- #include "inc/hw_memmap.h"
- #include "inc/hw_ssi.h"
- #include "inc/hw_types.h"
- #include "driverlib/ssi.h"
- #include "driverlib/gpio.h"
- #include "driverlib/sysctl.h"
- #include "driverlib/uart.h"
- #include "utils/uartstdio.h"
- //! \addtogroup ssi_examples_list
- //! <h1>SPI Master
- (spi_master)</h1>
- //! This example shows how to configure the
- SSI0 as SPI Master. The code will
- //! send three characters on the master Tx
- then polls the receive FIFO until
- //! 3 characters are received on the master
- Rx.
- //! This example uses the following
- peripherals and I/O signals. You must
- //! review these and change as needed for
- your own board:
- //! - SSI0 peripheral
- //! - GPIO Port
- A peripheral (for SSI0 pins)
- //! - SSI0CLK - PA2
- //! - SSI0Fss - PA3
- //! - SSI0Rx - PA4
- //! - SSI0Tx - PA5
- //! The following UART signals are
- configured only for displaying console
- //! messages for this example. These are not required for operation of SSI0.
- //! - UART0 peripheral
- //! - GPIO Port
- A peripheral (for UART0 pins)
- //! - UART0RX - PA0
- //! - UART0TX - PA1
- interrupt handlers. To use this example
- //! in your own application you must add
- these interrupt handlers to your
- //! vector table.
- //! - None.
- // Number of bytes to send and receive.
- #define NUM_SSI_DATA 5
- // This function sets up UART0 to be used
- for a console to display information
- // as the example is running.
- void
- InitConsole(void)
- // Enable GPIO port A which is used for UART0 pins.
- // TODO: change this to whichever GPIO port you are using.
- SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);
- // Configure the pin muxing for UART0 functions on port A0 and A1.
- // This step is not necessary if your part does not support pin muxing.
- // TODO: change this to select the port/pin you are using.
- GPIOPinConfigure(GPIO_PA0_U0RX);
- GPIOPinConfigure(GPIO_PA1_U0TX);
- // Select the alternate (UART) function for these pins.
- GPIOPinTypeUART(GPIO_PORTA_BASE, GPIO_PIN_0 | GPIO_PIN_1);
- // Initialize the UART for console I/O.
- UARTStdioInit(0);
- // Configure SSI0
- in master Freescale (SPI) mode.
- This example will send out
- // 3 bytes of data, then wait for 3 bytes
- of data to come in. This will all be
- // done using the polling method.
- int
- main(void)
- unsigned long ulDataTx[NUM_SSI_DATA];
- unsigned long ulDataRx[NUM_SSI_DATA];
- unsigned long ulindex;
- // Set the clocking to run directly from the external
- crystal/oscillator.
- // TODO: The SYSCTL_XTAL_ value must be changed to match the value of
- the
- // crystal on your board.
- SysCtlClockSet(SYSCTL_SYSDIV_1 | SYSCTL_USE_OSC | SYSCTL_OSC_MAIN |
- SYSCTL_XTAL_6MHZ);
- // Set up the serial console to use for displaying messages. This is
- // just for this example program and is not needed for SSI operation.
- InitConsole();
- // Display the setup on the console.
- UARTprintf("SSI ->\n");
- UARTprintf(" Mode:
- SPI\n");
- UARTprintf(" Data:
- 8-bit\n\n");
- /*SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);
- GPIOPinTypeGPIOOutput(GPIO_PORTA_BASE, GPIO_PIN_3);
- GPIOPinWrite(GPIO_PORTA_BASE, GPIO_PIN_3,0);
- GPIOPinWrite(GPIO_PORTA_BASE, GPIO_PIN_3,GPIO_PIN_3);
- GPIOPinWrite(GPIO_PORTA_BASE, GPIO_PIN_3,~0);
- SysCtlPeripheralDisable(SYSCTL_PERIPH_GPIOA);*/
- // The SSI0 peripheral must be enabled for use.
- SysCtlPeripheralEnable(SYSCTL_PERIPH_SSI0);
- // For this example SSI0 is used with PortA[5:2]. The actual port and pins
- // used may be different on your part, consult the data sheet for more
- // information. GPIO port A needs
- to be enabled so these pins can be used.
