一个VLAN设置实例
 楼主| keer_zu 发表于 2023-9-14 15:19 | 显示全部楼层 |阅读模式
  1. emac1:
  2.         address: xx:xx:xx:xx:00:90
  3.         inet 17.18.5.88 netmask 0xffffff00 broadcast 17.18.5.255
  4. rt0:
  5.         address: xx:xx:xx:xx:00:88
  6.         inet 192.168.1.12 netmask 0xffffff00 broadcast 192.168.1.255
  7.
  8. bridge0: flags=0 mtu 1500
  9. vlan11:
  10.         vlan: 11 priority: 0 parent: emac1
  11.         address: xx:xx:xx:xx:00:90
  12.         inet 17.18.11.90 netmask 0xffffff00 broadcast 17.18.11.255
  13.
  14. vlan16:
  15.         vlan: 16 priority: 0 parent: emac1
  16.         address: xx:xx:xx:xx:00:90
  17.         inet 17.18.16.90 netmask 0xffffff00 broadcast 17.18.16.255
  18.
  19. vlan2:
  20.         vlan: 2 priority: 0 parent: rt0
  21.         address: xx:xx:xx:xx:00:88
  22.         inet 17.18.2.88 netmask 0xffffff00 broadcast 17.18.2.255
  23.
  24. vlan3:
  25.         vlan: 3 priority: 0 parent: rt0
  26.         address: xx:xx:xx:xx:00:88
  27.         inet 17.18.3.88 netmask 0xffffff00 broadcast 17.18.3.255
  28.
  29. vlan4:
  30.         vlan: 4 priority: 0 parent: rt0
  31.         address: xx:xx:xx:xx:00:88
  32.         inet 17.18.4.88 netmask 0xffffff00 broadcast 17.18.4.255
  33.
  34. vlan13:
  35.         vlan: 13 priority: 0 parent: rt0
  36.         address: xx:xx:xx:xx:00:88
  37.         inet 17.18.13.88 netmask 0xffffff00 broadcast 17.18.13.255
  38.
  1. # arp -a
  2. ? (17.18.2.30) at xx:xx:xx:xx:00:30 on vlan2 permanent
  3. ? (17.18.2.56) at xx:xx:xx:xx:00:56 on vlan2 permanent
  4. ? (17.18.2.57) at xx:xx:xx:xx:00:57 on vlan2 permanent
  5. ? (17.18.2.58) at xx:xx:xx:xx:00:58 on vlan2 permanent
  6. ? (17.18.2.59) at xx:xx:xx:xx:00:59 on vlan2 permanent
  7. ? (17.18.2.66) at xx:xx:xx:xx:00:66 on vlan2 permanent
  8. ? (17.18.2.97) at xx:xx:xx:xx:00:97 on vlan2 permanent
  9. ? (17.18.2.99) at xx:xx:xx:xx:00:99 on vlan2 permanent
  10. ? (17.18.3.50) at xx:xx:xx:xx:00:50 on vlan3 permanent
  11. ? (17.18.3.55) at xx:xx:xx:xx:00:55 on vlan3 permanent
  12. ? (17.18.3.99) at xx:xx:xx:xx:00:99 on vlan3 permanent
  13. ? (17.18.4.81) at xx:xx:xx:xx:00:81 on vlan4 permanent
  14. ? (17.18.4.91) at xx:xx:xx:xx:00:91 on vlan4 permanent
  15. ? (17.18.4.98) at xx:xx:xx:xx:00:98 on vlan4 permanent
  16. ? (17.18.5.89) at xx:xx:xx:xx:00:89 on emac1 permanent
  17. ? (17.18.11.97) at xx:xx:xx:xx:00:97 on vlan11 permanent
  18. ? (17.18.13.97) at xx:xx:xx:xx:00:97 on vlan13 permanent
  19. ? (17.18.18.97) at xx:xx:xx:xx:00:97 on vlan18 permanent
  20. ? (192.168.1.12) at xx:xx:xx:xx:00:88 on rt0 permanent
 楼主| keer_zu 发表于 2023-9-14 16:11 | 显示全部楼层
如果把vlan有关的设置从rtl9072中完全删除,那么就会出现这样的结果:
如果以此ip为sip,那么发出的组播包其它port收不到。
 楼主| keer_zu 发表于 2023-9-14 16:14 | 显示全部楼层
如果把vlan有关的设置从rtl9072中完全删除,ifconfig内容好像没有变化,这说明ifconfig结果只和soc系统的ifconfig设置脚本的内容有关。
但是arp -a的结果里面之前可以ping到的ip地址:192.168.1.12变成了测试主机的192.168.1.2
1478
