- void i2cbus_ll_init(void)
- dma_parameter_struct dma_init_struct;
- // RCU Part
- rcu_periph_clock_enable(I2C_PERIPH_RCU);
- rcu_periph_clock_enable(I2C_PORT_RCU);
- rcu_periph_clock_enable(RCU_DMA);
- // GPIO Part
- gpio_af_set(I2C_PORT, GPIO_AF_1, I2C_CLOCK_PIN);
- gpio_af_set(I2C_PORT, GPIO_AF_1, I2C_DATA_PIN);
- gpio_mode_set(I2C_PORT, GPIO_MODE_AF, GPIO_PUPD_PULLUP, I2C_CLOCK_PIN);
- gpio_output_options_set(I2C_PORT, GPIO_OTYPE_OD, GPIO_OSPEED_50MHZ, I2C_CLOCK_PIN);
- gpio_mode_set(I2C_PORT, GPIO_MODE_AF, GPIO_PUPD_PULLUP, I2C_DATA_PIN);
- gpio_output_options_set(I2C_PORT, GPIO_OTYPE_OD, GPIO_OSPEED_50MHZ, I2C_DATA_PIN);
- // DMA Part
- // -> RX
- dma_deinit(DMA_CH4);
- dma_struct_para_init(&dma_init_struct);
- dma_init_struct.direction = DMA_PERIPHERAL_TO_MEMORY;
- dma_init_struct.memory_addr = (uint32_t)i2c_rxbuffer;
- dma_init_struct.memory_inc = DMA_MEMORY_INCREASE_ENABLE;
- dma_init_struct.memory_width = DMA_MEMORY_WIDTH_8BIT;
- dma_init_struct.number = 24;
- dma_init_struct.periph_addr = I2C1_DATA_ADDRESS;
- dma_init_struct.periph_inc = DMA_PERIPH_INCREASE_DISABLE;
- dma_init_struct.periph_width = DMA_PERIPHERAL_WIDTH_8BIT;
- dma_init_struct.priority = DMA_PRIORITY_ULTRA_HIGH;
- dma_init(DMA_CH4, &dma_init_struct);
- // -> TX
- dma_deinit(DMA_CH3);
- dma_init_struct.direction = DMA_MEMORY_TO_PERIPHERAL;
- dma_init_struct.memory_addr = (uint32_t)i2c_txbuffer;
- dma_init_struct.priority = DMA_PRIORITY_HIGH;
- dma_init(DMA_CH3, &dma_init_struct);
- dma_circulation_disable(DMA_CH4);
- dma_circulation_disable(DMA_CH3);
- dma_memory_to_memory_disable(DMA_CH4);
- dma_memory_to_memory_disable(DMA_CH3);
- dma_interrupt_enable(DMA_CH3, DMA_INT_FTF);
- dma_interrupt_enable(DMA_CH4, DMA_INT_FTF);
- // I2C Part
- i2c_clock_config(I2C_PERIPH, 400000U, I2C_DTCY_2);
- i2c_mode_addr_config(I2C_PERIPH, I2C_I2CMODE_ENABLE, I2C_ADDFORMAT_7BITS, 0x70);
- i2c_enable(I2C_PERIPH);
- // NVIC Part
- //nvic_irq_enable(I2C_NVIC_EVENT_IRQ, 1, 1);
- nvic_irq_enable(I2C_NVIC_ERROR_IRQ, 1, 2);
- //nvic_irq_enable(DMA_Channel3_4_IRQn, 0, 0);
编写功能代码
- i2cbus_error_t i2cbus_write_data(uint8_t addr, uint8_t *data, uint8_t count)
- i2cbus_error_t err = I2C_OperationTimedOutError;
- // Copying data to static buffer
- for (int i = 0; i < count; i++)
- i2c_txbuffer[i] = *data++;
- // DMA Transfer configuration according to GD32F3x0 User Manual - Page 158/159.
- dma_channel_disable(DMA_CH3); // 1
- dma_memory_to_memory_disable(DMA_CH3); // 2
- dma_transfer_direction_config(DMA_CH3, DMA_MEMORY_TO_PERIPHERAL); // 2
- dma_circulation_disable(DMA_CH3); // 3
- dma_priority_config(DMA_CH3, DMA_PRIORITY_HIGH); // 4
- dma_periph_increase_disable(DMA_CH3); // 5
- dma_periph_width_config(DMA_CH3, DMA_PERIPHERAL_WIDTH_8BIT); // 5
- dma_memory_increase_enable(DMA_CH3); // 5
- dma_memory_width_config(DMA_CH3, DMA_MEMORY_WIDTH_8BIT); // 5
- dma_interrupt_enable(DMA_CH3, DMA_INT_FTF); // 6
- dma_interrupt_enable(DMA_CH3, DMA_INT_ERR); // 6
- dma_periph_address_config(DMA_CH3, I2C1_DATA_ADDRESS); // 7
- dma_memory_address_config(DMA_CH3, (uint32_t)i2c_txbuffer); // 8
- dma_transfer_number_config(DMA_CH3, count); // 9
- dma_channel_enable(DMA_CH3); // 10
- // Wait for bus to be available
- while(i2c_flag_get(I2C1, I2C_FLAG_I2CBSY));
- // Start
- i2c_start_on_bus(I2C1);
- while(!i2c_flag_get(I2C1, I2C_FLAG_SBSEND));
- // Address
- i2c_master_addressing(I2C1, addr, I2C_TRANSMITTER);
- while(!i2c_flag_get(I2C1, I2C_FLAG_ADDSEND));
- i2c_flag_clear(I2C1, I2C_FLAG_ADDSEND);
- // DMA
- i2c_dma_enable(I2C1, I2C_DMA_ON);
- i2c_dma_last_transfer_config(I2C1, I2C_DMALST_OFF);
- while (!dma_interrupt_flag_get(DMA_CH3, DMA_INT_FLAG_FTF));
- dma_flag_clear(DMA_CH3, DMA_INT_FLAG_FTF);
- while(!i2c_flag_get(I2C1, I2C_FLAG_BTC));
- i2c_stop_on_bus(I2C_PERIPH);
- while(I2C_CTL0(I2C_PERIPH) & 0x0200);
- return err;
它卡在了线上:while(!i2c_flag_get(I2C1,I2C_FLAG_BTC));;第二次我尝试写作。有人遇到过这个问题吗?
如果我不这样说的话。 DMA不发送数据。
