lqland 发表于 2014-4-29 20:08
你第一次提的指令:
./ltib -m scbuild -p imx-tet-3.0.35-4.1.0
./ltib -m scdeploy -p imx-tet-3.0.35-4. ...
楼主你好,在飞思卡尔官方文档中有解释如下三个命令的含义和使用方法,你可以查看一下:
/* Get the source code of one package. The source code will be extracted to <ltib folder>/
rpm/BUILD/ */
./ltib -m prep -p <package name> --------- 释放源码
/* This command is used to build the source code of <package name>. If you modify the source
code, you can rebuild the source code by this command */
./ltib -m scbuild -p <package name> ---------重新编译源码
/* Install one package to rootfs */
./ltib -m scdeploy -p <package name>----------将package放到rootfs目录下
如有疑问再联系~~
