* Include files
#include "modem.h"
#include "iap.h"
#include "flash.h"
#include "usart.h"
* Local type definitions ('typedef')
* Local pre-processor symbols/macros ('#define')
* Global variable definitions (declared in header file with 'extern')
uint8_t u8FrameData[FRAME_SHELL_SIZE + PACKET_MAX_SIZE];
* Local function prototypes ('static')
static uint16_t Cal_CRC16(const uint8_t *pu8Data, uint32_t u32ByteLen);
static uint16_t FLASH_PageNumber(uint32_t u32Size);
* Local variable definitions ('static')
* Function implementation - global ('extern') and local ('static')
* @brief Update CRC16 for input byte
* @param crc_in input value
* @param input byte
* @retval None
uint16_t Update_CRC16(uint16_t crc_in, uint8_t byte)
uint32_t crc = crc_in;
uint32_t in = byte | 0x100;
do
crc <<= 1;
in <<= 1;
if (in & 0x100)
++crc;
if (crc & 0x10000)
crc ^= 0x1021;
while (!(in & 0x10000));
return crc & 0xffffu;
* @brief Cal CRC16 for Packet
* @param data
* @param length
* @retval None
uint16_t Cal_CRC16(const uint8_t* p_data, uint32_t size)
uint32_t crc = 0;
const uint8_t* dataEnd = p_data + size;
while (p_data < dataEnd)
crc = Update_CRC16(crc, *p_data++);
crc = Update_CRC16(crc, 0);
** \brief Modem receive frame
** \param [out] u8RxBuff Pointer to Rx buffer.
** \param [in] u16RxLength Pointer to receive data length.
** \param [in] u32Timeout Communication process timeout
** \retval Ok Receive finished
** \retval Error Receive error
en_result_t Modem_RecvFrame(uint8_t *u8RxBuff, uint16_t *u16RxLength, uint32_t u32Timeout)
uint16_t u16PacketSize = 0u;
uint16_t u16Crc16;
*u16RxLength = 0u;
if (Ok == UART_RecvData((uint8_t *)&u8RxBuff[FRAME_HEAD_INDEX], 1, u32Timeout))
if ((FRAME_HEAD == u8RxBuff[FRAME_HEAD_INDEX]) &&
(Ok == UART_RecvData((uint8_t *)&u8RxBuff[FRAME_NUM_INDEX], 2, u32Timeout)))
if ((u8RxBuff[FRAME_NUM_INDEX] == (u8RxBuff[FRAME_XORNUM_INDEX] ^ FRAME_NUM_XOR_BYTE)) &&
(Ok == UART_RecvData(&u8RxBuff[FRAME_LENGTH_INDEX], 2, u32Timeout)))
u16PacketSize = *((uint16_t *)&u8RxBuff[FRAME_LENGTH_INDEX]);
if (((u16PacketSize >= PACKET_MIN_SIZE) && (u16PacketSize <= PACKET_MAX_SIZE)) &&
(Ok == UART_RecvData(&u8RxBuff[FRAME_PACKET_INDEX], u16PacketSize + 2, u32Timeout)))
u16Crc16 = *((uint16_t *)&u8RxBuff[FRAME_PACKET_INDEX + u16PacketSize]);
if (Cal_CRC16(&u8RxBuff[FRAME_PACKET_INDEX], u16PacketSize) == u16Crc16)
*u16RxLength = u16PacketSize;
return Ok;
return Error;
