在给FPGA分配引脚时,出现错误 Error: Can't place pins assigned to pin location Pin_101 (IOPAD_X34_Y18_N21) Info: Pin /OE is assigned to pin location Pin_101 (IOPAD_X34_Y18_N21) Info: Pin ~ALTERA_nCEO~ is assigned to pin location Pin_101 (IOPAD_X34_Y18_N21)
其中ALTERA_nCEO是FPGA配置用的芯片,可以不用的,所以可能通过Assignents->Device->Device and Pin Options->Dual-Purpose Pins中设置ALTERA_nCEO为Use as regular I/O,其中Dual-Purpose Pins看起来像是不可修改的,其实呢只是个假像,只要双击它就可以出现下拉框来供你选择了。
