();
- else
- D6_L();
- if(dat&0x80)
- D7_H();
- else
- D7_L();
- E_H();//允许
- delay(50);
- E_L();
- dat<<=4;
- //函数名: write_data
- //函数功能:LCD1602写数据
- //注释:
- void write_data(unsigned int dat)
- unsigned char j;
- RS_H();//数据
- for(j=0;j<2;j++)
- if(dat&0x10)
- D4_H();
- else
- D4_L();
- if(dat&0x20)
- D5_H();
- else
- D5_L();
- if(dat&0x40)
- D6_H();
- else
- D6_L();
- if(dat&0x80)
- D7_H();
- else
- D7_L();
- E_H();//允许
- delay(50);
- E_L();
- dat<<=4;
- //函数名:lcd1602_write
- //作用:将数据或者指令写入LCD1602
- //注释:
- void LCD1602_DATA_write(LCD1602_Write_TypeDef order,unsigned char dat)
- if(order==Write_data)
- write_data(dat);
- else
- write_com(dat);
- //函数名:lcd1602_show_character
- //作用: 在制定坐标,显示单个字符
- void lcd1602_show_character(unsigned char x,unsigned char y,unsigned char dat)
- unsigned char address;
- x=x%16;
- y=y%2;
- if(y==1)
- address=0xc0+x;
- else
- address=0x80+x;
- LCD1602_DATA_write(Write_order,address);
- LCD1602_DATA_write(Write_data,dat);
- //函数名:lcd1602_show_number
- //作用:
- // 以(X,Y)坐标为起始,显示一个数字(此数字值不能大于4294967295(0xffffffff))
- //注释:
- // 返回数字的显示长度,若改行显示不下,函数自动换行, 显示其余部分
- unsigned char lcd1602_show_number(unsigned char x,unsigned char y,unsigned short dat)
- unsigned short pow=1,instead;
- unsigned char increase=0,lengh=0;
- instead=dat;
- while(instead!=0)
- instead=instead/10;
- increase++;
- lengh=increase;
- if(increase==0)
- lcd1602_show_character(x,y,0x30);
- return 1;
- else
- for(;increase>1;increase--)
- pow=pow*10;
- while(pow!=0)
- instead=dat/pow;
- lcd1602_show_character(x,y,(0x30+instead));
- x++;
- if(((x%16)==0)&&(x!=0))
- y++;
- y=y%2;
- x=x%16;
- dat=dat%pow;
- pow=pow/10;
- return lengh;
- //函数名:lcd1602_show_string
- //作用:
- // 以(X,Y)坐标为起始,显示一个字符串
- //注释:
- // 返回数字的显示长度,若改行显示不下,函数自动换行, 显示其余部分,字符长度小于256
- unsigned char lcd1602_show_string(unsigned char x,unsigned char y,unsigned char *dat)
- unsigned char lengh=0;
- while(dat[lengh]!='\0')
- y++;
- y=y%2;
- x=x%16;
- lcd1602_show_character(x,y,dat[lengh]);
- x++;
- lengh++;
- return (lengh);
- //作用:
- //注释:
- unsigned char lcd1602_show_s32(unsigned char x,unsigned char y,short dat)
- short pow=1,instead;
- if(((dat&0x80000000)==0x80000000)&&(dat!=0xffffffff))//负数
- instead=-dat;
- y=y%2;
- lcd1602_show_character(x,y,0x2D);//"-"
- x++;
- else if((dat&0x80000000)!=0x80000000)//正数
- instead=dat;
- y=y%2;
- lcd1602_show_character(x,y,0X2B);//"+"
- x++;
- else//0
- instead=0;
- dat=instead;
- while(instead!=0)
- increase++;
- lengh=increase;
- if(increase==0)
- return 1;
- else
- pow=pow*10;
- while(pow!=0)
- instead=dat/pow;
- x++;
- y++;
- y=y%2;
- //x=x%16;
- dat=dat%pow;
- pow=pow/10;
- return lengh+1;
复制代码 lcd1602.h
- #ifndef __LCD1602_H__
- #define __LCD1602_H__
- //为了适应任意IO驱动LCD1602做的定义
- #define RW_L() GPIO_PinClear(GPIO_PTE0)//RW=0
- #define RW_H() GPIO_PinSet(GPIO_PTE0) //RW=1
- #define RS_L() GPIO_PinClear(GPIO_PTE1)//RS=0
- #define RS_H() GPIO_PinSet(GPIO_PTE1) //RS=1
- #define E_L() GPIO_PinClear(GPIO_PTC5)//E=0
- #define E_H() GPIO_PinSet(GPIO_PTC5) //E=1
- //#define D0_L() P2 &=~BIT0//D0=0
- //#define D0_H() P2 |=BIT0 //D0=1
- //#define D1_L() P2 &=~BIT1//D1=0
- //#define D1_H() P2 |=BIT1 //D1=1
- //#define D2_L() P2 &=~BIT2//D2=0
- //#define D2_H() P2 |=BIT2 //D2=1
- //#define D3_L() P2 &=~BIT3//D3=0
- //#define D3_H() P2 |=BIT3 //D3=1
- #define D4_L() GPIO_PinClear(GPIO_PTG0)//D4=0
- #define D4_H() GPIO_PinSet(GPIO_PTG0) //D4=1
- #define D5_L() GPIO_PinClear(GPIO_PTG1)//D5=0
- #define D5_H() GPIO_PinSet(GPIO_PTG1) //D5=1
- #define D6_L() GPIO_PinClear(GPIO_PTG2)//D6=0
- #define D6_H() GPIO_PinSet(GPIO_PTG2) //D6=1
- #define D7_L() GPIO_PinClear(GPIO_PTG3)//D7=0
- #define D7_H() GPIO_PinSet(GPIO_PTG3) //D7=1
- typedef enum
- Write_data =0X00,
- Write_order =0x01/*BIT0*/
- }LCD1602_Write_TypeDef;
- //函数名: delay
- //函数功能:LCD1602延时
- //注释:
- void delay(unsigned char z);
- //注释:
- void LCD1602_GPIO_INIT(void);
- //函数功能:LCD1602初始化
- void LCD1602_INIT(void);
- //函数功能:LCD1602清屏
- //注释:
- void LCD1602_Clear_Screen(void);
- //函数名: write_com
- //函数功能:LCD1602写指令
- //注释:
- void write_com(unsigned int dat);
- //函数名: write_data
- //函数功能:LCD1602写数据
- //注释:
- void write_data(unsigned int dat);
- //注释:
- void LCD1602_DATA_write(LCD1602_Write_TypeDef order,unsigned char dat);
- void lcd1602_show_character(unsigned char x,unsigned char y,unsigned char dat);
- //作用:
- //注释:
- unsigned char lcd1602_show_number(unsigned char x,unsigned char y,unsigned short dat);
- //作用:
- //注释:
- unsigned char lcd1602_show_string(unsigned char x,unsigned char y,unsigned char *dat);
- //显示有符号S32
- unsigned char lcd1602_show_s32(unsigned char x,unsigned char y,short dat);
- #endif
复制代码
