有人用过lpc1768吗?串口1老是没反应啊
 楼主| 相信哥咯 发表于 2012-2-16 10:32 | 显示全部楼层 |阅读模式
串口0可以:'(
int main (void)
  SystemInit();
  GPIO1->FIODIR|=(1<<26);//方向控制 led
  UARTInit(0, 9600);    /* baud rate setting */
  UARTInit(1, 9600);    /* baud rate setting */
  while (1)
    Delay();
    UART0->THR =0x55;
      UART1->THR =0xaa;
              /* Loop forever */
uint32_t UARTInit( uint32_t PortNum, uint32_t baudrate )
  uint32_t Fdiv;
  if ( PortNum == 0 )
        PINCON->PINSEL0 = 0x00000050;       /* RxD0 is P0.3 and TxD0 is P0.2 */
    UART0->LCR = 0x83;                /* 8 bits, no Parity, 1 Stop bit */
        /* By default, the PCLKSELx value is zero, thus, the PCLK for
        all the peripherals is 1/4 of the SystemFrequency. */
    Fdiv = ( SystemFrequency/4/16 ) / baudrate ;        /*baud rate, Fpclk: 18MHz */
    UART0->DLM = Fdiv / 256;
    UART0->DLL = Fdiv % 256;
        UART0->LCR = 0x03;                /* DLAB = 0 */
    UART0->FCR = 0x07;                /* Enable and reset TX and RX FIFO. */
           NVIC_EnableIRQ(UART0_IRQn);
    UART0->IER = IER_RBR | IER_THRE | IER_RLS;        /* Enable UART0 interrupt */
    return (TRUE);
  else if ( PortNum == 1 )
        PINCON->PINSEL4 |= 0x0000000A;        /* Enable RxD1 P2.1, TxD1 P2.0 */
    UART1->LCR = 0x83;                /* 8 bits, no Parity, 1 Stop bit */
    Fdiv = ( SystemFrequency/4/16 ) / baudrate ;        /*baud rate */
    UART1->DLM = Fdiv / 256;
    UART1->DLL = Fdiv % 256;
        UART1->LCR = 0x03;                /* DLAB = 0 */
    UART1->FCR = 0x07;                /* Enable and reset TX and RX FIFO. */
           NVIC_EnableIRQ(UART1_IRQn);
    UART1->IER = IER_RBR | IER_THRE | IER_RLS;        /* Enable UART1 interrupt */
    return (TRUE);
  return( FALSE );
 楼主| 相信哥咯 发表于 2012-2-16 15:01 | 显示全部楼层
找到了,映射问题
