不进中断,头大了!!
- #pragma config WDTEN = OFF //WDT disabled (enabled by SWDTEN bit)
- #pragma config PLLDIV = 2 //Divide by 3 (12 MHz oscillator input)
- #pragma config STVREN = ON //stack overflow/underflow reset enabled
- #pragma config XINST = OFF //Extended instruction set disabled
- #pragma config CPUDIV = OSC1 //No CPU system clock divide
- #pragma config CP0 = OFF //Program memory is not code-protected
- #pragma config OSC = INTOSCPLL
- #pragma config T1DIG = OFF //Sec Osc clock source may be selected
- #pragma config LPT1OSC = OFF //high power Timer1 mode
- #pragma config FCMEN = OFF //Fail-Safe Clock Monitor disabled
- #pragma config IESO = OFF //Two-Speed Start-up disabled
- #pragma config WDTPS = 32768 //1:32768
- #pragma config RTCOSC = INTOSCREF //RTCC uses INTRC as clock
- #pragma config DSBOREN = OFF //Zero-Power BOR disabled in Deep Sleep
- #pragma config DSWDTOSC = INTOSCREF //DSWDT uses INTOSC/INTRC as clock
- #pragma config DSWDTEN = OFF //Disabled
- #pragma config DSWDTPS = 2048 //1:8,192 (8.5 seconds)
- #pragma config IOL1WAY = OFF //IOLOCK bit can be set and cleared
- #pragma config MSSP7B_EN = MSK7 //7 Bit address masking
- #pragma config WPFP = PAGE_0 //Write Protect Program Flash Page 0
- #pragma config WPEND = PAGE_0 //Start protection at page 0
- #pragma config WPCFG = OFF //Write/Erase last page protect Disabled
- #pragma config WPDIS = OFF //WPFP[5:0], WPEND, and WPCFG bits ignored
- #include <p18cxxx.h>
- void drv_CPUIO_INT1_Init_Falling(void)
- INTCON3bits.INT1IF = 0;
- INTCON2bits.INTEDG1=0; //No, falling edge is used
- INTCON2bits.RBPU=1; //disable pullups
- INTCON2bits.RBIP=1;
- INTCONbits.RBIE=1;
- INTCONbits.RBIF=0;
- INTCON3bits.INT1IP=1;
- INTCON3bits.INT1IE=1;
- PORTB = PORTB;
- void main(void)
- TRISA = 0x25;
- PORTA = 0x27;
- LATA = 0x27;
- TRISB = 0x1;
- PORTB = 0xF;
- LATB = 0xF;
- TRISC = 0x33;
- PORTC = 0x73;
- LATC = 0x73;
- RPINR1 = 0; //INT1 = RP0(RA0外接按键,按下为低电平)
- drv_CPUIO_INT1_Init_Falling();
- while(1)
- Nop();
- Nop();
- PORTB = PORTB;
- void high_isr (void);
- void low_isr (void);
- #pragma code high_vector=0x08
- void high_vector (void)
- _asm goto high_isr _endasm
- #pragma code low_vector=0x18
- void low_vector (void)
- _asm goto low_isr _endasm
- #pragma code
- #pragma interrupt high_isr
- if(INTCON3bits.INT1IF)
- Nop();
- if(INTCONbits.RBIF)
- Nop();
- #pragma interruptlow low_isr
- Nop();
- Nop();
- Nop();