- // Configure the pin muxing for SSI0 functions on port A2, A3, A4, and
- A5.
- GPIOPinConfigure(GPIO_PA2_SSI0CLK);
- GPIOPinConfigure(GPIO_PA3_SSI0FSS);
- GPIOPinConfigure(GPIO_PA4_SSI0RX);
- GPIOPinConfigure(GPIO_PA5_SSI0TX);
- // Configure the GPIO settings for the SSI pins. This function also gives
- // control of these pins to the SSI hardware. Consult the data sheet to
- // see which functions are allocated per pin.
- // The pins are assigned as follows:
- // PA5 - SSI0Tx
- // PA4 - SSI0Rx
- // PA3 - SSI0Fss
- // PA2 - SSI0CLK
- GPIOPinTypeSSI(GPIO_PORTA_BASE, GPIO_PIN_5 | GPIO_PIN_4 | GPIO_PIN_3 |
- GPIO_PIN_2);
- //GPIOPinTypeSSI(GPIO_PORTA_BASE, GPIO_PIN_5 | GPIO_PIN_4 | GPIO_PIN_2);
- // Configure and enable the SSI port for SPI master mode. Use SSI0,
- // system clock supply, idle clock level low and active low clock in
- // freescale SPI mode, master mode, 1MHz SSI frequency, and 8-bit data.
- // For SPI mode, you can set the polarity of the SSI clock when the SSI
- // unit is idle. You can also
- configure what clock edge you want to
- // capture data on. Please
- reference the datasheet for more information on
- // the different SPI modes.
- //SSIConfigSetExpClk(SSI0_BASE, SysCtlClockGet(), SSI_FRF_TI,
- SSI_MODE_MASTER, 500000, 8);
- SSIConfigSetExpClk(SSI0_BASE, SysCtlClockGet(), SSI_FRF_MOTO_MODE_1,
- 8);
- // Enable the SSI0 module.
- SSIEnable(SSI0_BASE);
- // Read any residual data from the SSI port. This makes sure the receive
- // FIFOs are empty, so we don't read any unwanted junk. This is done here
- // because the SPI SSI mode is full-duplex, which allows you to send and
- // receive at the same time. The
- SSIDataGetNonBlocking function returns
- // "true" when data was returned, and "false" when
- no data was returned.
- // The "non-blocking" function checks if there is any data in
- the receive
- // FIFO and does not "hang" if there isn't.
- while(SSIDataGetNonBlocking(SSI0_BASE, &ulDataRx[0]))
- // Initialize the data to send.
- ulDataTx[0] = 'H';//s
- ulDataTx[1] = 'e';//p
- ulDataTx[2] = 'l';//i
- ulDataTx[3] = 'l';//i
- ulDataTx[4] = 'o';//i
- // Display indication that the SSI is transmitting data.
- UARTprintf("Sent:\n ");
- // Send 3 bytes of data.
- //SSIDataPut(SSI0_BASE, 'A');
- for(ulindex = 0; ulindex < NUM_SSI_DATA; ulindex++)
- // Display the data that SSI is transferring.
- UARTprintf("'%c' ", ulDataTx[ulindex]);
- // Send the data using the "blocking" put function. This function
- // will wait until there is room in the send FIFO before returning.
- // This allows you to assure that all the data you send makes it into
- // the send FIFO.
- SSIDataPut(SSI0_BASE, ulDataTx[ulindex]);
- // Wait until SSI0 is done transferring all the data in the transmit
- FIFO.
- while(!SSIBusy(SSI0_BASE))
- // Display indication that the SSI is receiving data.
- UARTprintf("\nReceived:\n
- // Receive 3 bytes of data.
- // Receive the data using the "blocking" Get function. This
- function
- // will wait until there is data in the receive FIFO before returning.
- SSIDataGet(SSI0_BASE, &ulDataRx[ulindex]);
- // Since we are using 8-bit data, mask off the MSB.
- ulDataRx[ulindex] &= 0x00FF;
- // Display the data that SSI0 received.
- UARTprintf("'%c' ", ulDataRx[ulindex]);
- UARTprintf("\n");
- while(1);
- // Return no errors
- //return(0);