** \brief Modem send frame
** \param [out] u8TxBuff Pointer to Tx buffer.
** \param [in] u16TxLength Send buffer data length.
** \retval None
void Modem_SendFrame(uint8_t *u8TxBuff, uint16_t u16TxLength)
uint16_t u16Crc16;
u8TxBuff[FRAME_LENGTH_INDEX] = u16TxLength & 0x00FF;
u8TxBuff[FRAME_LENGTH_INDEX + 1] = u16TxLength >> 8;
u16Crc16 = Cal_CRC16(&u8TxBuff[FRAME_PACKET_INDEX], u16TxLength);
u8TxBuff[FRAME_PACKET_INDEX + u16TxLength] = u16Crc16 & 0x00FF;
u8TxBuff[FRAME_PACKET_INDEX + u16TxLength + 1] = u16Crc16 >> 8;
UART_SendData(&u8TxBuff[0], FRAME_PACKET_INDEX + u16TxLength + 2);
** \brief Modem process
** \param [in] u32Timeout Communication process timeout(ms)
** \retval Ok Communication done
** \retval ErrorTimeout Communication timeout
** \retval Error Communication error
en_result_t Modem_Process(uint32_t u32Timeout)
uint8_t u8Ret;
uint8_t u8CommFlag = 0u, u8FlashAddrValid;
uint32_t u32TimeoutCnt = 0u;
uint16_t u16PacketLength, u16DataLength;
uint32_t u32FlashAddr;
uint8_t u8Cmd, u8Cnt;
uint16_t u16PageNum;
uint32_t u32Temp;
while (1)
if (u32TimeoutCnt >= u32Timeout)
if (u8CommFlag == 0u) // No communication
return ErrorTimeout;
else
return Error;
if (Ok == Modem_RecvFrame(&u8FrameData[0], &u16PacketLength, FRAME_RECV_TIMEOUT))
u32TimeoutCnt = 0u;
u8CommFlag = 1u;
u8Cmd = u8FrameData[PACKET_CMD_INDEX];
u16DataLength = u16PacketLength - PACKET_INSTRUCT_SEGMENT_SIZE;
if (PACKET_CMD_TYPE_DATA == u8FrameData[PACKET_TYPE_INDEX])
u32FlashAddr = *((uint32_t *)&u8FrameData[PACKET_ADDRESS_INDEX]);
if ((u32FlashAddr >= (FLASH_BASE + BOOT_SIZE)) && (u32FlashAddr < (FLASH_BASE + FLASH_SIZE)))
u8FlashAddrValid = 1u;
else
u8FlashAddrValid = 0u;
switch (u8Cmd)
case PACKET_CMD_HANDSHAKE:
u8FrameData[PACKET_RESULT_INDEX] = PACKET_ACK_OK;
Modem_SendFrame(&u8FrameData[0], PACKET_INSTRUCT_SEGMENT_SIZE);
break;
case PACKET_CMD_JUMP_TO_APP:
u32Temp = APP_FLAG;
EFM_WriteFlash(BOOT_PARA_ADDRESS, (uint8_t *)&u32Temp, 4);
return Ok;
case PACKET_CMD_APP_DOWNLOAD:
if (1u == u8FlashAddrValid)
u8Ret = EFM_WriteFlash(u32FlashAddr, (uint8_t *)&u8FrameData[PACKET_DATA_INDEX], u16DataLength);
if (EfmError == u8Ret)
u8FrameData[PACKET_RESULT_INDEX] = PACKET_ACK_ERROR;
else
else
u8FrameData[PACKET_RESULT_INDEX] = PACKET_ACK_ADDR_ERROR;
break;
case PACKET_CMD_APP_UPLOAD:
u32Temp = *((uint32_t *)&u8FrameData[PACKET_DATA_INDEX]);
if (u32Temp > PACKET_DATA_SEGMENT_SIZE)
u32Temp = PACKET_DATA_SEGMENT_SIZE;
u8Ret = EFM_ReadFlashByte(u32FlashAddr, (uint8_t *)&u8FrameData[PACKET_DATA_INDEX], u32Temp);
else
Modem_SendFrame(&u8FrameData[0], PACKET_INSTRUCT_SEGMENT_SIZE + u32Temp);
else
break;
case PACKET_CMD_ERASE_FLASH:
u16PageNum = FLASH_PageNumber(u32Temp);
for (u8Cnt=0; u8Cnt<u16PageNum; u8Cnt++)
u8Ret = EFM_EraseSector(u32FlashAddr + (u8Cnt * FLASH_SECTOR_SIZE));
break;
if (EfmOk == u8Ret)
else
break;
default:
break;
else
u32TimeoutCnt += FRAME_RECV_TIMEOUT;
** \brief Calculate how many sectors are included in a given size.
uint16_t u32PageNum = u32Size / FLASH_SECTOR_SIZE;
if ((u32Size % FLASH_SECTOR_SIZE) != 0)
u32PageNum += 1u;
return u32PageNum;
* EOF (not truncated)
