原来的函数是这样的
- * [url=home.php?mod=space&uid=247401]@brief[/url] Display a float
- * @param x position x-axis 0 - 127
- * @param y position y-axis 0
- * @param num The order of the Chinese characters in the Hzb[] array
- * @param accuracy Preserve decimal places
- * @param fontsize 8/16
- * [url=home.php?mod=space&uid=536309]@NOTE[/url]
- void OLED_ShowFloat(uint8_t x, uint8_t y, float num, uint8_t accuracy, uint8_t fontsize)
- uint8_t i = 0;
- uint8_t j = 0;
- uint8_t t = 0;
- uint8_t temp = 0;
- uint16_t numel = 0;
- uint32_t integer = 0;
- float decimals = 0;
- //Is a negative number?
- if (num < 0)
- OLED_ShowChar(x, y, '-', fontsize);
- num = 0 - num;
- i++;
- integer = (uint32_t)num;
- decimals = num - integer;
- //Integer part
- if (integer)
- numel = (uint16_t)integer;
- while (numel)
- numel /= 10;
- j++;
- i += (j - 1);
- for (temp = 0; temp < j; temp++)
- OLED_ShowChar(x + 8 * (i - temp), y, integer % 10 + '0', fontsize); // 显示整数部分
- integer /= 10;
- else
- OLED_ShowChar(x + 8 * i, y, temp + '0', fontsize);
- i++;
- //Decimal part
- if (accuracy)
- OLED_ShowChar(x + 8 * i, y, '.', fontsize);
- i++;
- for (t = 0; t < accuracy; t++)
- decimals *= 10;
- temp = (uint8_t)decimals;
- OLED_ShowChar(x + 8 * (i + t), y, temp + '0', fontsize);
- decimals -= temp;
当我要显示28.55的时候显示成了28.54,大家猜猜是哪儿的错误。
