- void i2c_init()
- GPIO_InitTypeDef GPIO_InitStructure = {0};
- I2C_InitTypeDef I2C_InitStruct = {0};
- __RCC_GPIOB_CLK_ENABLE();
- __RCC_I2C1_CLK_ENABLE();
- PB06_AFx_I2C1SCL();
- PB07_AFx_I2C1SDA();
- GPIO_InitStructure.Pins = GPIO_PIN_6 | GPIO_PIN_7;
- GPIO_InitStructure.Mode = GPIO_MODE_OUTPUT_OD;
- GPIO_Init(CW_GPIOB, &GPIO_InitStructure);
- I2C_InitStruct.I2C_BaudEn = ENABLE;
- I2C_InitStruct.I2C_Baud = 0x0B;//500K=(48000000/(8*(11+1))
- I2C_InitStruct.I2C_FLT = DISABLE;
- I2C_InitStruct.I2C_AA = DISABLE;
- I2C1_DeInit();
- I2C_Master_Init(CW_I2C1,&I2C_InitStruct);//初始化模块
- I2C_Cmd(CW_I2C1,ENABLE); //模块使能
- int32_t main(void)
- uint8_t testdata[16] = {0},index = 0;
- RCC_HCLKPRS_Config(RCC_HCLK_DIV1);
- RCC_PCLKPRS_Config(RCC_PCLK_DIV1);
- uart1_init();
- i2c_init();
- I2C_MasterReadEepomData(CW_I2C1,0,testdata,16);
- printf("EEPROM read data:\n");
- index = 0;
- while(index < 16)
- printf("%02X ",testdata[index]);
- if(index < 10)
- testdata[index] = index+1;
- else
- testdata[index] = 0xFF;
- index += 1;
- printf("\n");
- printf("EEPROM write data:\n");
- I2C_MasterWriteEepromData(CW_I2C1,0,testdata,10);
- index = 0;
- while(index < 10)
- index += 1;
- printf("\n");
- yuyy_delay_ms(10);
- printf("EEPROM read data after write:\n");
- index = 0;
- while(index < 16)
- index += 1;
- printf("\n");
- while (1)
运行结果
可以看到,在写的过程中会多写一个字节的数据,但是这个数据并没有写到EEPROM中,应该是被停止命令覆盖掉了,但是数组越界的情况还是存在,最好还是改一下
接下来用I2C读取DHTC12的温湿度数据,并用LCD屏幕显示出来,DHTC12能支持的最高频率是100KHz
- YUYY_IIC_DEV_t iic_dev;
- YUYY_DHTC12_DEV_t dhtc12_dev;
- void iic_devices_init()
- I2C_InitTypeDef I2C_InitStruct;
- GPIO_InitTypeDef GPIO_InitStructure;
- PB10_AFx_I2C1SCL();
- PB11_AFx_I2C1SDA();
- GPIO_InitStructure.Pins = GPIO_PIN_10|GPIO_PIN_11;
- I2C_InitStruct.I2C_Baud = 59; //100K=(48000000/(8*(59+1))
- I2C_InitStruct.I2C_FLT = ENABLE;
- I2C1_DeInit();
- iic_dev.iictype = YUYY_IIC_TYPE_HARD;
- iic_dev.hiicx = CW_I2C1;
- dhtc12_dev.iicx = &iic_dev;
- yuyy_dhtc12_init(&dhtc12_dev);
- uint8_t const test16x16temp[]={
- 0x00,0x0C,0x12,0x0C,0x00,0xC0,0x70,0x10,0x08,0x08,0x08,0x08,0x10,0x30,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x0F,0x18,0x30,0x20,0x20,0x20,0x20,0x30,0x1C,0x00,0x00
- float temp,hum;
- char out[20];
- uint8_t outlen;
- RCC_HSI_48M_init();
- hs12864g18b_init();
- yuyy_hs12864g18b_clear_screen(&hs12864_dev);
- yuyy_hs12864g18b_display_string_8x16(&hs12864_dev,0,0,0,(uint8_t *)"CW32L031 TEST");
- yuyy_hs12864g18b_display_string_8x16(&hs12864_dev,0,4,0,(uint8_t *)"Code by yuyy1989");
- iic_devices_init();
- while (1)
- yuyy_dhtc12_readHT(&dhtc12_dev,&temp,&hum);
- outlen = sprintf(out," %.1f%% %.1f",hum,temp);
- yuyy_hs12864g18b_display_string_8x16(&hs12864_dev,0,2,0,(uint8_t *)out);
- yuyy_hs12864g18b_display_graphic_16x16(&hs12864_dev,0,2,8*outlen,(uint8_t *)test16x16temp);
- yuyy_hs12864g18b_display_string_8x16(&hs12864_dev,0,2,8*(outlen+2),(uint8_t *)" ");
- yuyy_delay_ms(1000);
运行效果,一个简单的温湿度检测仪就做出来了
