- * [url=home.php?mod=space&uid=288409]@file[/url] main.c
- * [url=home.php?mod=space&uid=895143]@version[/url] V1.00
- * $Revision: 4 $
- * $Date: 15/05/22 2:05p $
- * [url=home.php?mod=space&uid=247401]@brief[/url] 通过P40(24)和P41(PIN36)输出两路PWM信号.
- * @note
- * Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
- #include <stdio.h>
- #include "M051Series.h"
- /* Macro, type and constant definitions */
- #define PLLCON_SETTING CLK_PLLCON_50MHz_HXT
- #define PLL_CLOCK 50000000
- /* Global variables */
- void SYS_Init(void)
- /* Init System Clock */
- /* Enable Internal RC clock */
- CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
- /* Waiting for IRC22M clock ready */
- CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
- /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
- CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
- /* Enable external 12MHz XTAL, internal 22.1184MHz */
- CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk | CLK_PWRCON_OSC22M_EN_Msk);
- /* Enable PLL and Set PLL frequency */
- CLK_SetCoreClock(PLLCON_SETTING);
- /* Waiting for clock ready */
- CLK_WaitClockReady(CLK_CLKSTATUS_PLL_STB_Msk | CLK_CLKSTATUS_XTL12M_STB_Msk | CLK_CLKSTATUS_OSC22M_STB_Msk);
- /* Switch HCLK clock source to PLL, STCLK to HCLK/2 */
- CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_PLL, CLK_CLKDIV_HCLK(2));
- /* Enable UART module clock */
- CLK_EnableModuleClock(UART0_MODULE);
- /* Enable PWM module clock */
- CLK_EnableModuleClock(PWM01_MODULE);
- /* Select UART module clock source */
- CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
- /* Select PWM module clock source */
- CLK_SetModuleClock(PWM01_MODULE, CLK_CLKSEL1_PWM01_S_HXT, 0);
- /* Reset PWMA channel0~channel3 */
- SYS_ResetModule(PWM03_RST);
- /* Update System Core Clock */
- /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
- //SystemCoreClockUpdate();
- PllClock = PLL_CLOCK; // PLL
- SystemCoreClock = PLL_CLOCK / 1; // HCLK
- CyclesPerUs = PLL_CLOCK / 1000000; // For SYS_SysTickDelay()
- /* Init I/O Multi-function */
- /* Set P3 multi-function pins for UART0 RXD and TXD */
- SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk);
- SYS->P3_MFP |= SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0;
- /* Set P4 multi-function pins for PWMA Channel 0 and 1 */
- SYS->P4_MFP &= ~(SYS_MFP_P40_Msk|SYS_MFP_P41_Msk);
- SYS->P4_MFP |= (SYS_MFP_P40_PWM0|SYS_MFP_P41_PWM1);
- void UART0_Init(void)
- /* Init UART */
- /* Configure UART0 and set UART0 Baudrate */
- UART_Open(UART0, 115200);
- /* Main Function */
- int32_t main(void)
- uint8_t i=100;
- /* Unlock protected registers */
- SYS_UnlockReg();
- /* Init System, IP clock and multi-function I/O */
- SYS_Init();
- /* Lock protected registers */
- SYS_LockReg();
- /* Init UART0 for printf */
- UART0_Init();
- PWM_EnableOutput(PWMA, 0x1|0x2);
- PWM_ConfigOutputChannel(PWMA, PWM_CH0, 2000, i);
- PWM_ConfigOutputChannel(PWMA, PWM_CH1, 2000, 100-i);
- PWM_Start(PWMA, 0x1|0x2);
- GPIO_SetMode(P3,BIT6,GPIO_PMD_OUTPUT);
- while(1)
- while(i>0)
- i=i-1;
- CLK_SysTickDelay(5000);
- //驱动板载的LED红灯闪烁
- P36 ^=1;
- while(i<100)
- i=i+1;
- //驱动板载的LED红灯闪烁
- P36 ^=1;
