重写主函数
- int main(void)
- /* USER CODE BEGIN 1 */
- /* USER CODE END 1 */
- /* MCU Configuration--------------------------------------------------------*/
- /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
- HAL_Init();
- /* USER CODE BEGIN Init */
- /* USER CODE END Init */
- /* Configure the system clock */
- SystemClock_Config();
- /* USER CODE BEGIN SysInit */
- /* USER CODE END SysInit */
- /* Initialize all configured peripherals */
- MX_GPIO_Init();
- MX_USART1_UART_Init();
- MX_TIM1_Init();
- /* USER CODE BEGIN 2 */
- HAL_TIM_Base_Start(&htim1);//开启定时器
- /* USER CODE END 2 */
- /* Infinite loop */
- /* USER CODE BEGIN WHILE */
- while (1)
- /* 定时器1,通道1,模式随便,主要用于计数,没有使用边沿捕获 */
- Start();//开启超声波模块
- //对超声波输入端口操作
- while( HAL_GPIO_ReadPin (Echo_GPIO_Port ,Echo_Pin) == GPIO_PIN_RESET);//等待输入电平拉高
- __HAL_TIM_SetCounter(&htim1,0);
- //对超声波输入端口操作
- while( HAL_GPIO_ReadPin (Echo_GPIO_Port ,Echo_Pin) == GPIO_PIN_SET);//等待输入电平变低
- Cnt = __HAL_TIM_GetCounter(&htim1);
- HAL_TIM_Base_Stop(&htim1);
- Distance = Cnt*340/2*0.000001*100 ;
- printf("Distance=%.1fcm\n",Distance);
- HAL_Delay(500);
- /* USER CODE END WHILE */
- /* USER CODE BEGIN 3 */
- /* USER CODE END 3 */
