单电源IC,必须注意这个问题。
Maxim有beyond-the-rail,允许输入略负于地电平。 ADI同样的情形如:ADuC824的32~33页---
Analog Input Ranges
The absolute input voltage range on the primary ADC is restricted to between AGND + 100 mV to AVDD – 100 mV. Care must be taken in setting up the common-mode voltage and input voltage range so that these limits are not exceeded, otherwise there will be a degradation in linearity performance.
The absolute input voltage range on the auxiliary ADC is restricted to between AGND – 30 mV to AVDD + 30 mV. The slightly negative absolute input voltage limit does allow the possibility of monitoring small signal bipolar signals using the single-ended auxiliary ADC front end. 这种情形不多,但有时非常有效----不需要偏置电压(共模电压)抬高信号电平。
http://www.analog.com/UploadedFiles/Data_Sheets/ADUC824.pdf
